I have a cyberpower 625avr, i must of had a power surge computor broke and backup side dosent work
    Sergeant:
  • 458 Answers
What are you asking? You seem to know the problem. You can open it up and look for a fuse if there is one. Call the company and ask for a tech. There might not be a way to fix this. An electrician might be able to. Do not mess with it if you do not know electronics.
Posted on Mar 10, 2008
My 685AVR trips itself off immediately after being plugged in. Even with nothing plugged into it. Is something faulty with the product itself, or am I missing some simple solution?
Raymond,
Replace the battery and that should do it. If it's a 12v 7ah battery then you can buy one for 20USD w/ 1 year factory warranty.
If you need UPS, Surge, or Power Related help contact Daniel @ Power & Systems Innovations 800.260.2259 or go
to our website: http://psihq.com/
Sep 19, 2013 | Cybernet Systems CyberPower 625AVR...
How to hook up my Cyberpower to HP PC
Plug CyberPower to wall then plug PC to open outlet.You can connect monitor and other devices as well. The network cord can also be looped into unit. One in. One Out. Make sure power on strip is turned to use PC and other nodes on strip.
Aug 28, 2012 | CyberPower 625AVR (cps625avr-sc) UPS...
If the battery is dead, but the charging system is working will that stop the Battery/Surge side from working?
If you still have your dead battery connected it will work as long as there's no power loss, there are rare cases this won't happen, you can replace the damaged one for a motorcycle one or even a car battery as long as they're 12 volts and polarity setup is right, inverse polarity will kill the UPS so be careful.
May 12, 2011 | Cybernet Systems CyberPower 625AVR...
Power light is out. Is the unit dead?
Atypically if this is an older unit what you have is an issue with the battery. It will no longer hold a charge.
You will nee d to go to the vendor site and look for a replacement battery.
In some cases it may be less headache and cost just to buy a new one.
Oct 06, 2009 | Cybernet Systems CyberPower 625AVR...
Shutting down computer
You need a new battery. A battery store such as Batteries Plus can help you. Many Ace Hardware stores will order one for you and in fact, Radio Shack has the most common battery types in store or can get it for you. If you go through Cyber Power you will pay the highest price.
Hope this helped you.
Regards,
Worldvet
Please don't forget to rate all our solutions on Fix Ya.
Jul 02, 2008 | Cybernet Systems CyberPower 625AVR...
I got lucky with my cyberpower 1000. Found that the black wire from the outlets to the board was not tight enough. Squeezed it a little with my pliers, and it works now. Don't worry about the on-plug falling out, you can push it in from the outside when you're done.
Mar 21, 2008 | Cybernet Systems CyberPower 625AVR...
The battery plug in area is dead but the surge protector side works
Hello Vicki,
What you are describing is usually a result of the batteries losing their ability to hold a charge.
The surge protector side does not rely on the batteries.
I found good batteries at a reasonable cost on ebay, but I think you're going to need to replace batteries at this point.
Hope this helps.
Charlie
Nov 18, 2007 | Cybernet Systems CyberPower 625AVR...
Wiring Fault light
You can download the manual from the link below: http://www.sourceresearch.com/cyberpower/cyberpower-pdf.cfm?PdfPage=625_Manual.pdf The "wiring fault" could be serious, as per manual: "This LED indicator will illuminate to warn the user that a wiring problem exists, such as bad ground, missed ground, or reversed wiring. If this is illuminated, user is advised to disconnect all electrical equipment from the outlet and have an electrician check the outlet to insure proper ground." I would turn the UPS off, unplug all equipment, wait 10 seconds, reset the circuit breaker (if tripped) and turn the unit on. If you still have an issue then it's probably fried! Have you had any thunder storms or electrical power outages recently? Check your house insurance because it may cover a replacement unit. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 13, 2007 | Cybernet Systems CyberPower 625AVR...
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
