Question about Insignia LCDTV26 26 in. Television
Insignia LCD 27" w/vertical lines for picture
TV works fine for about 5 mins then the picture turns into vertical colored lines moving erratically. Sometimes the picture will come back and it will work fine for hours. Main problem is vertical lines on TV with no recognizable picture.
  • 2 more comments
  • VolvoTech Mar 10, 2008
    I have done that, it works for a bit but then goes back to the vertical lines, thanks though.
  • Anonymous Oct 22, 2008
    turn on tv and works fine then turns pastel and muddled and then might
    return to normal
  • Anonymous Dec 02, 2008
    THE SCREEN GETS ALL CRAZY WITH MULTI COLORED LINES BUT YOU CAN HEAR IT!! THEN IT CLEARS UP AND OCCURS AGAIN!!
  • Tom Pavlock
    Tom Pavlock Mar 20, 2014
    This does not work for me. Anything else?
  • 146 Answers
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Posted on Mar 09, 2008
Black vertical line
This seems to be a problem with some older panels. If you are prepared to tackle the problem yourself then try the following.
WARNING there are some very high voltages within the TV which can be LETHAL so the greatest of care should be taken.
With the back of the TV removed, use a hair dryer and apply warm air to all the ribbon cables in turn until you find the one which causes the fault to disappear. Now turn your attention to the faulty ribbon and remake the connections as necessary.
Dec 19, 2013 | Insignia Televison & Video
Insignia 27" lcd tv vertical colored lines across screen.
This television, appears to have had a failure in the mainboard. This is the board that controls the video functions and sound functions. The unit should be taken or sent in to a service center for testing and servicing. The service center will have all the correct service information to determine the problem for you. You can call Insignia customer support at this telephone number 1-877-467-4289. You can also got to the customer support website at www.insignia-products.com. Go to the support section and ask them for help on how to get service for your television. I hope this information helps you with your problem.
May 14, 2009 | Insignia IS-LCDTV32 32 in. Television
When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Mar 02, 2009 | Samsung LN-S3238D 32 in. LCD HDTV
Insignia ns32lcd no picture just lots of vertical colored lines
Usually this problem is caused by the connections for the LCD Controller(TCON). If you disconnect and re-connect the cable until it works correctly it will usually solve this problem.
Feb 08, 2009 | Insignia IS-LCDTV32 32 in. Television
Half screen showing
ok
keep tv off.
it will only get wors
if sumon dosent work on it soon
the problem you are having in the vertical section of the tv
hav a repairman resolider all conection on the vertical IC and check the serounding componets for falts.
regards daniel.
PS the repair takes me about 15 min.
Jan 13, 2009 | Samsung TXG2746 27" TV
Insignia(samsung) 50" plasma Vertical red lines
I would take it back. I know from purchasing an Insignia LCD from them a while back, the TV just died after about 4 or 5 months. They ended up offering me another TV or with store credit. I took the store credit and chose another TV. I also did not have a warranty. I was told since it was Insignia (which is a Best Buy house brand) that replacing it was not a problem. Good luck.
Nov 25, 2008 | Samsung Televison & Video
Problem with my insignia tube tv!!!!
if that look like horizontal line shuld be vertical problem. check vertical ic around it of resistor& capacitor. good luck!
May 26, 2008 | Insignia NS- 27" TV27 TV
Westinghouse 27" lcd hdtv
My Wesinghouse 27" lcd hdtv jumps and vertical hold is out of control after being on 15 mins. The cable company checked the connection and it is clean. We did not damage the tv. It has been doing this since we got it. We did not get a service contract. Sometimes the screen goes black with a small rolling picture on top. Help me please. Can the maufacter still help us?
we lost all the papers when we moved.
Jan 27, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Dec 17, 2007 | Samsung LNT3242H Television
Insignia LCDTV26 26 in. Television Logo
911 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
