Laptop screen after unplugging the harddrive on my sumsung v20 the screen does not work why is this
    Problem Solver:
  • 16 Answers
Did you unplug the 'tower', or did you remove the hard drive from your computer? In either case, the monitor would not be affected. I suggest plugging everything back in where it was, start from scratch, and see if your monitor works then.
Posted on Mar 09, 2008
Samsung sens v20 laptop power on but no display
Any sound? Does the HDD led blink during start-up? Can you hook it up to a external display? If so, what is on the screen?
Nov 27, 2013 | Samsung V20 XVC 2400 Notebook
I have come across this issue before. I believe it was with a dell or Gateway laptop. The screen had been stepped on. I wanted to check the computer out before I replaced the screen. I connected an external desktop monitor. It worked fine. You just have to hope that the dual monitor feature is enabled. There's no way to do it without a monitor or active screen. I hope that helps.
Feb 20, 2011 | Samsung V20 XVC 2400 Notebook
My NC10 netbook works normaly until i try to run it with the power cable plugged in ...the screen goes blank (white)...unplug the power and it runs OK. roger.
first thing i to check psu model specs,(should be on sticker on psu) is as supplied with your model(manufacturers site)
Sep 11, 2010 | Samsung V20 XTC 1800 Notebook
Blue screen on Laptop
I'm not going to state this is going to cure your problem, but here are some things you may wish to try;
1.Remove the AC adapter if plugged in. Remove the Battery.
Open the Memory Compartment door, and remove it.
Take the ram memory module, (Stick), out. If you have more than one, remove them both.
Now reinstall them/it. Reinstall the Memory Compartment door.
2.Remove the Harddrive Compartment door. Make sure the harddrive is plugged in tight. If you look, there is a rectangular shaped part on one side, in this compartment, that the harddrive plugs into.
This is a connector. (Actual name is Interface)
Push the back, (Opposite side of the connector), of the harddrive, to assure that it is fully seated in the connector.
Reinstall the Harddrive Compartment door.
Reinstall the Battery. Plug the AC adapter back into the laptop. Plug the AC adapter, (Charger), into the surge protector.
(Advise always unplug the AC adapter from the surge protector first, then from the laptop. If you do not, there is a chance of a voltage spike)
WAIT 1 minute, then turn on the laptop.
The Ram Memory can become unseated very easily.
The Harddrive has a metal frame around it, and the frame is attached to the main body of the laptop, with a scre-w, or scre-ws.
Still may be a chance, that the harddrive can become partially unplugged from it's connector.
Dec 25, 2009 | Office Equipment & Supplies
My v20 screen stays white as it tries to boot up
did you sort this problem out with the white screen mine is doing the same
Sep 24, 2009 | Samsung V20 XVC 2400 Notebook
The Samsung V20 Notebook doesn't have screen Output after Start. One button clip of the keyboard button --> is missing. Is there a dependance between keyboard function and screen?
no, but if it got knocked hard enough to mess up the keyboard there is a good chance that something has happened to either the gpu or the screen itself as well.
Aug 14, 2009 | Samsung V20 XVC 2400 Notebook
Samsung v20 display keeps going i have changed the screen cable
sounds like your new screen cable is either loose or faulty.i had same problem and was only after i had removed keyboard and ensured cable was tightly connected did i solve the seems to be a design fault in the samsung v20
Jan 24, 2009 | Samsung V20 XVC 2400 Notebook
Hi, i have a samsung v20 laptop.2 questions...
I have a Samsung V20 for many years and I know it doesn't support a wireless connection built in. But if you connect a USB like myself you can have access to the internet wirelessly. The flikering on the screen are you sure you haven't got a screen saver switched on, you may have it set to a clear black screen and like you say have to tap the keyboard and it comes back to life. It may also have hibernation switched on which will automatically turn off the screen have so many minutes you can change all these setting by right clicking on the desktop and selecting properties and under the screen saver tab there will be a power btton you should see hibernation and other tabs across the top these can be altered to whatever you want.
Hope this of use.
Dec 05, 2008 | Samsung V20 XVC 2400 Notebook
Screen fault on samsung v20
screen tube or inverter board faulty.
change the inverter board, then replace the CFL tube.
Or replace the whole tft screen.
Mike @ Compurepair.
Jul 09, 2008 | Samsung V20 XVC 2400 Notebook
No sound
check in your device manager that you have installed the driver successfully.
1st go to control panel
2nd click on system
3rd click on properties
4th...on device manager and select it and see the status!
Dec 08, 2007 | Logitech V20 Computer Speakers
Computers & Internet Logo
David Payne
David Payne
