Question about Kenmore 43042 Front Load Washer
My 4 yr old kenmore(G.E.made) front loader will not spin
My wife started wash in morning, came home evening and washer was stuck in the rinse cycle continuously pouring water in the tub and draining out too. Long story short- I start any cycle the the water is poured in and then it does nothing. I advance it and still does nothing. I advance it to spin cycle and it drains out the water continuously and nothing else. I check the belt and it looks fine and the door shows locked during cycle. Can this be solved by a do-it-yourself-er or spend money on a appliance tech? I would appreciate any help. thanks!
    Genius:
  • 3,587 Answers
You may need a new control panel and timer..not hard to do, but you'll need the serial number to get parts online.
Posted on Mar 09, 2008
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
Jan 30, 2012 | Washing Machines
Maytag front loader HE washer.
cheak your tube if there is a nail or an object is stuck in one of the holes
Jan 24, 2010 | Maytag MAH6700A Neptune High Efficiency...
F 02 reading on front loader washer.
I found several helpful sites from owners who had the same problem and they got the issues resolved, will try what they advised and if that don’t work I’ll call a service technician.
Oct 01, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Kenmore washer not draining/also getting stuck doing nothing
i had my kenmore washer doing the same,looked at water pump but nothing was stuck inside ,i tried the lid switch and stuck a screwdriver in it to see if this would do the trick,nothing..but when i took it out, i could see where it had come apart...took it out and decided to use gorilla glue and clamp it back till the glue dries,before the glueing process ,i test the draining outside with a buckett..and bingo,it started draining the water,i only had the switch crimped with my fingers and at the same time pushed the switch down ,it worked..draing started..hopes this helps
Mar 15, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
I also need the answer...
where is the lint trap located
Dec 06, 2007 | Washing Machines
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Kenmore 43042 Front Load Washer Logo
98 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
