Question about Panasonic KX-T7630 Corded Phone
Changing Time Hi Folks, It's day light savings time again. How can I change the time? Thanks for any assistance.
  • 4 more comments
  • Anonymous Mar 11, 2008
    I need to know how to change the time on all of our 7630 telephones.
  • Anonymous Mar 28, 2008
    Same problem, the manual seems to be no good
  • Noelb Mar 31, 2008
    I have the same problem
  • cherrydabomb Apr 04, 2008
    How do you change the time on these phones?
  • Sharynd Apr 07, 2008
    Tried looking for a solution but can't find one. I too, need to know how to change the time!
  • ntbichlien Apr 28, 2009
    I key in the same as instructed above but still no help. only 4 beaps are sound. please help. May be this phone was set with another password. thanks
Hey peoples this worked for me :)
On the main phone
- hit the "PROGRAM" key
- then key in **
- it asks for a password key in 1234
- then key "NEXT"
- then key "ENTER" (this is to set the date)
- then key "NEXT" (this is too set the time)
- once the time is correct hit the "ENTER" key at the bottom of the phone.
Posted on Oct 08, 2008
Hit the program button then * # 1234 000
Posted on Oct 06, 2008
Didnt work... need help
Posted on Sep 29, 2008
Hi Guys,
To change the time and date settings:
  • Hit the Program button then **1234000
  • Adjust Time and Date, then hit the store button to save the settings
  • Hit the hold button to exit the program then click on exit a couple times until you get back to the phone.
Posted on Apr 07, 2008
How do I set digital watch of UL1159
press MODE button 3 times on left screen DAY will flash press RESET MINUTE will flash, change minute what you want by pressing START.
press again RESET button HOUR will flash press START to change hour.
Press again RESET button DATE will flash change same way.
press again RESET button MONTH will flash change same way.
press again RESET button DAY will flash change same way.
After done press MODE to bring back normal time position.
Changing ALARM ....
press 2 times MODE button. Alarm HOUR will flash press START to set alarm hour.
Press again RESET button Alarm MINUTE will flash press START to change.
After done press MODE to bring back normal position.
SO YOUR TIME & ALARM GET SET. images?q=tbn:and9gctqfaospxemzn5ytb2yvmxsagwhcrw-zhdezmqvoulno244gvhvkgaae8w
Oct 04, 2014 | Kenneth Cole Unlisted Ana-Digi watch
Bios date is not being saved
it has to be the battery contacts, the motherboard is loosing contact with the battery which is why it keeps resetting itself
Jul 06, 2010 | Computers & Internet
I suspect the on-board battery because I did some minor maintenance and when I re-booted the computer the time and date were at January 1, 2004 at 12:00 a.m. I have the SG-80
Thanks for using Fixya.
If your system BIOS time keeps on going back to Jan. 1, 2004 without you changing it. There is a 95% chance that you have a bad battery. All you need to do is to replace it. If replacing it doesn't help, try checking the battery terminal if they are still good. I hope this helps.
Thanks and have a nice day.
- Hotratchet
Nov 03, 2009 | Abit SG-80 Motherboard
Fiat Sicentio 1.1 (02 plate) problem after changing spark plugs
check spark plug gaps are set correctly and that leads are in correct order if you took all leads off at same time its easy to mess up just one or two
Nov 08, 2008 | 2007 Fiat X1/9
NEC Dterm80- I need to change the date
On the adminstrator's phone (usually ext 100, 101, 110 or 10)
Do not lift handset
Press the FEATURE button
Dial 9#
Enter the hour & minutes (ex:01:25) using the dialpad
Press RECALL button to change AM/PM setting
Press HOLD to change the calendar setting
Press FEATURE button again to save & exit
Hope it works for you
Nov 03, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Changing time-for day lights saving time on watch
A. Press and hold MODE until HOURS digits flash (you’ll be in Alarm Mode). Press MODE again
to enter TIME mode. SECONDS digits will flash.
B. Press ADJUST to set SECONDS to zero.
C. Press START/STOP to select MINUTES.
D. Press ADJUST to change.
E. Repeat to set HOURS, MONTH, DATE, and DAY of WEEK. Go through 12 hours to set AM
or PM.
F. Press MODE when done.
Nov 02, 2008 | Timex 1440 Nylon watch
Day Light Savings Time
If you tip your clock over you will see three little buttons under. They are each labeled. Press/hold the one that says "clock" until your display blinks. Use the forward/back buttons on face of clock to re-set time, then press the little "clock" button underneath it again to keep the time you just set. It probably will beep.
When Congress's ideal day comes, re-set it the same way. Sorry, but all this will do is keep you from having to look at the wrong time for a few weeks straight.
Oct 28, 2008 | Zenith Z166S Clock Radio
CHANGING PRINTER CONTROL PANEL LANGUAGE
See solution below:
1. Turn off the printer.
2. Press 'select' and turn on the printer. (select button should be pressed while turning it on)
3. press '-value+' to choose your language
4. press 'select' to save
5. press 'go' to return to ready mode.
Thanks
Sep 10, 2008 | HP LaserJet 4000 Printer
Changing time
it does it automatically. you don't have to mess with it. at least mine does.
Mar 11, 2007 | Motorola Mobility RAZR V3
Changing time
go to settings, iniatial setup hope (I spelled that goog enough anyway then go to time and date and your done.
Panasonic KX-T7630 Corded Phone Logo
497 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
