Question about Sony ICF-2010 AM/FM/SW Radio
LCD display invisible on Sony ICF-2010
The LCD display of my ICF-2010 is blank, or so I thought, until I noticed that if I hold the radio horizontally at eye-level, I can just make out the numbers on the clock and frequency display. But when I sit the radio upright and look directly at the display it appears blank.
Is there a fix for this, or is the LCD display basically kaput? The radio dates from 1986.
  • glenner Mar 09, 2008
    Found this elsewhere on the Internet and it worked: Clean Memory Battery contacts with fine sandpaper and put in new memory batteries. Display is much darker.
I found a posting that said this usually is a problem with weak memory batteries or a bad battery contacts. I replaced batteries and cleaned contacts and the problem was solved.
Posted on Mar 10, 2008
  • Ringbearers Apr 09, 2011
    Found your solution and it worked great for me. Now I'll go check the displays on the other 3 ICF-2010s that I own -- all probably have memory batteries that are beyond "shelf" life. Thanks again. Gordo
Buttons not working on Sony icf-cd7000
Hello
Unplug the unit and replug it after 5 minutes or so. Then Hold Down the CLOCK/DATE until a short beep sounds. If this beep sound cannot be heard, be sure that the internal circuit has some trouble, and has to be repaired. Normally, any other button get strucked, there will be no response with other buttons. OK.
Nov 02, 2011 | Sony ICF-CD7000 CD/MP3 Clock Radio (Black)
Trying to find a power adaptor for my sony icf 2010?Thanks Will
I can help with this but need more info..... Rod ( poikaa@yahoo.com )
May 13, 2010 | Sony ICF-2010 AM/FM/SW Radio
Radio does not function-will not operate at all. Is there someone who can repair Sony ICF-2010s?
I know time has passed.... I do repairs on SONY receivers. email me and we can go over the details. Rod ( poikaa@yahoo.com )
Mar 27, 2010 | Sony ICF-2010 AM/FM/SW Radio
I have a Sony ICF 2010 (for over 20 years) and when I turn it on, the only reception I get is on the FM frequencies (+ aircraft freqs). Thank you. Alex
Late answer on this.... There is a FET problem with older radios and this could be the problem. Static can "zap" the transistor making the radio deaf on receive in the AM modes.
Aug 24, 2009 | Sony ICF-2010 AM/FM/SW Radio
ICF 2010, no sound suddenly
If the radio does not work with headphone then the external jack for audio may have broken loose from it's soldered points. Simple re solder may make the repair. Beyond that it would have to be diagnosed by a technician.
May 28, 2009 | Sony ICF-2010 AM/FM/SW Radio
Sony ICF-7600D Radio side is dead
Getting ready to send it to ACT ELECTRONICS in US.
Mar 02, 2009 | Sony ICF-SW7600 AM/FM/SW Radio
Sony ICF 2010 Shortwave scan does not scan, it beeps.
It will not scan blank memories and it will not scan on search function till you specify a frequency range.
Rod
Jan 30, 2009 | Sony ICF-2010 AM/FM/SW Radio
Sony ICF2010 Scan does not work.
The SONY does not scan non programmed memory channels, you must have some programmed in.
SONY ICF 2010/SONY ICF 77/AM EXTERNAL ANTENNA JACKS BAD
The antenna jack is no longer available, these can be serviced but the unit needs to be sent out. I do this service, contact me .... poikaa(at)yahoo(dot)com
Jan 13, 2009 | Sony ICF-SW77 AM/FM/SW Radio
Sony ICF-2010 AM/FM/SW Radio Logo
443 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
