Question about Sony PS-LX250 Turntable
Sony PS-LX250H speed problem
I have a PS-LX250H that is about 8 years old, and has been unused for about three years.
i have to set the speed at 33 rpm to play a 45 rpm record, and a 33 rpm record when set on 33 rpm plays too fast. basically, the motor is running too fast. any idea why this is happening?
  • skyedog Apr 10, 2008
    The turntable spins too fast for the 33 setting, and too fast for the 45 setting. Any help? Thanks.
  • Anonymous Nov 09, 2008
    worked great for years - not sure if the kids did something, but after not using it for about a year, i went to play some LPs and the 33 speed is too fast.
I have a different Sony model (PS-LX-150H) that had a similar problem. I hadn't used it in awhile, and then when I did, I noticed the speed problem.
IF your PS-LX250 is like my PS-LX150, there are small speed adjustment screws accessible from the bottom of the unit. On mine, the two adjustment screws were labeled - one for 33rpm, the other for 45 rpm. Basically I just fiddled a bit with them using a very small precision screw driver until I could verify that I had reached 33 rpm (I used a stopwatch and literally counted the number of rotations/minute after making adjustments.)
Now it sounds right!
Posted on Feb 02, 2009
    New Friend:
This is the correct answer. Don't mess with the SW, LIN, or RET screws. You'll just screw it up. Use a jeweler or eyeglass style flat blade screwdriver and just slightly adjust the 33 or 45 screws. First, unplug the unit. Then, place the screwdriver in and feel around until you feel the blade engage. Make very small adjustments plug it in and play a record till it sounds right to you.
Posted on Jul 13, 2013
  • S. Groover Jul 13, 2013
How do I adjust the speed of a Sony LX250H turntable? The answer is not in my manual.
Presumably you mean correcting the speed to play 45 and 33 correctly?
Some turntables have the speed control(s) as a preset(s) built into the base on the underside of the unit. Often covered with a sticker. You simply remove the sticker and stick a small screwdriver in the thing and turn it.
Others have the preset inside on a circuit board, got to by removing the bottom of the turntable. Others have it built into the motor itself.
You should replace the belt first if the speed is slow on both 45 and 33, before adjusting the motor speed.
Apr 25, 2014 | Sony PS-LX250H Turntable
Grundig 4400 / Audio Techinca T4P Turntable spins at 35 RPM instead of 33 RPM
I think you mean 45 rpm?
It sounds like you have got the belt in the wrong position. Try adjusting the position of the belt by experiment. Or you could look up the correct way to set up the belt.
Jul 28, 2013 | Audio Players & Recorders
Turntable runs at 45 spped when set to 33 1/3 and at 78 speed when set at 45 speed
This sounds like the belt, if it is a belt drive model, has slipped to the wrong position on the motor post. You should be able to set it back up right. As long as the belt is not worn out.
Any recordings at 45 can be converted to 78 using the software. There should be an option to do this. This applies to all other speed settings too. You can convert 33 to 45 etc using the same thing.
Jun 02, 2017 | Sony PS-LX300USB Turntable
Sony ps-lx250H turntable only spins at 45 RPM
It seems to me that the switch has broken and isn't moving to the 33 setting. You just need to find the switch. Without seeing it I can't say what type it is so I suggest looking for it under google image search. Try "micro switches" or "leaf switches". You can also look try Maplin, or the Curry's Partmaster website.
Nov 11, 2011 | Sony PS-LX250H Turntable
I have a Sony PS-LX210, and need to adjust the speed. Going by the music it's played, it's just a bit slow on 33 RPM (I don't know about 45). I find no external adjustments, but there are some trim pots...
According to anything I can find online, like any decent turntable it has a manual pitch control. Unfortunately, I can't find a manual or even a good close-up picture.
This is the best one I've found.
http://www.neowin.net/forum/topic/652451-post-your-vintage-tech/
What's that rectangular slider-looking thing at the front right edge?
Feb 10, 2011 | Sony PS-LX250H Turntable
My Sony PS-LX250H Turntable suddenly started playing records too fast for both 33 and 45 speeds. Any ideas on how to fix???
If this is a belt drive then most of these speed increases are caused by the belt being in the wrong position. The belt could be faulty and my need to be replaced. Otherwise it could be due to a power supply problem, such as a faulty regulator to the supply of the motor. A check on the voltage to the motor will determine this. Assuming you know what the correct voltage should be! Of course with luck it will be higher than the motor is supposed to run at.
Feb 02, 2011 | Sony PS-LX250H Turntable
My audio technica turntable is playing records too fast. how do i fix this?
there are two small holes under the unit labeled 33 and 45 that control speed. im guessing youre mainly playing lps so use a flathead jewlers screw to adjust the 33 setting until you get the right speed
Jan 08, 2011 | Sony PS-LX250H Turntable
My Sony PS-LX250H turntable will only spin at 45rpm. When i push the speed button for 33 it doesn't change. i also sometimes have to give the deck a little push to get it to spin.
I have the exact same problem for the same model. Only spins at 45 and I sometimes have to kick-start it. I tried de-activating the switch (so that it's not making a connection) and therefore in the 33 position but that does not help.
Dec 14, 2010 | Sony PS-LX250H Turntable
My Sony PS-LX250H is all of the sudden playing too slow with a 33
Not sure what made it happen all of a sudden, but you might want to check out Mocamom1 's question related to PS-LX250H speed & the attached solutions. You may just need to adjust the SW screw on the underside of the unit (worked for mine that was playing everything at 35 1/4!)
Jun 27, 2009 | Sony PS-LX250H Turntable
LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Nov 29, 2008 | ION Audio TTUSB10 Turntable
Sony PS-LX250 Turntable Logo
3,518 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
