Question about Panasonic CT-36SX12 36" TV
TV DOESNT TURN ON ,I SWITCH PLUGS ,I TRIED TO TURN THE TV ON FROM THE TELEVISION ,CAN YOU PLEASE HELP.
  • Bluebird55 Mar 27, 2008
    My TV only comes on intermittantly and only when I push the front button. The red power light comes on, but no picture or sound. It can come on after I push the button on and off several times -- it's very unpredictable. However still has good picture/sound when on. I have tried plugging on and off, moving plugs, turning power strip on and off, etc. What else? Can't afford a new tv right now.
  • 373 Answers
Possible blown fuse or worse. If you attempt to change the fuse use the same amps that is in it.
Posted on Mar 16, 2008
TV will not switch on using the remote or manually on TV
Shorted circuit board components. Contact any service technician or the authorized service centre for LG, to confirm. Troubleshooting to plasma TVs is really a skilled work. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 16, 2014 | LG 50PX1D 50 in. Plasma Television
My television can't switch on
have you tried turning the tv off for 4 to 5 hours unplugging it
Jan 13, 2014 | LG 47LM6200 - 47" Class LED 3D Cinema HDTV...
Unable to switch from tv to cable Magnavox older 13
Have you tried accessing the on screen menu and maybe changing the input type to cable or even line in if you are using rca (red/white/yellow) plugs to connect the cable box to the television?
Oct 19, 2012 | Philips Magnavox 20MT133S 20" TV
42 plastma problem
Bad Capacitors in Power supply. IF doesnt help changing Capacitors Replace Power Supply Board
Feb 28, 2009 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
Unknown problem in my xbox 360
3 likely possibilities -:
1) The slide switch on the Video Lead plug (plugs into Xbox) is in the wrong place for where its attached to you tv.
2) you consul is set to PAL not NSTC or the other way around.
3) Wrong video refresh rate, should be 50 for PAL Uk 60 NSTC
Feb 12, 2009 | Microsoft Xbox 360 Console
LG 37in HD LCD tv not responding to any pressed buttons.
Based on your description, it appears that you have main board issues with your unit since your controls do not work and some inputs are NG.
Apr 24, 2017 | LG 37LP1D 37 in. LCD Television
TV won't turn on, red flashing light
Hold The Off Button for 20 sec should make clicking noise switch off at power and on again should be working
Nov 03, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Gateway flat panel TV will not turn on, the front on and off switch doesnt work at all and when you use the switch in the back the front on and off switch lights up but tv still will not turn on. Is
This sounds like you have lost your power supply. The more expensive the equipment, the more sophisticated the power supply that converts the power from your outlet into your television. There could have been a lightning strike that has disabled the tv. Or it could be a faulty outlet.
Before called for a technician, I recommend plugging the television into a different outlet. use a good quality extension cord if necessary. You may find that your outlet is not polarized correctly. If this does not work, please try our premium service or use our online listing of technician for a professional near you.
thanks and good luck :)
Jun 20, 2008 | Televison & Video
Samsung Projection TV
try unplugging the 3 wire plugs for the convergence yokes and try powering up the set. if it comes on you will need convergence ICs if it doesnt you will need a deflection board. let me know what you discover as I can help you with either problem
Jun 19, 2008 | Samsung HCN4226W 42" Rear Projection...
DVD doesnt work
Replace the laser on DVD player and that will resolve your problem. Todays lasers are not that reliable
Nov 29, 2007 | TruTech PLV16260 Television
Panasonic CT-36SX12 36" TV Logo
80 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
