Question about Compaq Presario 5000 PC Desktop
Drive cable connection
Can you help me connect my hard drive and cdrom drive and floppy drive cales to the correct place in my older computer thanks
  • 655 Answers
Its easy to connect. Try the followings:
1) See the IDE0 port on your mother board and make connection for your hardisk to this port.
2) See the IDE1 port on your mother board and make connection for your CD-ROM to this port.
3) The IDE for floppy is much smaller than IDE0 and IDE1 so you can easily figure out that port and connect your Floppy Drive to that port.
Note: If you are newbiz then keep attention when connecting the cable to the device. Please push gently and firmly. If it got set easily then you are on right way, otherwise try in other direction.
Posted on Mar 09, 2008
I have a x4250 Its not on the list of products I can't get it connected to my computer.I don't have any money
If you can open the box removing the screws on the back of the main computer tower, remove the cover.
the floppy drive has about 4 small screws that hold it in place in one of the slots by the cd rom drives.
There are two connectors for this floppy. a flat ribbon cable and the 4 color wire cables they only go on one way.These floppy cables are smaller than the drive cable with double plugs on them. Find one, and connect it.
You may need to enter the CMOS set up when you first turn on the computer and tell it you added a floppy drive.
When you first turn on the computer, I believe you need to hit F1 or, F12, or F8 one of these to enter the computer board set up. There you should find the hard and floppy drives. Select the 3 1/2 drive for either A or B.
Save and exit.
The machine should work.
I am not sure what kind this computer is and I cannot tell the type of ribbon connections you have, and if you have any of the Floppy ribbon cables in there already.
The Floppy's take a different ribbon cable from the Hard drive.
And they are connected in the black plug in one part of the main board for floppies.
Good luck, if you have anymore information to provide on your computer, let us know.
Good luck.
Oct 18, 2009 | Acer Computers & Internet
Portege 3505
pls get ur cdrom service & try again but prior to that pls check ur data cable which is connected to ur pc
Jan 12, 2009 | Toshiba Portege 3505 Tablet PC
I cannot boot windows xp
Hi praph_wicked, normal order would be, floppy drive first, CDROM second & Primary hard disk drive third.
How ever if your bios does not comply you can always press the F8 key every two seconds & that should bring up (Please select boot device). Which will look like this;
Choose the CDROM drive with the windows CD in it.
If you have just one CDROM drive, make sure the jumper on the back side of the CDROM is set to "Master". If you have two CDROM drives connected, set one as master & the other to slave.
If using an IDE cable for the two CDROM drives. The CDROM at the end of the data connector is to be set as master, the 2nd CDROM connects to the next IDE connector & Its jumper is set to slave.
Dec 13, 2008 | EliteGroup P4M800-M7 Motherboard
Ilunable to read from hard drive or cdrom from p4i65g
Try changing the IDE cable which connects your CDROM to motherboard. Also make sure that Master/slave configuration are properly set if both the hard disk and the cdrom are connected with a single cable
Nov 25, 2008 | ASUS A7V8X-X (90-M7A690-W0EAY) Motherboard
Trubleshoot Motherboard
More than 70% of all computer problems are related to cabling and connections. Ensure all cables are connected and connected firmly. IDE and floppy ribbon cables and power cables can often go loose. Ensure microprocessor, memory modules, and adapters such as video card are inserted correctly and didn't "pop-up" due to vibration.
System has no power at all. Power light does not illuminate, fan inside the power supply does not turn on, and indicator light on keyboard does not turn on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Power cable is unplugged. Visually inspect power cable. Make sure power cable is securely plugged in.
Defective power cable. Visual inspection, try another cable. Replace cable.
Power supply failure. Power cable and wall socket are OK, but system is still dead. Contact technical support
Faulty wall outlet;circuit breaker or fuse blown. Plug device into socket know to work and test. Use different socket, repair outlet, reset circuit breaker or replace fuse.
System inoperative. Keyboard lights are on, power indicator lights are lit, and hard drive is spinning. PROBABLE CAUSE DIAGNOSIS SOLUTION
Expansion card is partially dislodged from expansion slot on the motherboard. Turn off computer. Take cover off system unit.
Check all expansion cards to ensure they are securely seated in slots. Using even pressure on both ends of the expansion card, press down firmly on expansion card.
Defective floppy disk drive or tape drive. Turn system off.
Disconnect the cables from one of the floppy drives. Turn on the system, check to see if the keyboard operates normally. Repeat until you have located defective unit. Contact Technical Support.
Defective expansion card. Turn computer off.
Remove an expansion card. Make sure expansion card is secure in expansion socket.
System does not boot from hard disk drive, can be booted from floppy disk drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Connector between hard drive and system board unplugged. When attempting to run the FDISK utility described in the HARD DISK section of the manual you get a message, INVALID DRIVE SPECIFICATION. Check cable running form disk to disk controller on the board. Make sure both ends are securely plugged in; check the drive type in the Standard CMOS Setup (in your motherboard manual).
