Something wen wrong on my computer---Now when I turn the computer on it will boot up and load then the screen turns black---when i hit control alt delele the blue screen with the option lock computer tast manager and so on show up---after this the screen turns black---what is the problem---Please help me this is making me so crazy-----
I'm afraid that it sounds like your inverter, which is responsible for all LCDs to light up, has gone bad. If you are in warranty, they are not hard to install. Google them. Sony has live help with real American accents, who Ihave found very knowledgable. They can take over your screen during a chat, and troubleshoot it to confirm this is the problem. First, try a system restore to a date when your monitor worked. This happens with 50" LCD TVs, too.
If when you say faint you mean you can barely make out an image then the problem is most likely the backlight inverter in the screen assembly has gone bad. If what you mean is that the brightness got turned all the way down then it's just a matter of adjusting the brightness of the screen by holding down the function key (Fn) and pressing the LCD screen brightness adjustment keys noted usually by a picture of a sun or something similar accompanied by an up or down arrow.
then tey and use window Xp cd to boot your systems from the setup and it is ok for using xp than vista ok then before then you can backup your document so that you can format your systems before loading or installing any device ok post to me what else .
put os in cd drive and boot up to install new copy .if system says ** os found you k**w you have hd problem you can try to fix or reinstall new copy anyway.remove hd and re seat it first.check mem .remove ,check connections and replace.go into bios and select default.save and exit.
see how you get on .
sounds like missing or conflicting software but try all the above first.If it is missing or conflicting software pretty easy to fix.let me k**w
