If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system.:
From the Switcboard / Main telephone or Managers phone with the handset on the cradle/hook:
1. Press PROGRAM * * or PROGRAM * # followed by the system password ( default is 1234).
2. Now press 000 and then ENTER.
3. Enter the last 2 digits of the year and then select the month with either SEL+ or AUTO ANS / MUTE.
4. Scroll right with the right arrow key and change the date.
5. Press the NEXT button on the screen and the time will appear.
6. Set the time. Press AUTO DIAL / STORE to save your changes.
7. Lift the handset and put it down to exit program mode.
Auto-Set Time and Date Settings
This model is equipped with the Auto-Set feature, meaning that the time and date have been programmed at the factory
and will already be set when you first plug the model in. Auto-Set will automatically adjust the time and date settings for
daylight-saving time and leap years. Auto-Set is programmed for Eastern Standard Time; if you do not live in this time zone,
you can easily switch the setting to one of six other time zones.
1. To change your time zone setting, press and hold the 8 Time Zone Button. The current Auto-Set Time Zone in the
lower-right-hand corner of the display will flash for approximately ten seconds, after which the display will revert to the
standard clock display.
2. While the Auto-Set Time Zone is flashing, press the 1 Reverse and 6 Forward Buttons to select your time zone.
The display will show each zone's current time setting. There are seven zones to choose from:
Auto-Set Time Zones
Z-01 Atlantic Standard Time
Z-02 Eastern Standard Time
Z-03 Central Standard Time
Z-04 Mountain Standard Time
Z-05 Pacific Standard Time
Z-06 Alaskan Standard Time
Z-07 Hawaiian Standard Time
3. Find your time zone, then press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the
setting to lock into place.
Manual Time and Date Settings
1. To change your time setting, press and hold the J Time Set Button so that the clock display begins flashing.
2. While the display flashes, press the 1 Reverse and 6 Forward Buttons to set the time. Hold a button for a few
seconds to set the time rapidly. Be sure to set the correct AM/PM time, shown by the PM Indicator.
3. After setting the time, press the 4 Enter Button or wait about ten seconds for the clock to beep twice and the setting
to lock into place.
4. To change the calendar, press and hold the 9 Date/7-5-2 Button until the display shows the flashing year.
5. Press the 1 Reverse and 6 Forward Buttons to set the current year. When you have selected the year, press the
4 Enter Button, then use the 1 Reverse and 6 Forward Buttons to set the month/day.
6. After you have set the date, press the 4 Enter Button or wait for the display to beep twice and lock into place.
