Question about Bose 3·2·1 II System
Remove the DVD from the system
I can't remove the DVD from the system and it didn't work eather it block.
how can I remove it the bose system is on for a second and after it's off
  • 1 more comment
  • paco cloclo Mar 09, 2008
    no I didn't Y think it's in the DVD the problem it means that it's a pirate movie
    and there is no hole anywere
    it's a bose 3.2.1 GS series II
    thank for help
  • paco cloclo Mar 11, 2008
    no non it doesn't work I tried many thinks like switching off wait and put on again , push the buttom open and keep my finger until it open nothing happen it gave me bose 3.2.1 and switch off again....
    no no neither it doesn't work i tried too
  • 796 Answers
Hi there
Posted on Mar 11, 2008
  • 1 more comment
  • isaac johny
    isaac johny Mar 11, 2008
    as you have said there is no hole
    try to resetting it...
  • isaac johny
    turn it off ....wait for some time and then switch it on and see....
  • isaac johny
    Turn the unit on. Pick it up
    from the right side and rest it on its left side in a vertical
    position. Gently tap the right side of the media console while hitting
    the eject button at the same time. try to tap it hard before it would
    eject the cd cartridge, but it did come out with all CD's intact. try to pry it open and check the gear on the motor.
When playing a dvd the color is in b&w only
I have had exactly this problem when changing TVs. Initially I had the sVideo out cable from the Bose with a scart plug on TV end - that worked fine on old TV. On new TV, first Samsung, second SOny, got Black and white video picture. To get it to work I used a component video cable - this is a short svideo cable with a an audio cable at the Bose end. It splits into a 3way R G B cable within 2- 3 inches at Bose end. I then plugged rgb extension cables into this and TV and worked perfectly.
I found the answer to this by errr...... reading the BOse doucumentation I reveived when I bought the Lifestyle system 5 years ago.
Good luck
May 15, 2010 | Bose Lifestyle 38 System
Placed dvd in to bose dvd player and it froze...wont go back to dvd mode and will not eject...any suggestions?
This can sometimes happen with a newly manufactured DVD (in which case you should call for a sw update) or a copied DVD. Either way, turn the 321 off, unplug the power cable from the acoustimass module, and wait 30+ seconds. After plugging it in, don't turn it on. Just press the eject button and wait about 5-8 seconds. If the tray doesn't open this could me a mechanical failure, in which case you should call Bose for a repair. Otherwise, just call them for a sw update if the DVD comes out.
Jun 17, 2009 | Bose 3 2 1 GSX System
My BOSE 321 GSX, was working just fine. I was listening to a CD and started storing it, then someone else tried to stop it, and pushed the on/off, source and eject buttons at the same time. Since then it...
you can open it up and see if you have broken the ac/dc converter. disc tray could have jammed it up. if you dont know much about them then try calling customer support. ^^
Jun 14, 2009 | Bose 3 2 1 GSX System
Bose 321 have dvd picture but no sound HDMI
check the power suply behind the acoustimass set to 115v, not to 230, that will solve you problem
Apr 12, 2009 | Bose 3 2 1 GSX System
Open/close tray disc stuck bose Lifestyle 48
I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
Feb 17, 2009 | Bose Lifestyle 48 System
This was posted a while ago, so I'm sure it's probably been solved by now. For anyone with audio issues using this or any other Lifestyle system: If you experience audio problems (no audio, intermittent audio) from more than just 1 source (especially if it involves internal sources like DVDs or the radio) then just reset this by unplugging the power for about 30+ seconds from the bass module and the media center DC power. Check the audio input cable (multi-pin din going from the media center to the bass module) for bent pins.
If this doesn't solve the problem, you could try replacing the input cable, but those are usually pretty robust. You could call Bose at 800-367-4008 for tech support or to set up a repair if this fails.
Dec 14, 2008 | Bose Lifestyle 38 DVD Home Entertainment...
Bose 321 DVD drive failure
Found another help site similar to FixYa where a person had posted that they successfully replaced their failed DVD ROM drive in their BOSE 3-2-1 Series I unit with a later model Toshiba SD-M1712 drive. There are 2 plastic trim bits and the metal DVD drive unit cover that need to be swapped between the old drive and the new PC type drive to complete the repair. I located and ordered a new drive and spent last evening removing the old drive from the BOSE. To remove the old drive all that is really necessary is to remove the lid from the BOSE unit and pop off a black steel holdown assembly across the top of the failed drive. Once that is done the old just drive lifts out and the replacement is virtually the same as swapping out a drive in your PC. I am awaiting arrival of the replacement OEM drive ($25) from some place in Texas. This just may work. BOSE wants hundreds of bucks and several weeks to repair their crappy unit. I will never purchase BOSE again. I had to also purchase a power supply in years past for this very lightly used unit and that was $300 and a lot of aggravation using the BOSE repair system. I have trouble just throwing this unit away because we spent $1000 hard earned $'s to buy the "best". I was certainly fooled. If this doesn't work I'm only out $25.
Dec 09, 2008 | Bose 3 2 1 GSX System
Bose 321 DVD Stuck Won't Open
This can happen if the disc has been put in upside down accidentally, if both sides are highly reflective (e.g. blank recording discs). If so, you need to get the system to eject the system before it attempts (and fails) to read the wrong side of the disc:
On the back of the Acoustimass module (sub woofer) is a power switch. Use this to the turn the system off and wait 30 seconds. Switch it back on, the media centre flashes up "Bose 321" - press the eject button firmly once as soon as this disappears. If this works, contact Bose with the serial number from the media centre to see if the system needs a (free) software update (a disc they send in the post) - just in case the system is having general disc reading issues.
However, it may be that the drive has failed - it's a mechanical part in a mass produced system so this is not unreasonable, just disappointing. But because you have bought a premium system, the company will rush to help you - call them for a repair and explain you need the disc back urgently. they'll probably arrange an urgent, fast turnaround repair....
Jan 01, 2008 | Bose 3·2·1 II System
DVD Issues
firmware issue with bose i would call them to get dvd rom updated
Dec 27, 2007 | Bose 3·2·1 II System
Bose 3·2·1 II System Logo
Top Bose Audio Players & Recorders Experts
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
