pls download the manual, memory card , compatability is a problem . panasonic,scandisk,toshiba only will work. if you put other m cards , the picture will be very bright-negative effect
May sound like a silly question, but do you have a memory card in? If not the camera may take a picture and show it for a second, but it does not write it anywhere.
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER If your photos are stored on the memory card, then removethe memory card from the camera and insert it into an USB memory card reader.Connect this USB memory card reader and memory card into the USB port of yourworking computer. Your computer will see this as an USB Mass Storage Device oran external storage device; you can then open the folder on the memory card andcopy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
I have that problem with my camera too but after a while... I gave up retype-ing the date and time, so know every picture is on Jan.1st 2004 at 00:00:00 :D I have tried as many things as I could TO fix it but.. nothing came through...
I looked at all the settings that you are able to change on MY camera and no.... you can't.... I was wondering that too a while back and I had to just give up on that.... :D hahaha.... but I hope this helped....
if you don't use it (press a button, take a pic., take a video, etc.) then it will turn off because say you put it in the case and forgot to turn it off, then it won't stay on and waste the battery.
