Question about Jenn-Air JGR8875QDS Gas Kitchen Range
F9 Code after power outage - Model JGR8855ADS
We can't get the F9 code to go away after a power outage. We cleared it, reset the time and the F9 keeps coming back keeping the oven door locked
  • tonydev Mar 13, 2008
    Unplugging released the F9 code
    Thanks
  • Anonymous Dec 29, 2008
    Jenair is junk,every time thelights flicker F9 comes on and service man costs $46 dollars to fix.Im getting rid of mine and bringing my old kenmore back upstairs .It still works great after 15 years.
  • 46 Answers
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Generic:
Fault Code Interpretation Components To Check
F-1 Communication error between touch pad and ERC (clock)
Replace the touch pad or clock.
F-2 Oven temperature sensed by electronic control Replace the clock/relay board
F-3 Open oven sensor or harness. Replace the oven sensor
F-4 Shorted oven sensor or harness Replace the oven sensor
F-5 Power to element relay disabled in cook mode Replace the clock/relay board
F-7 Shorted touch pad key sensed for 32 secs. Replace the touch pad/control panel
F-8 Shorted meat probe Replace the probe jack.
F-9 Door lock safety circuit on ERC sensed Replace the door latch assembly
F-C or F-0 Communication error between boards Replace the relay board
Maytag-Maycop-Magic Chef-Jennair-Admiral: Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Posted on Mar 10, 2008
I tried a different method. I was able to get the door open after the F9 code. But it would not turn off once I closed the door again.
Open the door all the way. Then take a long shoe string and wrap it around the lock latch and pulling it into the open position. This should be all the way to the left.
Continuing to keep the latch to the left with the shoe string, close the door. The string should be long enough for you to close the door while holding onto the shoestring keeping the latch to the left.
Now press the cancel/clear button several times. Or press and hold the clear button. After a few seconds I heard a "click" and the lock latch will stay in place. Open the door to confirm and the F9 code should go away!!
Posted on Oct 16, 2010
Jenn model sve47600w
f-7 code , i powered down at electricl panel ,but still sounds and code appears, after trying the next day seems to be ok no codes , my clock display is out but all seems to be working , when the oven reaches temp the display starts to get visible ,
is the clock display the same part as the control panel?
tmatero9@msn.com
Posted on Nov 28, 2009
I'm having the same problem as #2 above with the check probe message. Any Solution?
Posted on Jun 29, 2008
I moved the oven out to replace tile and am now getting constant "check probe" message and the oven won't operate. Have tried unplugging/replugging. Clock can be set but screen always reverts to beep with "check probe." Have pressed the probe button and "cancel" and also plugged the probe in and removed it but again, back to the beep and same message.
Posted on Apr 21, 2008
I keep getting an F1 code on my maytag an am unable to use the oven. Has anyone had this problem?
Posted on Nov 26, 2009
On my new stove i got a F9 code what can i do to get my stove to work
Possibly incorrectly wired. Often these codes are make specific.
F9 or F9 E0 - Whirlpool Home Appliances - Whirlpool® product help
producthelp.whirlpool.com/...Guides/...Ranges/...Code%2C...Code.../F9_or_F9_E0
Apr 22, 2017 - Reset power to the product: This code will most often indicate that the appliance is wired incorrectly at the home electrical supply, or at the hard wire connection. If your oven was installed recently (within approximately 3 months), contact a qualified electrician to verify the electrical supply. During a power ...
What does the F9 error code mean on my Kenmore range Model 790 ...
https://www.shopyourway.com/questions/1074065 Apr 6, 2010 - Door locked started blinking, door never locked,..pressed clear button caused "dr" code, pressed clear again and "f9" and beeping occurred. ... This was extraordinarily helpful...we got this oven from my mom in law when our old one died and she bought a new one, we knew nothing about it but thanks to ... How do I get rid of F9 error code on range?
18 Dec 2011
Why does my Kenmore oven display the F9 error code ...
1 answer
29 Oct 2009
How do I reset an F9 on Frigidaire oven?
1 answer
26 Oct 2009
What does the error code F9 mean on my Maytag ...
1 answer
11 May 2008
More results from www.shopyourway.com
going to clean the oven but got a f9 error had to reset it for it to work ...
? 1:49
https://www.youtube.com/watch?v=cgGKxTxxf4E May 17, 2016 - Uploaded by mike webb
going to clean the oven but got a f9 error had to reset it for it to work mike webb po box 408 stryker ohio 43557.
