Question about Western Digital MyBook Pro WDG1T5000 500 GB FireWire 400 (1394a) Hard Drive
PLEASE HELP I have a external hard drive that has changed from Z drive to the E drive and now it wont work the data that was on the hard drive will not show it tells me to locate it myself. I cant get it to show what is on the hard drive anymore. I cant run the programs that are on the ex hard drive
    Sergeant:
  • 406 Answers
Goto>
Control Panel> Performance and maintenance> Administartive Tools>Computer Management>Disk Management> Select The drive And Right Click after that select the Option {Change Drive Letter and Paths} \
here you can change drive letter and Path. If you need more help Kindly update the Request.
Posted on Mar 09, 2008
USB connector Hard Disk faulty
Usually you wont be able to change the USB-connector (problem 1: where to get an identical connector; problem 2: how to solder it without damaging something else). :-((
If you have important data on it, the best would be to take the hard drive out of the case and buy a USB-adapter for it (PATA or SATA as needed). With that you can access your data and copy them to something else - maybe a new external hard-drive.
Apr 10, 2014 | Buffalo Jeans Hd-Pnt500U3R 500Gb External...
Recovering data from external hard drive. HElP PLEASE
Try connecting the drive to a different computer. If it works then backup your data.
Mar 03, 2013 | Computers & Internet
I have a toshiba 500GB portable external hardrive....it still has 50GB more space left...however when i tried to open it...it wont open and i cant see my files...the computer says that it cannot fix the...
You can recover data from portable hard drive with data recovery software.Tenorshare data recovery is one of the bests. It can recover data after deeply scanning your hard drive to look for lost data due to drives crash, physical damage,bad section, virus attack etc.Download it and scan your external hard drive for free to preview whether your files can be recovered.You can get it here: http://www.any-data-recovery.com/product/datarecoveryprofessional.htm After you recover your data,you can format it to check out whether it can be fixed.
Jul 10, 2011 | Toshiba 640GB USB 20 Rocket Red Portable...
My external hard drive was damaged i wont recovery from hard drive.
Depending on the severity of the damage you have a couple of options.
1) Put the HDD inside a airtight bag and place in a freezer for at least 4 hours. Remove the HDD from freezer and see if it works. If it does start to work you will have a limited amount of time to recover the data.
2) Pay Data recovery company to recover the data
http://www.ontrackdatarecovery.com/
Mar 06, 2011 | Transcend 160Gb StoreJet 25 Unveils Rugged...
My external hard drive quit working. The light on
Its is normally tough to make external hard drive work after they stop working. Mostly you wont be able to retrieve the data. You might need to go to a specialist for that and it would cost you some bucks.
Feb 12, 2010 | Computers & Internet
I restored my computer and i saved all my data in my one touch 4 mini hard drive. Now my computer wont read one touch 4 mini 250gb. can some one please help me i lost everything?
No, you haven't lost anything. When you restored your software, you only restored the factory stuff. You'll need to reinstall the driver for the external hard drive. After you do that, your external drive and data should be accessible.
Nov 12, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Hi i got a buffalo tb external hardrive and the pc wont recognise it now after i transfered alot of data when the pc froze and i had to turn pc off mid transfer . please can you help
It is probable that since the transfer did not complete, the data on the external drive will be corrupt.
Uninstall the external drive then reinstall and format the ext drive.
You should then be able to begin the data transfer process again.
It just sounds like bad luck that your pc froze mid transfer.
When you try again, do not use the pc for any other uses until the transfer has completed.
Regards and let me know if this works for you.
Feb 24, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
USB port broken in 1TB seagate Freeagent external hard drive
This listing (260320213027) has been removed, or this item is not available.
IS THERE ANOTHER SITE THAT WILL FIT MY SEAGATE EXTERNAL HARD DRIVE, 1TB?
Feb 20, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My digital western external hardrive wont switch on..please help!
warrenty will be void if you open the casing
but warrenty for hdd will remain .. so if under warrenty get it replaced, as it is, if data required the warrenty should not be concidered and data recovered, probably the hard drive may not have got damaged , so dont get fooled if some one says data recovery . if you cannot do it hire an expert guru for data recovery.
Feb 07, 2009 | Western Digital WD800BB (999999991867) 80...
Problwm using my external hard drive
hey mate only thing i can think of is, on some external hard drives theres a switch on the side that write protects the data, you usually just have to change the switch over and it will work fine :-) all the best John
Mar 09, 2007 | FireLite (USBFLB80) Hard Drive
Western Digital MyBook Pro WDG1T5000 500 GB FireWire 400 (1394a) Hard Drive Logo
63 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
