Question about Kirby Generation 3 Bagged Upright Vacuum
Kirby 3g I have a kirby 3g about 4 yrs old and when I push it forward it just takes off, how and I adjust the tranny to control it better. Jeff
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 112 Answers
Here's a link on how to adjust the transmission on the kirby...the kirby pictured is a G4 or 5 but it is the same transmission as the G3
http://www.greatvacs.com/Kirby%20Transmission%20Adj.shtml
Hope this helps!!!
Posted on Mar 27, 2008
Kirby g10d, I shampooded the carpet then put it back together and it wont start 4/12 yrs old used approximately 50 times. Any ideas?
Make sure the emptor at the. Bottom of the bag assembly is turned all the way clockwise. It pushes in on lever on the switch. It won't run if the lever is not pushed all the way.
Jan 31, 2015 | Kirby G10 Sentria Vacuum Cleaner...
My Sentria always runs in the drive mode and it is so fast it seems out of control. If I push the neutral pedal it stays in drive. I can push it the regular way when it is turned off, whether the pedal is...
I sold vacuums for almost 20 yrs and the Kirby gets lots of complaints. The transmission that it has in it breaks as your has and they are costly.The best thing to do would be to take the maching to the local vacuum store(eg. sewing and vacuum are often in the same store).Bring it to a used vac store and they all repair kirby and thay can give you the best advice. I dont recommend going to kirby as thay will spend four hours at your house trying to sell you a newer model and they have not changed enough to get another one in hopes it will be betrter. Good luck
Oct 07, 2010 | Kirby Ultimate G Bagged Upright Vacuum
I have a senteria about 4 yrs old. it bounbes
Check the wheels and axles for damage or bent shafts. Remove the bottom cover and inspect the brush roller for damage--breakage of the roller, bad or broken end bearings, missing brush sections, or something stuck to the roller like a wad of gum or something. Hope this helps!
Dec 26, 2009 | Kirby G4 Bagged Upright Vacuum
Can't seem to pick up small items like lemon pips with Kirby G5. It just runs over them or pushes them backwards and forwards.
It sounds like your belt is broken, OR your beater bar is rotating but has not been adjusted downward to reach the carpet pile. Check by running the vacuum and looking to see if the beater is moving.
Jun 17, 2009 | Kirby G5 Bagged Upright Vacuum
I have a Kirby G5 vacuum that when light pressure is put on the handle it moves forward but in a jerky movement. Like the drive is engaging and disengaging. If you keep forward pressure on the handle the...
I hope adjusting position of the position of the "pivot spring assembly" will help. but you may have to disassemble entire slide assembly to clean it up if it still does not work smoothly. See instructions HERE (adjustment is explained in step #6). Try to "play" with screws #4 and if it does not help - clean slid.
Good Luck
Feb 28, 2009 | Kirby G5 Bagged Upright Vacuum
G-4 Kirby self propel unit works in reverse but not foward
Jon,
Here is a helpful link to use to adjust the tranny. About a 7 on the difficulty level.
Marci
Dec 10, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby ultimate g
Vibrating – that usually happens on some short fiber or very dense carpets. When nozzle goes against the carpet fiber Kirby starts jumping. Try vacuuming the same place while facing opposite way.
Belt – red arrows means DISENGAGE. When you install the nozzle on the Kirby unit while green arrows match you will not be able to turn it on red. You must follow sequence (starting from nozzle off the Kirby, green arrows match, Kirby front lifter all the way up by pressing one of the pedals):
1. Turn Kirby knob to match red arrows. You will feel some tension and hook inside of the nozzle is supposed to catch the belt and stretch forming a loop for the Kirby shaft.
2. Put the nozzle on the Kirby and lock it on with the latch.
3. Twist the knob back to match the green arrows. YOU ARE DONE
Go to GoodVac.com Kirby vacuum online manual. There are some small details that you may want to pay attention to if you have removed the brush roll to install a new belt. Also there are some pictures that will help you understanding the process.
Sep 27, 2008 | Kirby Ultimate G Bagged Upright Vacuum
KIRBY 5 PROBLEM
make sure the lever it the very back of the machine is in the on or drive position, make sure the height is up high enough ( the higher the better as long as it is still cleaning - lower is not better ) and change the belt even if it isn't broken they can stretch out in less then a year of use.
Sep 19, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby Generation 3 Bagged Upright Vacuum Logo
295 people viewed this question
Top Kirby Vacuums Experts
Jim Parker
Jim Parker
Richard Agent
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
