Bosch wff 2000 washing machine - won't spin/drain
My washing machine doesn't seem to want to enter the final spin cycle. It passes through that stage but just doesn't spin. It means that at the end of the cycle it is still full of water and I can't open the door to get my clothes out?!? After the end of the cycle the pre-wash light continually flashes? Is there anything I can do or am I going to have to call someone out?
Thanks aj
  • 5 more comments
  • Anonymous Jun 03, 2008
    Same thing happening here. What do you do? Tried checking pump sysrm but clear.
  • Anonymous Jul 23, 2008
    I have the same problem - did you have to call in someone or did you fix it yourself?
  • Anonymous Aug 30, 2008
    Yep same here. Pattern emerging.
  • Anonymous Sep 07, 2008
    On my Bosch washing machine the spin doesn't work...what could be the problem?
  • lshowell01 Sep 30, 2008
    My washing machine had recently stopped running the spin cycle and an Er:04 error warning on the display. The door would remain locked with the drenched clothes.
    I had found that if I turned the knob to the OFF and then turn the knob to cycle Start it then Pause it after a few seconds, the door would unlock.
    I had mention my problem with the washer to a friend who had offered to take a look for me. They had reached behind the machine pulled the drain out in front over a bucket started the Spin Cycle to see if there would be drainage. No drainage.
    Now in front of the washer at the bottom right is a drain to release the water from the tub (using a Wet Vac to prevent flooding the floor). Then the Wet Vac was used to thoroughly clean out the drain.
    The problem was some fuzz was clogging the drain preventing it from draining the water.
  • skippy289 Jan 05, 2009
    I have a similar problem. Water is draining ok and coming into & out of the machine ok, but the machine is not spinning or rinsing at all. The drum doesn't move around when on the wash cycle either, but does freely move if I move it myself when empty, so its not jammed as such. The motor makes a sound as though its trying to work, but then cuts out, so can only assume the pump is the problem. Does this sound right? I'm being charged £45 callout plus parts plus VAT, so am trying to find out whether this is likely to be worth fixing or should I just buy a new machine? (I'd rather not, but the machine is about 10yrs old & been used almost every day of its life...)
  • Anonymous Mar 20, 2014
    My Bosch washing machine does full cycle fine but will not spin at the end any ideas ?
My washing machine has water at bottom of the drum,the water appears days after we used it.
Can anyone help
bosch wff2000
Posted on Jul 11, 2009
Ihave the same prob with my new bosch it bleebs, displays the key icon and wont open.
turned out water wouldn't drain due to kink in drainage hose.
pull out machine check drainage hose is not twisted or bent
Posted on Oct 06, 2008
I had a similar problem a few years ago, sometimes it would pump out sometimes it just stopped and would not spin. Turned out the pump was broken so I replaced that and everything has been fine since. The guy in the spares shop told me it was not uncommon and showed me how the impeller could stick to the casing magnets. The pump cost about £40
Posted on Sep 06, 2008
How did you solve this problem. I have the same problem. Kiran
Posted on May 26, 2008
Hi our Bosch exxcel washing machine has stopped spinning and doesn't reach the end of its cycle most of the time. If it does the washing is still soaking and needs a new rinse and spin cycle after....
Hi gillsteer,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Bosch Washing Machines
We have a bosch WFF 2001 washing machine, the pump will not turn off and the spin light remians on
bosch WFF 2001 washing machine This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Jan 16, 2011 | Washing Machines
Won't do final spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 14, 2010 | Frigidaire ATF6000ES Front Load Washer
Bosch wff 1401 not emptying water therfor not able to spin the pump goes round but water does not empty if i drain the water the machine will spin
If you have not already done so, then check and clean filter located at bottom front right of washer behind drop down cover.
If it still does not empty, then it is either blocked between the pump and tge waste outlet, or the pump itself could be faulty.
Jan 25, 2010 | Bosch Washing Machines
Spin cycle does not operate
Your clutch on your motor is not working. Your clutch on your motor controls how the motor either spins or agitate.
Dec 15, 2009 | Bosch Washing Machines
My Bosch WFF 2000 washing machine goes through its cycle and then leaves the on/off button lit, the door button lit and the pre-wash button flashing; also the door will not open until you turn all the...
The problem turned out to be foreign objects in the pump that stopped the machine from draining; the solution is simply to open up the pump and remove the objects!
Sep 09, 2008 | Bosch Washing Machines
Washing machine - Bosch WFF 1401 - spinning problem
Bosch WFF 1401 This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2007 | Washing Machines
Bosch WFF 1800
There is no draining & this is why your spin does not work. There is only one belt. First siphon out the water from the machine via your front door. Clean out your outlet filter, check the tube from the tub to the filter. Luckily there shouldn't be a block in your outlet pump
Dec 07, 2006 | Bosch Exxcel WFO 2465 Front Load Washer
Washing Machines Logo
4,587 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
