Back to:
Tags:
Flat Panel Televisions
Generic problem for all Flat Panel Televisions
Lite On LVW-5001A DVD Recorder (by 2 users)
posted by Smitty3 on Mar 09, 2008
Loader door won't open !!! How can I fix it ?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by stinger123, posted on Jul 05, 2008
I have had the same problem, and although I can't 'fix' it, here's how I cope with it. Always keep a blank or 'dummy' disk in the tray; in other words, never close the tray without a disk in it. As long as there is a disk in the tray, the tray will always open when you command it to.
good luck
Best Solution
posted on Mar 09, 2008
Inappropriate (40)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
se me perdio el control remoto donde lo compro
Rating Locked! (?) Smitty3 has rated this solution as Inappropriate
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Lite On LVW-5001A DVD Recorder:
I don't want to Accept this solution
Can you Help with these Flat Panel Televisions problems?
Haier HP50B 50 in. Plasma Television
Need a power supply module, the shop says it's...
it does nothing when it is turned on the fuse is noblown...
I have a NEC HT 1100 projector. It was working fine now I...
Samsung LE40R74BDX 40 in. LCD Television
I have owned subject TV model for about a year. A couple...
Loading problems.
Repair Service
Find Flat Panel TV Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
