Question about Sony VAIO VGN-N250E/B Notebook
Sony notebook problem
Something wen wrong on my computer---Now when I turn the computer on it will boot up and load then the screen turns black---when i hit control alt delele the blue screen with the option lock computer tast manager and so on show up---after this the screen turns black---what is the problem---Please help me this is making me so crazy-----
  • 520 Answers
Put os in cd drive and boot up to install new copy .if system says ** os found you k**w you have hd problem you can try to fix or reinstall new copy anyway.remove hd and re seat it first.check mem .remove ,check connections and replace.go into bios and select default.save and exit.
see how you get on .
sounds like missing or conflicting software but try all the above first.If it is missing or conflicting software pretty easy to fix.let me k**w
Posted on Mar 10, 2008
My Toshiba Satellite C665 Laptop will not start up, when I push the power button to turn it on it does not load or start. On the bottom of the screen it says press F2 go to Setup Utility or F12 to go to...
There is something wrong with your hard drive.. It is not being recognized by your bios. Could be a bad logic board. Get appropriate software and perform diagnostics on it to confirm
Sep 08, 2017 | Toshiba Satellite Laptop with Intel Core...
The computer has the wrong compaq on it so it will not boot up.
After going to setting does it boot normally? Coz it sounds CMOS battery due for replacement.
Apr 03, 2009 | HP Presario R3000t PC Notebook
WINDOWS EXPLORER VISTA
then tey and use window Xp cd to boot your systems from the setup and it is ok for using xp than vista ok then before then you can backup your document so that you can format your systems before loading or installing any device ok post to me what else .
Sep 01, 2008 | Sony VAIO VGN-S460 Notebook
My computer's "driver" won't start therefore my computer won't boot.
While Booting the Laptop, Press the F2 Key (some use DELETE key) .. THis will take you to your Bios Setup.. Look there for .. LOAD OPTIMAL SETTINGS.. Choose Save & Reboot..Also In there If You See.. ENABLE FAST BOOT, or something Similar.. Set it to that to Bypass the screen youre seeing.. Hope that helps your Problem.. Cheers
http://www.wnycomputerpro.com
Jun 03, 2008 | Acer Aspire 5100 Notebook
Problem restarting, "press r"
  1. Start the laptop
  2. when the logo screen turns black start pressing F8 a few times.
  3. A Windows Boot Options screen should show on the screen
  4. If you see the Windows Logo (the normal thing when Windows loads, then press reset and try again
  5. At the Windows Boot Options screen select "Last known good configuration" and press Enter twice
It "should" now load normally, if not then..
  1. Replace step 5 above with "Safe Mode" and see if that loads all the way through. If so, then restart and see if its OK now.
If not, then post back with any error messages and we can look at something else.
Apr 13, 2008 | Toshiba Satellite A105 Notebook
Sony vio vgn-250E
I'm afraid that it sounds like your inverter, which is responsible for all LCDs to light up, has gone bad. If you are in warranty, they are not hard to install. Google them. Sony has live help with real American accents, who Ihave found very knowledgable. They can take over your screen during a chat, and troubleshoot it to confirm this is the problem. First, try a system restore to a date when your monitor worked. This happens with 50" LCD TVs, too.
Mar 09, 2008 | Sony VAIO VGN-N250E/B Notebook
Computer wont boot
yep you said it loose connection, wiggle the power cord and and thing attached.
Jan 08, 2008 | Computers & Internet
Booting and dvd drive not detected
i'm not sure if your pc has a floppy drive, but if it does, then get a win 98 or win ME startup disk then power up and then push the F8 key (or DELETE key) to enter BIOS setup then select boot floppy then and insert into slot then reboot then boot minimal then get to c: drive and run CHKDSK/FIX then try again, w/out floppy. if no-go then repeat back to c: drive and delete the PAGEFILE.SYS file (may need to attribute the file to allow delete) then reboot w/out floppy
Jun 02, 2007 | Compaq Presario V4000 Notebook
Sony VAIO VGN-N250E/B Notebook Logo
91 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
