Question about D-Link Rangebooster G USB Adapter (WUA2340)
Wireless connection manager
Ok when i try to open wireless connection manager i click on it no window pops up so i go to connection manager and it says wireless adaptor not found when my adaptor is working perfectly and im connected to internet
Remove all entries - run regedit delete all values from the adapter software and reinstall
Posted on Mar 10, 2008
Deleted some files from toshiba laptop and now I cannot connect to the internet
Try This:
Windows XP
Accessing Device Manager using Control Panel 1] Press the Start button. 2] Go to Settings, a new menu will pop out to the right. 3] Click on Control Panel. 4] When the control panel comes up, find the System icon and open it up. 5] When the System properties box opens, click on the Hardware tab. 6] You should see your 'Device Manager' button here. Click It.Expand your 'Network Adaptors' from this list, as shown below, using the [+] box.
Now locate your Wireless device, right-click it and select uninstall.
**If prompted, DO NOT uninstall your drivers also**
Now right-click your machine name at the top (I have blacked mine out in the above image for obvious reasons) and select the 'Scan For Hardware Changes' option from the menu.
Let it settle, reboot.
Windows Vista &Windows 7
Start>Right click Computer>Manage>Device Manager
Complete the steps from above to locate and uninstall Network Adaptor.
Jul 31, 2012 | Toshiba Satellite L305 Wireless Card...
My dlink 615 wireless routers connects fine and works for awhile. If I leave my computer for a bit, when I come back it isn't connected and doesn't connect again unless I shut down and restart
This should be related to power management setting or the wireless network adaptor present in the computer.
Access devicemanager (right click on mycomputer and click on Manage).
Click on device manager in the left side of this window
Right side click on the + sign besides network adaptors
Double click on the wireless network adaptor there
In the properties window click on the power management and disable power management for the card.
Now try checking if the issue is rectified.
Jan 03, 2011 | D-Link Computers & Internet
When I click the Zoom icon nothing appears. I
You can't zoom the Internet, it's a big as it's going to get :-) ha ha ha.
I usually set "Let Windows Manage my wireless connection" and use that on after-market wireless adaptors. This can also be done, maybe temporarily (?), by enabling:
Services > Wireless Zero Configuration Service
* You might try to uninstall the software ... then read very carefully the instructions that came with it. I say that because some hardware requires the software to be installed first! Others require the hardware first then the software. If you break the rules you COULD end up with problems.
Usually there's somewhere in the software of the adaptor to set it to let Windows (Wireless Zero Config) to manage it. This may not be the same in Windows Vista or Windows 7. Haven't tried yet ...
Nov 22, 2009 | Zoom Computers & Internet
Laptop cannot log on wirelessly . have Bigpond land line and an Optus wireless connection , neither will connect . Other computers in the house have no problem
Check if the wireless switch on the Computer is turned ON. Based on the Operating system, make sure that wireless is enabled in the supplied application, for instance, if you're using Windows Vista Operating System then make sure that wireless is enabled in Windows Mobility center.
Check in the Device manager whether the wireless adaptor has any exclamation mark. You can reach to the device manager by typing devmgmt.msc in the run dialog box and clicking OK.
Under the Device manger, click the plus sign beside the "network adaptor" and chekc if the wireless driver is listed and doesn't have any exclamation mark. If wireless driver is listed but has an exclamation mark then right click on it and uninstall. When prompted to delete then select yes and restart the Computer.
next visit the support site of the manufacturer to download the wireless driver compatible to the installed Operating system. Furthermore, you can run network diagnosis by opening Internet Explorer and click on the 'repair network".
Oct 20, 2009 | Toshiba Satellite A135-S2386 Notebook...
Unable to open pages...wireless connection is enabled
Windows WiFi Fix,
Windows Zero Wireless Configuration is one of the best programs to run a WiFi in Windows XP or Vista. Most of the other software packages that come with the different adapters have been poor at best in keeping a connection through Windows. Here is the best guide to get you back up and connected.
Windows XP:
Click Start
Right click on My Computer
When a window pops up click on properties
Click on the Hardware tab
Click Device Manager
Click the [+] next to Network Adapters
Find your wireless card and right click on it.
Click Disable
Windows may warn you that disabling the device may make it stop functioning.
Continue disabling the device.
