Question about Sanyo DS27930 27" TV
Can not get remote to change channgles
Can not get the remote set to where it will work through the vcr ,It has to go through it because if not it will just go to changel 47 and skips to 99 what would be wrong
  • 50 Answers
DISCONNECT THE VCR AND CONNECT THE CABLE STRAIGHT TO THE TV ANTENNA--GO INTO THE MENU ON THE SET AND FIND AUTOPROGRAM-ENTER THAT AND IT AUTO FIND ALL CHANNELS THAT YOU ARE SUBSCRIBED TO AND SHOULD PICK UP THE CHANNELS YOU SKIPPING!YOU CAN ALSO DO THIS MANUALLY--THAT'S ALSO IN THE MENU SCREEN..
Posted on Mar 22, 2008
Need remote code for DVD player
From my searches I don't think you will find it. Try going to http://www.sony.ca/view/cic_contact.htm and asking them directly for it. I can't see them saying no.
Sep 11, 2009 | Sony SLV-D360P DVD Player/VCR
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
Universal remote for vcr
yes. the paperwork that came with the remote will tell you how to change the frequency of the remote so it works for your vcr. make sure the remote is compatable with the vcr brand
Jan 20, 2009 | JC Whitney - Audiosonic 3-way Custom-fit...
Orion vcr recording
I'm sorry, but the speed cannot be changed without the remote.
Nov 07, 2008 | Orion VR213 VHS VCR
Panasonic NV-SJ205 Changing Rf ?
ok. This is a really easy one.
All you have to do is hold down the menu button on the remote control for more than 5 seconds, If that doesnt work hold down the power button on the remote control for more than 5 seconds. If that doesnt work hold down the power button on the actual vcr unit for 15 seconds. The first method should work for Panasonic's fine.
This will then display your current rf output.
You can then change the output by using the up and down arrows or the channel up and down button on your remote or the vcr unit.
Press menu button to save or the same button you used to bring up the rf opposition eg power button on remote or the unit.
all the best. Top tech
Sep 02, 2008 | Panasonic NV-SJ205 VHS VCR
Sylvania 6313CB 13" TV/VCR replacemnt remote
We have a Sylvania 6313CB TV/VCR combo.  I bought a universal remote and the code would not work when I tried to program it to the "TV" button using all those possible codes listed in the books.  So, on the universal remote, there was a button named "VCR" and when I programmed in the code "0000" all worked.  This was a $6.00 universal remote named "One For All"  we bought at the Big Lots store.
Specifically, here is what I did:
Turned TV on Pushed the "VCR" button and light blinked once Pushed and held the "set" button until it blinked twice Released the "set" button and entered the numbers "0000" Pushed the on/off button and it worked including volume, channel up/down and channel change by entering the channel number.
Hope this works for you too.
Jan 14, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
Westinghouse LTV-32w4 HDC - adjustment buttons unresponsive, volume drop, etc.
plug your cable connection to a vcr "in" then run a seperate cable cord from the vcr "out" to your television (which should be on channel 3 or 4) depending on your vcr setting and use the vcr to control the channel so when your westinghouse freezes and becomes unresponsive you could still change the channel and so on through your vcr and tv acts like a monitor works for me. N.B be sure to set the volume and so on before it freezes which could be like a 1min window from turning your tv on
P.S ......................Cardinez
Dec 02, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Changing the Recording speed from SP to EP on TV/VCR Combo using universal remote?
I am sorry to have to tell you this, but the only way to change the recording speed is with an original remote. If you look on the original replacement remote link I posted here you will see the SP/EP selector, this is to change the recording speed. Good Luck. http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=DS13TVR90&brand_pn=FISHER_DS13TVR90&mode=large&uid=11755283300930
Apr 01, 2007 | RCA T13208 13 in. TV/VCR Combo
How can I turn to AV without a remote control (Samsung TV/VCR 19in Combo)
I had this problem with my TV/VCR combo unit (Samsung CXC1972) after losing the remote while in the dorms. I tried a few different universal remotes and dozens of codes before I tried the Philips 3 device universal remote as pictured below with code 037 programmed into the VCR/DVD button. I can't change the volume with this code but the input key switches between line in and tv. You can also change the channel, access the menu and operate the VCR functions with the code. I bought the remote for less than $10 at Walmart so it might be worth a try, and if it doesn't work you can always bring it back. Hope this helps.98fe8a9.jpg
Feb 18, 2007 | Samsung CXJ1964 19 in. TV/VCR Combo
Remote control no longer works
an original remotes available for ya at http://www.remotes.com for 30 bucks + shipping
Apr 23, 2006 | Sylvania 6319CC 19 in. TV/VCR Combo
Sanyo DS27930 27" TV Logo
52 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
