Question about Canon imageRUNNER 400S Copier
Problem on GP405 coppier
My machine some times diplay Error codes 301, 100, 220. then the copy are printed in vertical lines are print. please give assist against this problem.
  • Anonymous Jul 22, 2008
    yes
  • 86 Answers
E220
The lamp intensity does not
exceed a specific value
within a specific time after
scanning operation starts
(following lamp activation).
• The lamp remains off for 10
sec when it should remain on.
E301 is
The output of the intensity
sensor drops below a specific
value while the lamp is on.
E100 is
The BD signal is not
generated during image
formation (2nd sheet pickup
and later).
• The BD signal cycle has
deviated.
• The BD signal is not
generated within 2 sec after
the laser has turned on (at
time of 1st sheet pick-up).
To have all three come up at differant times and intermittantly
I suspect the front door interlock switch is not being made properly or needs replacing
If you require more help please contact me by reposting
Thank You
Posted on Mar 11, 2008
For my past experience these is due to the ccd unit faulty
Posted on Mar 08, 2009
Canon gp405 erro E-100
Posted on Feb 10, 2009
Sir, My machine is Canon GP405, its showing me error code E100-0002 while i making copy, after paper pickup its throwing this error code. Please help me.
This *may* be of help.
E100 e100 0001 e100 0002
Before doing anything else, try unplugging the machine, leave it unplugged for a half hour (overnight?) and see if it works OK afterwords.
Dec 26, 2017 | Canon Office Equipment & Supplies
Error sc 329
This is for a Ricoh copier. You did not indicate machine.
SC 329: Laser Beam Pitch Adjustment Error
The LD unit home position sensor does not detect an on condition while changing the LD unit position for correcting the LD position or changing the DPI.
Instructions from the Service Manual below...
5.4.3 LASER BEAM PITCH ADJUSTMENT
There are two laser beam pitch adjustment procedures: one for 400 dpi, and one
for 600 dpi. These adjustments use the following SP modes.
· SP2-109-1: Laser Beam Pitch Adjustment - 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment - 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting - 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting - 600 dpi
· SP2-902-2, no.12: IPU Test Pattern - Cross Stitch - 400 dpi
· SP2-902-2, no.13: IPU Test Pattern - Cross Stitch - 600 dpi
1. Perform SP2-109-8 (Beam Pitch Data Reset).
2. Input the value for 400 dpi that is printed on the LD unit into SP2-109-1.
Use the value printed after "P" on the new LD unit as shown below.
NOTE: Do not use values printed after a "V".
(These value numbers are on a sticker inside the machine with a UPC code on it. The numbers are just under the UPC barcode. And example number looks like this: "15980300151P: 120, 172", so the example 400 dpi value here is "120".)
3. Press the "Enter" key.
4. Perform SP2-109-3.
5. Print the 400-dpi test pattern onto A3 (11"x17") paper using SP2-902-2 no.12
(cross stitch). (See Service Tables - Test Pattern Printing - Section 4.2.3, pasted below.)
6. Write the value of SP2-109-1 on the test pattern which was input at step 2.
7. Change the value of SP2-109-1 and print another test pattern, repeating steps
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. "48", "96",
"192", "240").
8. Check this test pattern. If the laser beam pitch is not correct, the image looks
like a black vertical stripe pattern.
NOTE: If the laser beam pitch is correct, the vertical stripe is not so noticeable.
If the value is not correct, the vertical stripe pattern is darker.
9. Adjust the laser beam pitch position until the thin lines are of uniform thickness
(no striping effect should appear on the printout), doing steps 2, 3, and 4. (In
step 2, input a value which is estimated to be correct, then do steps 3 and 4,
then if necessary go back to step 2 and try another value.)
10. After adjusting the laser beam pitch for 400 dpi, adjust the laser beam pitch for
600 dpi, using the same procedure as for 400 dpi (use the SP modes for 600
dpi).
4.2.3 TEST PATTERN PRINTING (SP2-902)
NOTE: Do not operate the machine until the test pattern is printed out completely.
Otherwise, an SC may occur.
1. Access the SP mode which contains the test pattern you need.
2. Press exit, then touch the "Copy Mode" key on the operation panel to access
the copy mode display.
3. Select the paper size.
4. Press the "Start" key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the "SP Mode" key.
Reset the test pattern to 0.
6. Exit the SP mode.
Test Pattern Table (SP2-902-2: Test Pattern Printing - IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
6 Vertical Lines (256-greyscale) 13 Cross Stitch (600 dpi)
7 Vertical Lines (1-dot)
8 Vertical Lines (2-dot)
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
12 Cross Stitch (400 dpi)
Test Pattern Table (SP2-902-3: Test Pattern Printing - Printing)
No. Test Pattern
0 None
1 Vertical Line (1-dot)
2 Horizontal Line (1-dot)
3 Vertical Line (2 dot)
4 Horizontal Line (2-dot)
5 Grid Pattern (Single-dot)
6 Grid Pattern (Double-dot)
7 Alternating Dot Pattern
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
12 16 Grayscales (Horizontal)
13 16 Grayscales (Vertical)
14 16 Grayscales (Vert./Hor.)
15 16 Grayscales (Vert./Hor Overlay)
16 Not used
17 Horizontal Line (1-dot)
18 Grid Pattern (Single-dot)
19 Grid Pattern (Double-dot)
20 Alternating Dot Pattern
21 Blank Page
These adjusments listed in the manual require removal of a service panel and mechanical adjustment of the laser mounts, so it should be done by a qualified technician.
However, these test procedures can indicate whether or not this is the problem with your printer.
Sep 05, 2012 | Office Equipment & Supplies
Infotech is 2127
"I want, I want, I want".....I bet you do!
First, learn how to ask for things nicely ....but repair manuals are NEVER part of the deal
Quit messaging me!
Nov 27, 2011 | Ricoh Office Equipment & Supplies
Copying problem
Vertical lines on the copy usually indicate a dirty drum or Corona wire. The Corona wire should be cleaned each time you replace the toner cartridge. This is done by moving the Corona tab back and forth across the wire several times to clear it of debris. You may also want to check the drum for debris. Holding the copied page to where it feeds out and lining up the line or mark on the page will give you an idea as to where the dirt may be. Best of luck with your printing issue.
Greg
Nov 04, 2009 | Brother IntelliFAX 2800 Laser Fax
Canon GP 405 print error
The network card (ethernet pcb in the copier) has a fault, replace it.
May 05, 2009 | Canon imageRUNNER 400S Copier
My Canon IR c3200 started to print olors out of focus... I read 3 manuals through, transfer belt is clean, auto calibration process gives nothing, horizontal lines printed fine but colors misplaced in...
you have miss regrestion there are several ways to correct this process 1-go into service mode -function-clear-dc con -ok then take machine off unlug from wall outlet replug turn machine on 2-replace your itb assy. 3-there is another way but you have to be next to the machine and fimilar with second level service mode.
Oct 21, 2008 | Canon imageRUNNER C3200 Copier
Muratec MFX 2500 copies have lines
need to be more specific, printing have both hor. and vert. lines aas well as copying ???
Dec 18, 2007 | Muratec MFX-2500 Plain Paper Laser Fax
Lines show on printed copies from Muratec MFX 2500
Probably a bad cleaning blade in the toner cartridge or a dirty charge wire.
Look for a small slider on top of the cartridge.
Canon imageRUNNER 400S Copier Logo
470 people viewed this question
old marine
old marine