Wait 30 seconds or so.
Right click on your wireless again and click Enable.
Exit the device manager.
Reconnect to your router.
You should now be able to connect to the internet.
Windows Vista:
Click Start Logo
Right Click Computer
Windows will ask you about opening Device Manager Click Continue
Click Disable
Oct 16, 2009 | Toshiba Tecra T9000 Notebook
Netgear wireless USB adaptor (WG112v2) compatibility problem
If your laptop has windows VISTA then perform the steps below:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
If it has windows XP then perform the steps below:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Sep 24, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I'm trying to set up a new wireless router but i get a messagw that says thw network adapter is not working
Open the Device Manager and check if the wireless device is listed under the "Network Adaptor".
You may also check in the "System Information" window for all the network adaptors installed and functional in the Computer.
Follow the steps given below to access the "System Information" window:
(i) Please press the Windows key on the Keyboard and then press the "R" key while holding down the Windows key to open the Run dialog box.
(ii) Then, please type "msinfo32" in the Run dialog box and click OK to open the System Information window.
(iii) In the left pane, click on the plus sign next to the Components then on the Network adaptors. This will display all the installed and functional network adaptors in the right pane. Check if wireless adaptor is listed.
If the wireless adaptor is not listed at any of the places then you may try restarting the Computer and reinstalling the wireless driver.
If the Computer still shows the message then the issue may be with the wireless adaptor.
Sep 23, 2009 | Dell Inspiron 9400 Notebook
My wireless button does not work on compaq nx7010
Press the Windows key on the Keyboard and then press the "R" key while holding down the Windows key to open the Run dialog box.
Then, type "msinfo32" in the Run dialog box and click OK to open the System Information window.
In the left pane, click on the plus sign next to the Components then click on the plus sign next to the Network.
Under the Network, click on the Adaptor to view the information regarding all the network adaptors functional in the Computer.
You can view the Network adaptor's information on the right pane. On the right pane, check whether the wireless adaptor is listed or not.
Furthermore, you can check in the Device manager under the "Network Adaptor" category whether the wireless adaptor is listed.
If the wireless adaptor is not listed in either of the windows then the issue is hardware related and service will be required.
Sep 15, 2009 | Compaq Computers & Internet
Unable to connect netgear wg111 adaptor to orange livebox for internet connection
Hi, follow the steps below:
4. Change the Start Up Type to Automatic and click on Apply.
8. Go to the 'Wireless Networks' tab.
Aug 31, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Sony UWA-NA1 - no available driver for Windows? what specs does it have? It seems that with a Giga Juke Hifi-stereo, it will only communicate with WEP encryption, but the Wireless Giga Juke player station...
I found it! Sony UWA-NA1 USB Wireless Adaptor is a OEM products of Quanta Microsystems Inc, it's using the same USB adaptor as Ralink RT73 USB Wireless LAN card with RT2571WF chipset. I did it work ok in window 7 64-bit. But in the link below, its support XP, Vista as well.
1. Download Drivers for XP/Vista/Win7 here: http://www.station-drivers.com/page/ralink.htmChoose Ralink RT257x/RT2671/RT520x (RT73 series USB Wireless LAN)
2. After download it, run it to install the Ralink Wireless App, check for the driver only. When it done, find the folder it has installed. 3. Open device manager in window managerment, choose the Wireless USB (have no driver with yellow !), right-click, update driver software..
3.a Click "Let me pick from a list of device drivers on my computer". Find the "Network adaptor" in the category devices list, click on it, OK.
3.b In a new window name "Select Network Adapter", choose "Have Disk..." then browse the path of folder Ralink has installed. Your will see a file "netr7364.inf" (may be in XP-32bit or Win7 32bit you will a difference *.inf file). Click on it, click open, then OK.
3.c In the left box, find Ralink Technology Corp. click on it, the find RT73 USB Wireless LAN card, then click NEXT, a "Update Driver Warning" pop-up will appears, just click yes. Then windows will install the driver for Sony UWA-NA1 as "RT73 USB Wireless Card". Good luck! (You may try another devices in the list at your own at risk)P/s: Sorry for my bad english! English is not my primary language.
Jul 08, 2009 | Sony Computers & Internet
D-Link Rangebooster G USB Adapter (WUA2340) Logo
466 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
