Question about Dell Inspiron 6000 Notebook
Screen problems?????????????? sometimes get a 2.5 inch horizontal band at the bottom of the screen, or past images of the previeous website when changing to another website.
  • 2 more comments
  • carpetboy Mar 10, 2008
    **. I have not updated my drivers, and I don't know what graphics card I have, I do believe it is integrated into the mother board.
    thanks for the information i have a ATI mobility radeon 9000 I will try to download the updated driver.
  • btfire911 May 11, 2010
    ok go to your display properties and click on the settings tab and where the display drop-down menu is it will tell you what video card you are using (i believe it should be mobility radeon x300) if that is the case go to the website i previously posted and it will gove you step by step instructions on how to update your driver
    have you updated your drivers? and by update, i mean update from manufacturer, not from dell support. what graphics card are you using? if you have ATI card here is a website to get you started on updating drivers. Its a long process because dell does not allow ATI to offer updates.http://www.driverheaven.net/modtool/
    Problem Solver:
  • 7 Answers
Heres a common issue in the field. Of course you must always make sure you have the latest DELL BIOS version.
There is a device that controls the screen called an invertor. This sits in ths screen housing usually toward the bottom. Sometimes people close the lid and forget about the inkpen they were using. The fix in my six years in the field has always been replaceing the LCD.
Posted on Mar 10, 2008
Samsung tv model un50eh5000v Having horizontal blurring and repetitive images from 8 inches from the top to the bottom of the screen. Top is clear. All inputs and stations.
It sounds like you have a defective panel. It will be cheaper for you to replace the set. Hopefully the place that you purchased the boards from have a good return policy.
May 11, 2016 | Samsung Televison & Video
2 horizontal bands of negtative image
Hi there
Try replacing the electrolytic capacitors in the power supply section. I started with replacing (2) 860uf 180v caps just after the bridge rectifier and continued along the circuit. Some (15) or so capacitors later,it finally cleared the the horizontal bars and lines and the high pitched noise. It also fixed another intermediate problem of no video, when turning on the power.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as FixYa if it helps you.
Thanks
Dustin Ellse (BearWeb)
Jun 30, 2008 | Dell W4200 42 in. HD-Ready Plasma...
A horizontal band of green and red lines across the screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Type in the brand name to your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 17, 2015 | Panasonic TC-P46C2 - 46 Inch 720P Plasma...
Pink/Blue horizontal line on TV
Considering it is a 32 inch set and costs now under 300 dollars it may or may not be worth fixing.
To give an educated guess: either whatever it uses for an inverter board may be bad or damaged OR even the main board that processes all signal into or out to the screen may have either a bad connection(unlikely but possible) or be causing this.
A fatal issue could be something wrong in the screen unit (panel) itself.
I gather set is not under any warranty at this time.
Apr 05, 2012 | Televison & Video
My zenith lcd tv has horizontal black lines whih form a band about 3 inches wide across the screen, sometimes the band looks more like a dark shadow than lines other times the right side of the screen...
This is either 1 of 2 things, first it could be faulty panel tabs , in this case, there is nothing you can do and is unrepairable....2) you could take the back off the tv and you will see 2 ribbons going from your t-con board to the panel tabs (top center of tv) remove them carefully and reseat them. This is a common problem. Tv repair tech 15 years! Best of luck.
Dec 05, 2017 | Zenith Televison & Video
I have a Dell 17" LCD monitor with a horizontal band.
You would better served replacing monitor you can buy one for about $100-$120 dell if you lie has one for $99
Mar 01, 2018 | Dell Computers & Internet
Screen is not a true square: One verticle side shorter than other
Simply just manualy adjust the bottom of the screen by adjusting the distance by an inch or so.
Depending on what screen you have adjust it from behind or vith a thin thread
May 19, 2009 | Optoma HD70 DLP Projector
2 Problems - Small white horizontal line. Black Lower part of screen
Try changing the TV's display format from widescreen to fullscreen.
Sep 21, 2008 | Samsung SPN4235 42 in. Plasma HDTV
RCA F27442 27" TV - topper half screen stripped and bottom-half is still good
check for bad c14505 220mf.
or u14501 vertical output ic.
Nov 04, 2007 | RCA F27442 27" TV
Dell Inspiron 6000 Notebook Logo
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
