I scan a paper correctly, and nothing happens
  • 24 Answers
Yor scanner is hookup correctly? You see it in your control panel? Under scanners and camera's. That is if you are using XP. If you are using XP. try using it in control panel, let me know what happens.
Let me know how it goes.
Posted on Mar 09, 2008
Not scanning
hmm..this is interesting..you'll need a new driver set first..go here for that
Mar 03, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printing pdf's, margins are wrong and cut off on top and left.
Hi
Choose the correct paper size of your printer for scanning and printer because I believe you select the incorrect paper size and it cut the pdf scanned file.
Go to printer icon, right click mouse and choose printing preferences and choose the correct paper size. Then go to scanning properties and choose the correct paper size.
Mar 16, 2011 | HP LaserJet 1022 Printer
Every time I scan lines appears either on document or pictures. I tried cleaning the glass but nothing happens.
Clean the **** glass with alcohol. The **** glass is the little glass that paper is scanned over when using a automatic document feeder.
Jun 18, 2010 | HP 5590 ScanJet Flatbed Scanner
I put in the paper push scan push start and it just says sleep nothing happens
you need to have mfc connected to computer with scan software running in order to scan, if you want to copy you just press copy and it will scan and print without computer connected.
Oct 29, 2009 | Brother MFC-5840CN All-In-One InkJet...
HP Deskjet F4280 all-in-one - when I preview a scan in "scanners and cameras" it previews fine but when I press the button to scan, the on/off light just blinks rapidly at me and nothing happens.
If you have installed your printer correctly, is your Page aligned, if not try page alignment by loading A4 paper into the tray and adjust the tray to fit with your paper, then restart your printer.
Note that you do not need the photo smart essential to perform your scanning, all you need is to press the scan button and the scanning page automatically open on your PC
Aug 02, 2009 | HP DeskJet F4280 All In One Printer InkJet
Printer will not scan pictures.
Introduction To use the scan features, the HP All-in-One and computer must be connected to each other and turned on. The HP All-in-One software must also be installed and running on the computer prior to scanning. To verify that the HP All-in-One software is running on a Windows computer, look for the HP Digital Imaging Monitor in the system tray at the lower right side of the screen, near the time. NOTE: Closing the HP Windows system tray icon can cause the HP All-in-One to lose some of its scan functionality and result in a No Connection error message. If this happens, correct it by restarting the computer or by starting the HP Image Zone software. Follow the instructions below to scan documents from the all-in-one to an application. Make a Scan Step one: Load paper
  1. Open the paper tray door. Figure 1: Opening the paper tray door c00315283.gif
  2. Pull the paper tray extender toward you, as far as it will go. Flip the paper catch at the end of the paper tray extender to open the extender the rest of the way. WARNING: Legal paper might get caught on the paper tray extender if it is fully extended when you print onto legal paper. To avoid a paper jam when using legal-size paper, do not open the paper tray extender.
  3. Squeeze and hold the tab on the top of the paper-width guide, then slide the paper-width guide to its outermost position. Figure 2: Sliding the paper-width guide to the outermost position c00315284.gif
  4. Tap a stack of paper on a flat surface to align the edges, and then check the paper for the following:
    • Make sure it is free of rips, dust, wrinkles, and curled or bent edges.
    • Make sure all the paper in the stack is the same size and type.
  5. Insert the stack of paper into the paper tray with the short edge forward and the print side down. Slide the stack of paper forward until it stops. NOTE: If using letterhead, insert the top of the page first with the print side down. For more help on loading full-size paper and letterhead, refer to the diagram engraved in the base of the paper tray. Figure 3: Inserting paper into the all-in-one c00315285.gif Squeeze and hold the tab on the top of the paper-width guide, then slide the paper-width guide inward until it stops at the edge of the paper. Figure 4: Sliding the paper-width guide to the edge of the paper c00315286.gif Do not overload the paper tray; make sure the stack of paper fits within the paper tray and is no higher than the top of the paper-width guide.
Step two: Load the original NOTE: Many of the special copying features will not work correctly if the glass and lid backing are not clean.
  1. Lift the lid and place the original face down on the left front corner of the glass, with the sides of the original touching the left and bottom edges. NOTE: For more help on loading an original, refer to the guide engraved under the glass.
  2. Close the lid.
Step three: Scan to an application NOTE: To use this feature, you must have installed the full software package and the HP Digital Imaging Monitor must be running.
  1. Press Scan on the control panel. A preview image of the scan displays in the HP Document Viewer window on the computer, where you can edit it.
  2. Click Done or Finish in the software. The HP All-in-One sends the scan to the HP Image Zone software, which automatically opens and displays the image.
NOTE: To stop scanning, press the Cancel button on the control panel, or in the HP Image Zone software, click Cancel . Have a good day,
Jun 18, 2009 | HP PSC 1410 All-In-One InkJet Printer
Partial print
Are you sure you have the paper aligned correctly?
should be left top or center.
Do you have the correct sive paper (Letter instead of A4)?
What happens to the rest of the copy : cut off, blank, black?
Is the scanner light staying on when scanning the whole page or does it die out when it scans 3/4 of it? ( bad scan cable or board)
Jul 31, 2008 | Sharp AL 800 Copier
Open Questions:
Computers & Internet Logo
24 people viewed this question
Alun Cox
David Payne
David Payne
