Question about SVA-USA SVA VR 15A 15" Flat Panel LCD Monitor
SVA Monitor stuck in Analog Mode or Sleep Mode
I powered on my pc today and monitor was strange pink color tones. Then went into sleep mode and now analog mode. Power button does not reset monitor. What is wrong?
  • 1 more comment
  • Berad Mar 12, 2008
    I plugged in the monitor and I get a message of "unknown mode Going to sleep"
    I have tried the plugs and a new cord to the monitor and get the same results.
    Any idea what I can do?
  • Q of Dolland Sep 24, 2008
    reset my resolution, monitor went into sleep mode because it could not support the resolution I selected, and now all it does is sleep. Can't operate my computer with out a monitor HELP!!!
  • 1edgy1 Dec 13, 2008
    same problem here,monitor just keeps booting , runs thru initial stages ,stops on"start windows normal" anolog power saving mode and starets all over again.over and over again till i push power button, ive started in all safe modes ,no change , changed monitors ,cables, nothing! i believe it started when i changed settings due too flexi sign8 was not fitting on screen.ya thats correct ,i was in an unknown zone .and once again ,POOOOOOF, i got signs to design and cant get too it. help purdy pleaseeeeeee?
Actually it was quite easy. I rebooted my computer in "safe mode" by restarting it and pressing the F8 key. At the start up windows gives you an option to toggle down to "enable VGA mode" and select it. After that, my computer recognized my monitor and it has worked fine ever since!
Posted on Mar 13, 2008
I had the same problem and called my brother who builds computers.  Here is what worked for me and makes perfect sense.  Also make sure that you set your computer to never go on sleep mode.
Plug in a different monitor so that you can set your computer display in this way:
The Screen disollution properties should be set to 1024X768 Make sure the setting is 16 Bit.  Now also set your refresh rate for 60hz(No higher)
Shut down your computer.  Plug in your flat screen monitor and restart your computer.
There is no reason to go find drivers because these monitors use the plug and play from windows.
It worked perfect after that.
Hope this helps everyone because it was simple and makes sense..
Posted on Jul 19, 2009
My monitor seems to be stuck in sleep mode
This happens when there is no communication with video card. Check cables, re-seat video card, make sure monitor is set to correct mode. VGA (15pin blue), DVI (white), or HDMI.
Aug 28, 2012 | Dell desktop and monitor- Inspiron 530...
VR-15R monitor in sleep mode
Most likely your issue is a bad video card or a bad vga cable. Try swapping video cards and see if this doesn't solve the problem. You could also use a vga signal generator, available for pretty cheap, to inject a signal into the monitor to determine if the problem is indeed your source rather than your monitor. If the monitor is the problem, you can try troubleshooting the various components on the circuit board with a huntron tracker while the unit is powered down. But then, I digress, as this is quickly becoming a solution beyond my ability to explain to you the inner workings of such things as a pn junction or the phase lag of a capacitor or the ringing of an inductor. Sorry, might be best for you to simply buy a new monitor. Ones like these cost, what - oh, look! FRee on craigslist.
Jan 25, 2012 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Mar 17, 2010 | Computers & Internet
HP1965 Monitor in sleep mode
hi there,
just remove the battery, this should solve your problem :)
hope this helps
May 06, 2009 | Computers & Internet
SVA VR 15A flat screen monitor does not complete boot up.
It sounds like that monitor has a leakage problem on the ground or shield. This is a common flaw that forces intel motherboards to keep from booting. If you carefully cut the outermost layer of monitor cable away (it looks like a basket weave made of metal threads) that surrounds the other signal cables inside, this problem will go away.
Mar 08, 2009 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Hyundai LCD monitor L70N Stuck in sleep mode?
push and hold the power button... then hit the settings button on the monitor and goto power>sleep mode
Jun 17, 2008 | Hyundai ImageQuest L70N 17" LCD Monitor
Double check the monitor cable, both going to the monitor, and going to the computer. Ensure it's securely connected. If this doesn't change anything, try rebooting your computer. When the power light flashes, it's in sleep mode and doesn't detect either an analog or digital signal - so either your computer has gone into sleep mode (you can awaken it by hitting any key or moving the mouse) or the cable isn't attached securely. Since your computer is brand new, it's unlikely that anything has broken down already. Another thing to check is to make sure that the resolution in your Display Settings is the correct resolution for the monitor - although it's hard to do this if you can't see what you're doing.
Best of luck, hope this helps!
Jun 07, 2008 | Gateway FPD2275W LCD Monitor
My monitor is in sleep mode and I cannot get it out if it.
Sleep Sleep is a mode that the computer enters after being inactive for a set amount of time. Commonly, this mode will turn off a device or set it into a stand-by
Engergy star No data is lost when computer components enter a low-power mode, ... keyboard would get the computer out of this mode. Also see: Power Definitions, Sleep
This should wake your computer, Good Luck/Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion F1703 17" LCD Monitor
Stuck in sleep mode w/black screen
If possible, try a friends monitor first. If it works, you can then change the sleep mode setting so that it won't come on again. If the other monitor does not work, the video card is probably defective.
Oct 26, 2007 | Computers & Internet
Won't come out of sleep mode
Is this monitor connector to PC? is yes most probably the problem is the system is not sending signal to tell your monitor to wake up...
Aug 30, 2007 | Sharp 17" Monitor
SVA-USA SVA VR 15A 15" Flat Panel LCD Monitor Logo
2,405 people viewed this question
Top SVA-USA Computers & Internet Experts
David Payne
David Payne
Are you a SVA-USA Computer and Internet Expert? Answer questions, earn points and help others
