Question about Mr. Coffee GBX25 Coffee Maker
Coffee maker not working
I have a mr coffee GBX25 brand new, trying to use it for the first time, the clock is working but nothing else works. I don't have the manual for this machine, the on/off button is not light up, if any one know how to fix it, please help
I fixed it! I returned the thing back to store.
Posted on Mar 10, 2008
Mr coffee model gbx23 stopped working, it won't turn on.
It might be a problem with your outlet, and not the coffee maker. Your kitchen outlets should be GFCI protected. There is supposed to be a sticker on all outlets that are protected by a Ground Fault Circuit Interrupter, but sometimes they are left off. Look for an outlet in the kitchen that has a rest button between the outlets. You can also take the coffee maker to a known working outlet, or bring something that you know works to the coffee maker outlet, to see if it is the outlet that is not working or if the coffee maker is still not working at a good outlet. If the outlet isn't working, try others in the kitchen to see if they are. If they are not, and you didn't locate a reset button on one of them, then check the breaker box for a tripped breaker.
Coffee makers do have at least 2 safety switches inside them, but they are only to keep them from overheating and catching fire. If one of the switches did go bad it is possible that it might shut down the entire machine. If that is the case, then it's time for a new coffee maker, as the safety switches are not servicable.
dd1bd15d-8ff7-4198-9167-3cc45a5562ef.jpg120v AC GFCI outlets
(220v AC outlets will have the same reset buttons)
Apr 28, 2014 | Mr. Coffee GBX23
There seems to be power going to my Mr. Coffee (the clock face is lit- though the clock face is blank). However, when I push the "brew now" button nothing happens. I changed outlets and still nothing. I...
Does the bottom pad get warm? If not it maybe a relay on the control board or most likely the element is bad. You can change this out but it is probably more cost effective to just purchase a new one.
Aug 21, 2010 | Mr. Coffee 12-Cup Programmable Coffeemaker
My coffee maker won't brew the coffee. Mr.Coffee GBX25
you tube is clogged pour in 2 cups of vinagar an brew this will eat away the calcium deposits. in your coffee maker if you water is hard where you live you may want to by distilled water or use some type of filter or water softener
Jun 23, 2009 | Mr. Coffee TFTX85 Coffee Maker
Mr.Coffee maker (quite new) won't make coffee
This is still under warranty, I would return for a new one. You could also call number in manual, they will probably replace it.
Jun 09, 2009 | Mr. Coffee TFTX85 Coffee Maker
Maker clicks on, but doesn't perk or heat the plate.
Unlike older coffee makers, the new Mr. Coffee designs seem to have reliability issues in regard to their circuit boards/controllers. You are right in your thoughts. If the unit is under warranty, I would suggest returning it for a replacement. E-mail your concerns directly to the company.
BTW--there are no user serviceable items within your coffee maker.
Mar 26, 2009 | Mr. Coffee FTX49 12-Cup Coffee Maker
Mr coffee model isx43 12 cup
Turn the :Warming Temp." dial to the right, this is the hottest the heating plate will get and should resolve your problem. THedial is locatedjust under the clock.
Feb 02, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Model DRX23
if machine work fine led screen is going it a maner of time before you see nothing cheers
Jan 23, 2008 | Mr. Coffee TFTX85 Coffee Maker
Mr. Coffee GBX25 Coffee Maker Logo
318 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Henry  Thomas
Henry Thomas
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
