Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
I have a Whirlpool Gold side by side frige Model # GDYHA Ice maker stopped working tried to troubleshoot it but still does not work...Have any idea how to fix it. Thanks
  • NotMuchHelp Mar 12, 2008
    I've got a similar model (GS6SHEXNB00), and have had this issue twice in 18 months. My water inlet line seems to freeze solid (freezer set to "2" setting).
    Workaround has been to remove frozen foods, then unplug refrigerator and leave freezer door open for 2-3 hours. Ice maker then works fine for another period of time.
    Consideration could be to set freezer to a slightly warmer setting to see if that helps without compromising food quality.
    Novelist:
  • 184 Answers
THE ICE MAKER CYCLES WHEN THE INTERNAL THERMOSTAT REACHES 10 DEGREES. IF THE FREEZER IS WARMER THAN 10 DEGREES, FIND THE REASON FOR THE WARMING TREND.
CHECK THE ICE MAKER TO SEE IF IT HAS ICE OR WATER IN IT. IF NOT, CHECK THE FILL TUBE TO SEE IF IT IS FROZEN. REMOVE THE ICE FROM THE FILL TUBE IF IT IS FROZEN OFF. IF THE FILL TUBE IS O.K., CHECK THE WATER VALVE ON THE BACK OF THE REFRIGERATOR TO SEE IF IT HAS GOOD WATER PRESSURE COMING TO IT.
ALSO, CHECK THE FRONT OF THE ICE MAKER BEHIND THE PLASTIC COVER. THE WHITE GEAR IS SUPPOSE TO BE HELD IN PLACE WITH TWO TABS IN THE CENTER OF THE GEAR. IF ONE IS BROKEN OR BENT INWARD, THE GEAR ISN'T MAKING CONTACT WITH THE CIRCUIT BEHIND IT. THE CONTROL MODULE WOULD NEED TO BE REPLACED. OR IT MAY BE JUST AS WELL TO REPLACE THE ENTIRE ICE MAKER.
Posted on Apr 10, 2008
I actually thought the same thing and than I cleaned out the bulk of the ice and it started working again. I do hope that this is all that is wrong with yours.
Jun 29, 2010 | Whirlpool GS5SHAXN Side by Side...
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
98978yi
May 10, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirpool gold Frige no light or temp display working
I am having the same problem does anyone have a solution?
Dec 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice Maker not working
Start by cleaning the condenser with a brush and a shop vac. Then get some nickleguard ice machine cleaner and wash the units plate's down going by package directions, then retry before calling a tech. It may start working but if it does not then it may save you some money by having the unit clean before the tech gets there. Ice machines are not a DIY repair. Sowwy
Mar 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold icemaker not working Model GD5SHAXLB02
problem with the heater or the thermastat of the ice maker
May 11, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
156 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