F9 Error Code - Whirlpool , KitchenAid & Kenmore Range - Repair ...
? 1:01
https://www.youtube.com/watch?v=MXMDjZRNDnw Oct 31, 2014 - Uploaded by ApplianceVideo.com
Visit us at http://www.appliancevideo.com Do-it-yourself diagnostic and repair videos brought to you by ...
stove got F9 code Google Search
Mar 18, 2018 | Kitchen Ranges
Whirlpool stove shooting code F9E0
F9 or F9 E0
Possible Solutions
  • If your oven was installed recently (within approximately 3 months), contact a qualified electrician to verify the electrical supply.
During a power outage, if there was an unexpected amount of power supply line "noise" that the control detected as an incorrect voltage amount, the control could display the F9, F9 E0 or PF Error Code. Also, if any keys were pressed before the 10 second delay interval on power up, this could cause the F9, F9 E0 or PF to appear.
  • Power unit down by turning off the circuit breaker(s) for one (1) minute.
  • Power unit up by turning on the circuit breaker(s).
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify oven operation.
Still need help? Call or schedule service.
You may need assistance from a qualified technician. Call 1-866-698-2538 or click below to schedule an appointment.
Schedule Service Online
Feb 01, 2018 | Whirlpool Kitchen Ranges
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
How do I clear the fault codes ?
How To Fix Maytag Washer Error Code F9 E1 ...
www.appliancerepairlesson.com/2013/.../maytag-washer-error-code-f9-e...
Dec 10, 2013 - The error code F9 E1 will be displayed on most newer Maytag washers and ..... My whirlpool duet wfw94heaw0 gives the error code F09 E01.
KitchenAid f09 error code Dishwashers Questions ... - Fixya
Nov 29, 2015 | Dishwashers
Frigidaire gallery error code f9
How do I reset an F9 on Frigidaire oven? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
Oct 26, 2009 - My Frigidaire oven, model feb24s5asb, door is locked and says f9. The door locked is beeping, I need code to know what the code means and how to unlock it.How do I reset an f9, door ... F-9 Error Possible causes: Door motor failure/jammed. Latch motor switch failure. ... Frigidaire Ovens Gallery 30 in.
F9 Error Code - Can't get it to stop beeping - Appliance Repair Forum
forum.appliancepartspros.com/.../400915-f9-error-code-cant-get-stop-be...
Jan 9, 2012 - 6 posts - ‎5 authors After that it flashed betwed F9 and dr and won't stop beeping. ... say that the last time I used the self clean, the dorr would not unlock and I got similar error codes. ...Frigidaire BFEF374EB1 Frigidaire Canada/electric Range Frigidaire Door Lock F9 error code and now F1
1 post
Dec 6, 2010
Frigidaire Door Lock and F9 error code
Jul 10, 2010
Frigidaire Error Code F20 - Upon Cleaning
Dec 3, 2008
Frigidaire error F-9
Feb 18, 2008
More results from forum.appliancepartspros.com
Oct 29, 2015 | Toaster Ovens
1 have a xerox copier model XD120F Had apower outage when copier cam back on screen is showing a H4 and not powering up thanks Joe
Hello
Since the problem occured after a power outage,you should try resetting the H code.
Press CLEAR, EXPOSURE MODE, CLEAR, EXPOSURE MODE. The display should go blank. Then enter 14 with the copy count keys and press START. If the machine does not turn off and back on by itself - then turn it Off and back on. See if the H code should vanish and your copier should work well.
Apr 17, 2011 | Office Equipment & Supplies
Amana ACF3325A Gas oven, F9 error won't go away
The door latch switch has failed. Probally from the power outage. This is easy to replace and inexpensive. You can enter your model # at www.appliancehelponline.com for diagrams and illustrations.
Apr 29, 2010 | Amana ACF3325 Gas Kitchen Range
Model JGR8855ADS is reading Code F9. what does
Hi There
I have this code for you. hope this helps you.
F9 Door latch Check door latch components.Thank you for writing to fix ya.
Best Regards Richard
Feb 18, 2010 | Jenn-Air JGR8750 Gas Kitchen Range
F9 error
hi there,
can you tell me the model # on your stove please?
Sep 14, 2008 | Maytag CWG3100A Gas Single Oven
Jenn-Air JGR8875QDS Gas Kitchen Range Logo
2,070 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
