Question about Whirlpool LGV4634JQ Gas Dryer
Need advice! My washer and dryer both went out this morning! What a bad day I am having! Anyway, I push the button and it makes a unusual sound but nothing else happens is there anything iI can do besides buy a new one??
  • chasity42176 Mar 09, 2008
    only a clicking noise like its about to start but it dont start, it doesnt do anything but make that noiseit is a Whirlpool LGR4634EQO Gas Dryer
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    If you are talking about a gas dryer, is this a "buzzing" sound?
  • 5,911 Answers
Okay...here's what you need to do to check out a gas dryer:
This advice is for problems associated with GAS DRYERS that RUN, but DO NOT HEAT. Ensure your dryer ducting is clear and **t clogged, first. ALL dryers require proper air flow in order to dry efficiently. If you do **t have any obvious vent duct obstructions you can follow these simple steps in identifying WHICH dryer heating circuit component may be defective BEFORE you have to disassemble anything. With the dryer plugged in and the gas supply turned on, follow these steps:
PUSH START – Listen for a “click”. You have to listen carefully to hear it. If ** “click” is heard when you push the start button, this is usually an indication of a bad RADIANT HEAT SENSOR.
PUSH START – “Clicking” sound is present, but dryer still does **t ignite. This is usually an indication of a bad IGNITER.
PUSH START – Dryer ignites, but heating circuits shut off after a short period of time. You attempt to restart, but the dryer makes a “buzzing” sound. This is usually an indication of a bad GAS VALVE SOLENOID.
Now, these initial symptom analyses will give you a rough idea of where to begin troubleshooting. These tips are NOT all inclusive, but suited for the more common problems encountered with dryer ignition problems. In theory the dryer ignition works like this – You push the start button and the igniter begins to glow. This igniter will produce a certain current potential (roughly 2.5 to 3.7 amps, depending on type of igniter) and the gas valve will open. Once the gas valve opens, you have ignition. This is a built in safety feature of the unit that prevents free flowing gas inside your home or garage without ignition. If you suspect a bad gas valve sole**id, the dryer usually has two of them. It is recommended that you replace BOTH of them at the same time. If you suspect the igniter to be bad, open the dryer e**ugh to see the burner assembly. There should be a visible glow from the igniter after you push start. If the igniter does NOT glow, replace it. If the igniter DOES glow, take a current reading to see if it is producing e**ugh current. Here are the two types of igniters are their specifications:
Carborundum – cylindrical in shape (2.5 to 3.0 amps)
Norton – Rectangular in shape (3.2 to 3.7 amps)
I hope this information is helpful. Post back if you have any questions/concerns.
PS From the initial indications you gave, it sounds like you may have a bad igniter.
Posted on Mar 10, 2008
  • Jeff Rockwell
    Jeff Rockwell Mar 10, 2008
    PS There is something wrong with the posting of comments on this page. Anything with the letters N or O (in that order) show up as an asterisk for some reason.
I went to press the Play/Pause button for the dishwasher this morning and it wouldn't beep or do anything. The light is on above the button. I then went to press the On/Off button to reset it.....and...
Not near enough info here to even speculate. What is the model #? Does the manual have a reset procedure? Try turning off the breaker for 15 minutes,
Mar 30, 2017 | DCS Dishwashers
Push button to start and does not start
Your problem could be with the "push to start" switch or "door" switch.
Apr 14, 2010 | Roper RES7648E Dryer
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
Dryer just sits and hums
if you push the start and it just humms it is a bad dryer motor to weak to kick on,to confirm this have sombody hold the dryer door button in and turn the drum when you push the start button,if it jump starts you know it's a bad motor-mike
May 05, 2009 | Dryers
Dryer won't start when pushing the button it clicks
Could be a broken belt if you hear motor, also can be defective door switch. you can try pushing door switch with finger and press button If motor does not make a sound and pressing door switch does nothing you will need a volt meter and test for power if you hear moter then its broken belt or jambed drum. Try and manually move drum
Jan 14, 2009 | Kenmore 62602 Electric Dryer
Not working at all
reset your circuit breaker - if it pops again, check for a blown element or burned out motor
Feb 09, 2008 | Kenmore 62602 Electric Dryer
Whirlpool LGV4634JQ Gas Dryer Logo
108 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
