Question about Proscan PS27115 27" TV
PS27115 27" CTC197BC Horizontal Width Adjustment
Horizontal width is to wide. Wondering which service code will adjust. Width and side to side.
Thanks
Steve
    Problem Solver:
  • 20 Answers
Probably shorted capacitor in pin cushion. and also a diode. is it bowed?
Posted on Mar 17, 2008
Picture adjustment on a samsung ue40f8000
Hi
You cannot choose individual width and height but in Tools > Picture Size you will find Auto Wide, 16:9, Wide Zoom, Zoom and 4:3
Hope this helps
Nov 07, 2013 | Samsung Cameras
Which service manual setting controls horizontal size?
You're discussing about the factory mode adjustments. The horizontal width adjustments will not be there. You have to adjust it by replacing certain capacitors at the horizontal output stage.
May 18, 2013 | Panasonic CT-20G6 20" TV
Horizontal adjustment
What is the brand name and model number to your TV? Provide more details please. Actually what do you want to adjust? If it is horizontal width, you have to enter its service mode to select this option. If you wish to get more details about how to enter service mode to different models of remote controls, check this link.
Feb 26, 2013 | Televison & Video
I have a euro-pro sewing machine that i got second hand, came with no manual so i dont know whot to set it to basic stich it has all these knobs and i have no idea how to run it normally
Hello
The stitch dial for the length is located all the way on the right side of the machine and is factory set at the setting "3," which is a 3mm or 1/8 inch length. Turn the dial up or down to adjust the length. For example, the setting "4" is 4mm (5/32 inch) and "2" is 2mm (5/64 inch).
The width of the serged seam is dependent on the needle or by adjusting the knob for the width. With the left needle only sewing, the width is set to 7/32 inch, and with the right needle only sewing, it is set to 9/64 inches. Additionally, by pushing in the width adjustment knob behind the front cover, the stitching can be adjusted manually from 1/8 inch to 17/64 inch wide.
Jul 23, 2011 | Euro-Pro Deluxe 6130 Mechanical Sewing...
Picture is too wide to fit screen can not see complete picture
hi there, i don't know your TV brand but this could be of help anyway. there is an adjustment for horizontal and vertical width. you can manually adjust the setting until it fits the picture on the screen. for standard TV it has trimmer in the CRT board. If in your case you have a soft adjustment in the remote control try to adjust it. Learn how the menu works just look for the picture adjustment.
Good luck, please rate and vote.
Mar 20, 2011 | Televison & Video
Screen horizondally pulled right side and screen rolled to left side
hi,
your monitors horizontal deflection side have some problem. you have to check the horizontal width cotrolling transistor mounded on the aluminum heatsik near the lot( line output transistor). also check the three mosfets which adjust the width for different resolutions. there are three such mosfets in the horizontal section.
fist of all replace the width controlling transistor in the heat sink. photo of mosfet and transistor is added for reference. not the exact number.
ok
Jan 27, 2011 | AcerView 99C 19" CRT Monitor
Dynex 19 inch tv used as pc monitor; the pc display is bigger that the width of the viewable screen which cuts off about 1/4 inch on each side making it difficult on some things to shut down since the...
\http://www.retrevo.com/support/Dynex-DX-LTDVD22-TVs-manual/id/23122dj497/t/2/
Above is a manual link. usually you use multiple presses on the buttons to get to the menus. One button, is menu, the others are for up.down & left/Right. The same as for Horz Posn. You press the menu, use the L/R buttons to go to the menu item, then up and down to + or - the setting.
have a look at the manual.
Apr 23, 2010 | Televison & Video
Picture is too wide, how can I adjust the width?
Can't you set/adjust that on menu settings? If not, and no adjustable knob inside for width adjustment. You are now dealing its adjustment with MCU, or its eeprom ic. Check its required power supply it should be within spec. Better to have an schematic if you deals within its electronics parts.
Nov 15, 2008 | Sanyo DS27910 27" TV
HOrizontal width problem
With older sets i found dust as the main culprit in simmular situations.check for any  adjustment pot on the circiut controlling the screen width[normaly 3 pots close together open back of set to reveal electronic's]. be very carefull not being electrified as the set must be in operation while doing the adjustment.even turning the pot forward and back and then to the original position sometimes solve the problem.
Oct 17, 2007 | Televison & Video
Televison & Video Logo
127 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
