Question about Vtech mi6896 Trio Cordless Phone
Vonage phone servive
I'm getting error [code 003} tring to setup my vonage phone
  • Anonymous May 14, 2008
    my internet stop's working the phone also stop's working and the v portal says error code 3 ''unplug your power cord and plug it in again. This happens constantely
  • Anonymous Dec 03, 2008
    Your service is terrible!!! I would never recommend it to anyone. The internet & phone is constantly going down with error codes, 1, 2, 3, 4, & 5. As a consumer, I wouldn't recommend to anyone getting Vonage.
Usually when u get an error code 003, it means ur internet is out, if u have problems getting online it effects the phone. if u have bad cables or an old modem or like wireless or satelite isp's can cause this issue as well, try power cycling the whole network modem-vonage device. al
Posted on Nov 20, 2008
I am getting an error code 003. unable to update software
Roku Phone Number
888-600-7658
Press 1
Average Wait: 17 mins - Monday through Saturday 8AM to 8PM PST
http://gethuman.com/phone-number/Roku/
Apr 02, 2015 | Roku Streaming Stick
Does grandstream gxp 280 support vonage
Yes it supports.
SIP Account Name: Vonage
Phone Number: xxxxxxxxxx (enter your Vonage phone number)
Authentication ID: xxxxxxxxxx (enter your Vonage phone number)
Authentication Password: xxxxxxxx (enter your Vonage Authentication Password, this can be Provided to you by Vonage. Please remember that the password is case sensitive.)
SIP Domain: leave blank
Proxy Address: sphone.vopr.vonage.net
Port: 5061
Outbound Proxy: sphone.vopr.vonage.net
Port: 5061
Local Port: 5061
Register Timer: 3600
Codec: Auto
Pkt. Time: Default
Out of Band DTMF: On
-Karthik.
Sep 25, 2012 | Grandstream GXP-280 IP Phone
My desktop has a local area connection with limited to no connectivity. I had my desktop pc connected to a netgear n900 router and a vonage phone connected to the router's lan1 port. This caused i
Did this connection ever work before? I have a similar setup with Iristel and once in a while it goes down (Hurricane Leslie generated the problem last week).
Check whether the setup works without the Vonage device. This will tell you whether the problem is with your router or the Vonage box. If it works without the Vonage, the problem is in the Vonage box, you may find a good time to call Vonage for support.
I don't know whether the Vonage box (in my Iristel case it's a mediatrix 2 something) has to 'call home' before it lets your router set itself up.
If your router does not work without the Vonage, you have a simpler problem, the router is the issue. You can reconnect the Vonage and if the phones work, this confirms that the router is the problem. At least you can use the phones.
With the router, you need to log in to the admin screens and poke around until you find the problem. It is always a good idea to only change one thing at a time and always remember what changed immediately before the problem was noticed.
Sep 16, 2012 | Gateway Computers & Internet
I am trying to send a Fax but keep getting a communications error
Vonage is a DIGITAL phone service. ALL fax machines are analog devices. You need a plain old telephone line.
Jul 22, 2009 | HP LaserJet 3050 Printer
Vonage customer, problem running through home phone wiring
Make sure you have disconnected the original phone line at the first entry point to your home. Even though regular phone service is disconnected (software) the original phone line carries some "noise" which can cause issues when trying to utilize existing phone wiring throughout the home.
Dec 02, 2008 | Lands Phones
Hp j6400 fax over voip line error code 388
Fax machines are ANALOG devices, VOIP, Vonage etc are DIGITAL devices.. It won't work reliably
Oct 29, 2008 | Office Equipment & Supplies
Vonage does not work with D-Link router
If you plugged a telephone into your D-link router, unplug it - that can not work!
You have to plug your vonage router (WAN port) into the D-Link (LAN port) and connect your phone to one of the LAN ports of the vonage router.
If you do not need the wireless capabilities of the D-Link, you can simply take that one out and only use your vonage router.
If you need more help, I would need more details form you:
Which vonage adapter are you using?
How is your setup (i.e. modem -> D-link -> vonage & computers)
What connections are you using (wire/wireless)?
You can also find help here.
Jun 17, 2008 | D-Link DI-704P Router
Vonage and faxes
Only real solution I know would be to get rid of Vonage. All experiences with Vonage has left a bad taste in my mouth. Regardless of your broadband speed, Vonage uses open internet and is subject to network problems. Fax's require Real-Time communication/transmission control, which is, thus far, not available with Vonage.
Dec 24, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Vonage Again
Just use a splitter and connect the phone line direclty to officejet 7310 All-in-One line 1 port.
Then make below changes :
Press Setup on the All-in-One. Navigatet to Advanced Fax setup - Fax speed. Set the Fax speed to Slow. Also set the ECM (Error Correction Mode) to Off.
Thanks
Dec 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Fax - Using Vonage
Press Setup on the All-in-One. Navigatet to Advanced Fax setup - Fax speed. Set the Fax speed to Slow. Also set the ECM (Error Correction Mode) to Off. Try sending FAX.
Vtech mi6896 Trio Cordless Phone Logo
1,682 people viewed this question
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
