Is the internal motor in a tsurumi 50pu2-15s
No it should be completely dry and clean, check the date of purchase, you will need to replace the mechanical seal and clean the motor,its not suppose to happen,
ask your tsurumi distributor if you want to repair it or ask about the warranty, i am assuming that the pump stop working so thats why you open it and ask about it here, make sure you dont see any burn (black) wire on the stator, if you see any burn on the stator its a bad news,
If there is no burn part,
If you have just a few dip of oil in the motor try to remove the oil as much as you can with (electric part (brake) cleaner) or rag and replace the mechanical seal,
If there is a lot of oil all over in the motor, if he is not already damage (Burn),you can try to wash the motor with clean or light soapy water and then let him dry for a few days or in a oven to make sure all the water is evaporate, then replace the seal and cross your finger,we can never be sure that this procedure will work due to this small electric motor, and you never know how long the motor might have run with liquid in it, but i say its 51% succesfull chance to work, if you have to pay someone to do that it might be worthed to buy a new unit.
Hope i help you,
Tsurumi Man
Everywhere, Always
