Question about Sony VAIO PCV-V200G PC Desktop
Testing this system out for starters
Aloha..this is a truly great item..thanks for posting it.
    Genius:
  • 3,587 Answers
Just wondering about this new innovation that is truly a look to the future.
Posted on Mar 09, 2008
1991 dakota blows 40amp ignition fuse when turning ignition on
First, I'm not a Dodge Tech.
* Check starter for short (or damage)
* Check starter relay for short (or damage)
* Check battery cables for clean connections (especially to starter)
* Have the Auto Mechanic check the starter system.
Aloha, ukeboy57
May 29, 2018 | Dodge Dakota Cars & Trucks
Car wont crank, start, spark... need igntion system wiring diagram, any helpful advice, an old priest and a young priest for a 1999 lexus gs300
Are you sure it is the starter relay that you hear clicking?
If the starter relay is truly clicking, check continuity of the wire from the relay to the starter solenoid.
If good, most likely problem is the security system or the neutral safety switch. If no security light is flashing, check continuity of the neutral safety switch. See notes at link below.
Do It Yourself Diagnosis and Repair
Aug 23, 2017 | Lexus Cars & Trucks
I have 1999 GMC suburban, it will not start without and boosted
Have you never had a problem like
that, since you started driving?
Start testing things-- to find a problem
Is the battery dead,old,worn out?
Have it tested
Test the starter & solenoid
Examine & test the battery cables
& many other items effecting the starting system
Won't Crank (turn over)?
or
Won't Start?
Won't Start check for fuel pressure,spark,injector
pulse & so on
Oct 04, 2014 | 2003 Chevrolet Suburban 1500
Mazda sting 130 2003 repair of the starter and the connection there of .
no symptoms posted.?
sting, we dont have them here, so what country?
is this is 323 car? 1.3L engine, can you see the starter, have you attempted to even look ,yet?
just starter vague post.
is this just a question of how to replace a starter and not get an acid bath?
1: disconnect battery minus lug. first, always 1st,
2: gain access to starter (remove stuff, or read the FSM)
3: take of the 2 wires from starter solenoid.
4: remove the 2 bolts.
5 it falls out.
or did you mean :?
I have a bad starter, can I repair it,
sure you can 90% of time. (skills good)
but usually the parts add up to more that a rebuilt.
we can show the tests, all great books on starter repair cover this.
in a pinch ive even repaired a solenoid.
ask. for the tests. and steps.
but with zero symptoms , id be forced to show all tests. all steps.
why ask this,..?????
Jun 19, 2014 | Cars & Trucks
I have a 1996 buick lesabre and when i turn key to start,i get nothing.not even a click from the solenoid.i can jump the solenoid and starter works fine.i have been reading about a possible fusable li
you get email when someone answsers. do not double post , please. but do back and see your old post and add more information to the same post , not a new one. (this forum is the worst for structure)
the best would be a real buick forum. trust me.
great the starter is good and battery charged.
so the key line is bad, i posted to your other post with a schematic
and the full testing of that key system.
did you discover this car has PASSKEY system yet? and is the PASSKEY lamp HAPPY? that be first.
back up one post. click the BILL link above. and bingo.
Jun 06, 2014 | 1996 Buick LeSabre
I have a 1994 Buick roadmaster , I have a no crank no start issue, the car has a new battery and I changed the starter just in case, however the car still won't start! I read about the security feature...
I am truly stumped!! Help!!! ???? It's not that difficult if you know how to test electrical circuit's using a wiring diagram an a DVOM - digital volt ohm meter . Free wiring diagrams here http://www.bbbind.com/free_tsb.html
Enter vehicle info. year , make , model . under system click on engine ,then under subsystem click on charging system . Click the search button ,then the blue link . Looking at the diagram on the left , i see the ignition switch ,the crank fuse in the I/P fuse box, the theft deterrent relay an the starter solenoid . Using a voltmeter or test light check for B+ voltage at the S terminal on the solenoid while someone tries to start the vehicle . If no light or B+ voltage ,back track to the relay , Test for B+ voltage at pin's 30 & 87 while cranking . If you pull the relay out of it's socket an look on the bottom or side you will see four set's of numbers 30 & 87 and 85 & 86 . You could just take a piece of wire ,heavy gage 12 . Jump 30 & 87 . If the heavy gage battery cable to the starter is good it should crank the engine .
Starter Voltage Drop
How to Diagnose No Crank No Start Issue Nothing or only Click When the Key...
Dec 27, 2017 | 1994 Buick Roadmaster
Engine turned off suddenly and wouldnot start
Several things coud cause this .. none good...
1. Bad gasoline (water in gas)
2. Head gasket blown.
You can check the "wiring" (spark):
Need another person to help
1. Set parking/emergency brake.
2. unplug one cable from a spark plug and place it on the motor or other metal
3. while "cranking" the engine, look for spark at end of sparkplug wire. It will probably spark... not an electrical problem
4. Don't touch the wire while the ignition is on .. it will shock you!
Use a can of "complete fuel system cleaner" not just an injector or throttle body cleaner. AutoZone ($9).
Hope this helps!
Sep 06, 2009 | 1990 Honda Civic
MSI K8N Diamond Plus Won't POST
If you can't get your board to POST (power on self test), this means a component in your system is failing to be initialized. Try a bare bones configuration, use onboard video, keyboard only, no mouse, remove anything non-essential. This includes extra hard discs, only have your OS hard disc plugged in and powered on. Add components one at a time, booting after each one is added. This will rule out a possible component issue. That being said, the component failing the initial check could be an onboard component, one that is soldered or integrated into the MB. Additionally, check if you are running DDR500 memory; the 1.1 version BIOS has this fix: "Fixed BIOS reports incorrect message for DDR500 during POST." If it is truly a BIOS issue, clearing the CMOS shouldn't do much; as CMOS just stores your settings that changed from the BIOS default. If you can get your system to boot, try upgrading your BIOS to a newer version only after a sequential rebuild is done.
Jun 07, 2009 | Intel Motherboard
Monitor shut off, no BIOS post, no keyboard or mouse lights, will not boot
Try another (Known good monitor). Or try you're monitor on another system.
Remove all memory except 1 DIMM. Double check all data cables (internally) & power cables. Remove the added video card. Try booting the system. Watch for the case LEDs to flash/blink, listen for hard drive spin up /cd-rom spin up. Lastly pull the battery & check with a volt meter. Bios battery should test no less than 3 volts. Post the correct MD rev.
Mike
Jul 22, 2008 | Intel Motherboard
Sony VAIO PCV-V200G PC Desktop Logo
29 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
