Question about Dell Inspiron 8200 Latitude C840 Laptop Keyboard03J247 CD-ROM Drive
Dell Latitude C840
Dear Wiz,
When press th epower button on my Dell lattitude C840 the green power light comes on , but after about a second or so it goes off again, **thing else. The battery is fully charged. I tried by removing the HDD, the CD rom, and display, even the momory and Cable interface card still ** effect, This problem occured after the Laptop was dropped. there is ** physical damage visible. Nothing is broken. Please help. i am a tech. i got to repair this one. or I will have to buy the customer a new |laptop. I am too poor for that.
I had the same problem which was after dropping the laptop. There is a small pcb which is plugged in under the keyboard near the mouse pad. It had come completely out of its socket and with a bit of fidling i managed to get it back in without removing the palm rest. Think i had to remove the other pcb above it though ?? May have been the vga card ? This fixed mine instantly ;)
Posted on Sep 10, 2008
Try testing your dc jack.When it was dropped more likely the dc jack is the problem,not getting a charge.Go on ebay and order a jack.
Posted on Jun 13, 2008
  • 47 Answers
Pls check your power supply
Posted on Mar 13, 2008
I know it is too late, but it may help to others,
Many Dell C8** have this common issue, which you can fix by pushing memory in a little and see if it starts. Try on 1 stick first. If it helps put something under the memory cover so it'll constantly push memory in. Hope it helps.
Posted on Aug 29, 2008
Im looking for the password of my dell lattitude c840 with jydxs0j-595b
Welcome to Fixya Support
I am Michelle, and i will be assisting you regarding the issue
in case you are not able to boot to windows, you can use the password recovery tool that can be downloaded from below link.
download this tool on another computer and it will create a disc.
you need to boot the computer in which the issue is occouring with the disc.
All steps are mentioned in below link as well
http://www.loginrecovery.com/index.php
In case its the power on password that you have forgotten then you need to get the same reset through Dell itself.
please feel free to ask in case you face any difficulty
Nov 21, 2010 | Dell Latitude C840 Notebook
Power comes on and then off after only a few
if u say the battery is the problem then first solve that the ill help with the battery which can be only done by replacing them!!
then reply and rate!!
Jul 11, 2010 | Dell Inspiron 8200 Latitude C840 Laptop...
Need to reset cmos for booting to DVD drive dell latitude c840
Hi try pressing the ESC button during boot up, sometimes its the delete button, then select this drive by scrolling down, select CD drive for primary boot device, save changes and reboot. Hope this helps, come back to me if you need more help?
Jul 07, 2010 | Dell Latitude C840 Notebook
My dell C840 wont power on.
well if the laptop worked till there was charge in the secondry battery its an issue with the cord or the port that connects the powercord to the laptop. ie the inlet on the laptop. check these two as well.
Mar 29, 2009 | Dell Latitude D830 Notebook
My dell lattitude D610 laptop wont charge battery
before you come to that conclusion, try it on AC power only
get back to us if the problem is still the same
regards
Dec 22, 2008 | Dell Latitude D600 Notebook
D800 will not even boot
Okay, I had that problem with my HP less than a minute ago.
Maybe it is the same problem. See if the battery light comes on. Press the power button again and again if it doesn't start, for some time. It may show the boot screen and hang. Now, the battery must be charged. Shut it down directly and switch the AC off.
Now, switch it on and see if the battery light comes on. If it does, it is the same problem as mine. Now, turn the PC over and remove the battery carefully. There may be switches for that.
Now, plug in the AC and start it without the battery in. If it does, you're done. Now, plug in the battery again.
Nov 28, 2008 | Dell Latitude D600 Notebook
D600 Power problem, Won't boot up
I agree. Try to turn on your computer using the ac adapter only. If the system won't hold power using the ac adapter. I suggest to call you computer manufacturer to check the warranty . I am seeing a problem with the motherboard.
Keep me posted.
Thanks.
Oct 19, 2008 | Dell Latitude D600 Notebook
Dell Lattitude C840 Laptop
The 3 LED's (Num Lock, Caps Lock, Scroll Lock) are used by Dell to diagnose no-post issues such as yours. The only error code close to yours is [Num Lock ON, Caps Lock FLASHING, Scroll Lock ON]. This indicates a a memory error. Try reseating the memory modules. If you have 2 memory modules, insert one at a time to determine the faulty module.
Sep 21, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
Power Cord
The power adaptor is faulty - they are available quite cheaply on ebay. Search using the same part number from your original adaptor to ensure getting the right type.
Please rate this assistance.
Mar 29, 2008 | Dell Latitude C800 Notebook
Computers & Internet Logo
246 people viewed this question
Alun Cox
