My Memorex mvdp1102 comes on for 2 seconds and shuts off. The "Open" light comes on for those 2 seconds even through the cover over the dvd is closed
  • jllando Mar 29, 2008
    MVDP1102 - When I turn it on, open cover signal shows with cover closed and turntable never starts. Unit shuts down after 5 seconds! P.S. screen never lights up when this occurs.
Possible suggestion:
http://www.memorexelectronics.com/html/support_search_faq_step3.php?FAQID=151
Check the switch for use with an external monitor.
(I don't have one, I just saw this.)
Posted on Mar 13, 2008
Power light doesn't come on
Check the adaptor as this can usually fail, if its not the adaptor try the battery and if it doesnt power up still then its an internal transistor thats shorted.
Nov 05, 2009 | Memorex MVDP1102 Portable DVD Player
My dvd battery wont...
the charger or the battery is gone. got warranty?
Sep 12, 2009 | Memorex MVDP1102 Portable DVD Player
Portable dvd wont play movies
I was getting the blue screen and open, then a black screen after loading the disk. If you have the AV switch in the wrong position, it will do the same thing. My kids must have moved it on me.
Apr 10, 2009 | Memorex MVDP1102 Portable DVD Player
Won't play, says open even when the lid is closed.
Well , from your bumping experiences , I would say the latch/hook/switch that tells the player that its lid is closed is loose.Carefully close your lid and see the parts that touch and you will find the latch/hook/switch.Manually play with it (or tape it down!) for a quick fix.For a more permament fix you might have to open it and fashion (or buy) a new switch.
Dec 18, 2008 | Televison & Video
DVD player - Memorex DVDP 1102 - "NO DISC" message
ok get a cotten swab and put a little alchohol on the tip now gently rub over and around the casing of the lens...gently trying to lift it back up into posistion (your son pushed it down into its casing....You might also try droping it upside down on a soft couch pillow to dislodge the lens (This method has worked for me ) ps its just a hair!
Dec 11, 2008 | Memorex MVDP1102 Portable DVD Player
Stuck in Standby
FOr the MVDP1102 Memorex 10.2 portable DVD Player:
I had the same problem. If you open the disc door there is suppose to be a plastic arm underneath the right side of the lid which when you close the lid, with the movie disc in, this arm will press through to a switch inside the machine and that will set the player in load/play mode. Memorex did not have parts for this player, so I unscrewed the bottom and one black screw inside where the lazer light is. This will allow you to handle the bottom back side and see underneath where the screen is you will find the switch. I rigged up a pin wire and did some small drilling. I was successful, but it wasn't easy. Most times I just fail and toss. I thing my son just open the disc door too much and that's how the piece was broken.
Apr 05, 2008 | Memorex MVD2042 DVD Player
I HAVE A MEMOREX (MMP8640A) AND IT WON'T COME ON.
myn wont even turn on ..it was just like charged half full!
i had it plugged inot the computer ..and it wa turned on so i turned it off ..like usually when i plug it in it makes a noise then it loads and a list of options comes up now nothing ..before when it was connected ..yesterday.. the screen said do not disconnect now nothing is on the screen ..its plugged in right now .. i tried going 2 windows media player to sync some music but it says nothing is connected!!!
good luck
Feb 21, 2008 | Audio Players & Recorders
reinstall the firmware, following the next steps:
Download the firmware from Memorex site (www.memorex.com) but use the firmware for MMP8620 NOT the one for MMP8640, otherwise you will finish with your player starting with a blank screen.
FIRMWARE UPDATE INSTRUCTIONS FOR MMP8640.
1. Make sure the unit is powered off.
2. Plug one end of the USB cable into the USB port on your PC.
3. Click on the start button on the lower left hand corner on you PC.
4. Highlight Programs, on the drop down page highlight Memorex Aptitude Digital Audio Player.
5. On the drop down window click on “Memorex Aptitude Firmware Download”.
6. Memorex Aptitude Firmware Download Window will open with a notice “PLEASE CONNECT
DEVICE”.
7. Press and hold down the MENU button on the MP3 player at the same time connect the other end of the
USB cable to the USB port on the player.
8. Firmware Download Window will begin initializing.
9. Keep holding down the MENU button on the player until the Firmware Download Window displays
“READY”.
10. Release your finger from the MENU button.
11. In the Firmware Download Window, put a check mark beside Format Data Area.
12. Click on the START button in the Memorex Aptitude Download window.
13. Wait until the screen says “firmware download complete”.
14. Click on the CLOSE button.
15. Disconnect the USB cable from the player. The player will turn on by itself. If the player doesn’t turn
on automatically, press the power button.
Please note if an ERROR message appears on the display of the player when the player powers on, you
need to repeat steps 1 - 15.
WARNING: DO NOT INTERUPT FIRMWARE DOWNLOAD PROCEDURE
Hope it helps, I solve the problem just like this.
Jan 08, 2008 | Memorex MMP8565 MP3 Player
Televison & Video Logo
91 people viewed this question
Top Televison & Video Experts
