Hard drive not recognized
I have a lacie d2 80gb firewire hard drive and it isn't getting recognized on my windows xp computer. what do i need to do?
  • 27 Answers
Is it detected in the Disk Management wndow?
To access Disk Management: Click Start>Run and type in DISKMGMT.MSC and click enter.
If it is detected there right click on it and select Partition and after partitioning the drive you can format by right clicking on it again.
Good Luck!
Posted on Mar 09, 2008
I had 4 LaCie 2TB Big Disk Quadra, Item 301343U. They are connected to a Nitro 8-PORT FIREWIRE 800/1394B PROFESSIONAL (N8PFW8HR) hub. The hub is connected to a LaCie Firewire 800 PCI card. I am running...
Let's not take this as a solution so much as an intuition. I believe you may have run up against a limit of physical disk space that XP can administrate.
DO me a favor and don't give my rating a thrashing if I'm wrong.
Best Regards,
Marcus
Sep 23, 2010 | LaCie Big Disk Extreme with Triple...
Will not mount on a Mac Book Pro 17"
try to connect lacie to windows base computer if it work, there a problem, with your mac book check if device manager recognize lacie drive if not check for the fire wire port.
Apr 10, 2010 | LaCie 1TB D2 HD Quadra FireWire 400 Hard...
Macintosh computer not recognizing the LaCie external hard drive
1. If you have another firewire device test this device with the same firewire cord you are currently useing for the LaCie. (if there is no reasponse form the other device then it is the cord it's self) If not then 2. Check the Leads on the back of the LaCie where the firewire plugs in if the copper looks tarnished use a ear swab dipped in Lime Away or CLR to clean it then wait for it to dry and try the cord again. 3. if these physical connections are in good connection with each other and the firewire in port on your computer and on the LaCie are good then. Run a "Permissions" verify and repair through the disk utility program on your Mac with the LaCie turned on and plugged in.
FINALLY if none of these options repair the LaCie you may have to open the LaCie up and check to make sure the soldering from the firewire to the chip set is still in tact. I hope this helps Happy Macing.
Mar 28, 2009 | LaCie Design by F. A. Porsche 160 GB Hard...
Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Jan 03, 2009 | LaCie (300728U) 250 GB Hard Drive
Having Problem with both LaCie hard drives being recognized on both macs
Try to connect to another computer, and see if it recognizes the drive. If Not, you can dismantle LaCie and take the disk out.
Connecto your disk to another external box (USB or Firewire) so you can have access to you data.
Jul 04, 2008 | LaCie (300740) 160 GB Hard Drive
Lacie 1tb hd
You can try to boot up with Linux LIVE cd and plug on the external HDD.
Apr 24, 2008 | LaCie d2 Extreme 250GB External with...
Two units conflict when connected thru Firewire 400
Windows XP and most pcs running it does not natively support firewire,as it was developed by Apple computers. Most Firewire ports on PCs are 4 pin. Your PCI card ( and I take it, its a desktop youre referring to ) should have a 6 pin connection. Firewire connections also have a 7 watt supply via the bus. You may need to open the computer and see if the molex jack on the card is being powered by your computers power supply. Two firewire drives, especially the power hungry Lacie quadras, may be to much consumption for the card. Hope this helps.
Sep 23, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie FireWire drive
I would seek out the latest drivers for the card in addition to checking to see the firewire card is properly installed. I would test the cable with another or ports. The D2 has a various array and combination of Firewire ports on each model. Also, try bringing the drive to another computer, to eliminate all other variables. Always of course, properly eject external hardrives and wait for confirmation whenever disconnecting it from the computer, and allow the drive to spin down before turning it off.
Sep 09, 2007 | LaCie (301146U) 320 GB FireWire 400...
Computers & Internet Logo
62 people viewed this question
Alun Cox
David Payne
David Payne