Damaged Hard Disk or Disk Controller. Format hard disk; if unable to do so, the hard disk may be defective. Contact Technical Support.
Hard Disk directory or FAT is scrambled. Run the FDISK program, format the hard drive(See HARD DRIVE section of manual). Copy your backup data back onto hard drive. Backing up the hard drive is extremely important. All Hard Disks are capable of breaking down at any time.
System only boots from Floppy Disk. Hard Disk can be read and applications can be used, but booting from Hard Disk is impossible. PROBABLE CAUSE DIAGNOSIS SOLUTION
Hard Disk boot program has been destroyed. A number of causes could be behind this. Back up data and applications files.
Reformat the Hard Drive as described in the Hard Drive section of the manual. Re-install applications and data using backup disks.
Error message reading "SECTOR NOT FOUND" or other error messages indication certain data is not allowed to be retrieved. PROBABLE CAUSE DIAGNOSIS SOLUTION
A number of causes could be behind this. Use a file by file backup instead of an image backup to backup the Hard Disk. Back up any salvageable data. Then do a low level format, partition, and high level format of the hard drive( see Hard Disk section of your manual for instructions). Re-install all saved data when completed.
Disk formatted on IBM PS/2 will not operate with this system. PROBABLE CAUSE DIAGNOSIS SOLUTION
The IBM PS/2 uses a different format than other computers. IBM PS/2 disk format will not work in an AT type computer. Format disk in the AT type computer insert disk into the IBM PS/2 and copy the files you wish.
After install an expansion card (network card, tape drive card, etc.) the system no longer works properly. PROBABLE CAUSE DIAGNOSIS SOLUTION
No power to monitor. All or part of the system may be inoperable. The new card may work but a mouse or COM port may not work. Change the interrupt or RAM address on the new expansion card. See the documentation that came with the new card in order to change pin settings. many expansion devices come with proprietary software that will assist you in doing this.
Screen message says "Invalid Configuration" or "CMOS Failure." PROBABLE CAUSE DIAGNOSIS SOLUTION
Incorrect information entered into the configuration (setup) program. Check the configuration program. Replace any incorrect information. Review system's equipment. Make sure correct information is in setup.
No power to monitor. Power connectors may be loose or not plugged in. Check the power connectors to monitor and to system. Make sure monitor is connected to display card, change I/O address on network card if applicable.
Monitor not connected to computer. See instructions above.
Network card I/O address conflict. See instructions above.
Memory problem, display card jumpers not set correctly. Reboot computer. Re-install memory, make sure that all memory modules are installed in correct sockets. Check jumper and switch settings on display card. See display card section for information of settings.
Computer virus. Use anti-virus programs (McAfee/PC-cillin, E-port, etc) to detect and clean viruses.
Screen goes blank periodically. PROBABLE CAUSE DIAGNOSIS SOLUTION
Screen saver is enabled. Disable screen saver.
Keyboard is disconnected. Reconnect keyboard. Check keys again, if no improvement, replace keyboard.
Faulty Monitor. If possible, connect monitor to another system. If no color, replace monitor.
CMOS incorrectly set up. Call technical support.
Floppy drive lights stays on. PROBABLE CAUSE DIAGNOSIS SOLUTION
Floppy Drive cable not connected correctly. Reconnect floppy cable making sure PIN1 on the Floppy Drive corresponds with PIN1 on floppy cable connector.
Bad floppy disk. Try new floppy disk.
Floppy disk not formatted Format floppy disk(type ENTER)
SETUP program does not have correct information. Boot from drive A: using DOS system disk. Input correct information to SETUP program.
Hard Drive cable not connected properly. Check Hard drive cable.
Cannot boot system after installing second hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
Master/Slave jumpers not set correctly. Set master /Slave jumpers correctly.
Hard Drives not compatible / different manufacturers. Run SETUP program and select correct drive types. Call drive manufactures for compatibility with other drives.
Missing operating system on hard drive. PROBABLE CAUSE DIAGNOSIS SOLUTION
CMOS setup has been changed. Run setup and select correct drive type.
Certain keys do not function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keys jammed or defective. Replace keyboard.
Keyboard is locked, no keys function. PROBABLE CAUSE DIAGNOSIS SOLUTION
Keyboard is locked. Unlock keyboard
If a problem persists, please search for a solution or post a question in our tech support forum in our Help Desk.
Oct 19, 2008 | Computers & Internet
I"m trying to hook up this Emachine and im having proble4ms connecting cdrom floppy hardrive
An external drive would have a cable you connect to the back of your tower. An internal would not have this but would connect directly to your motherboard on the inside of your PC Tower.
Based on your follow up question it appears you want to connect to an inside pin out connection point. Is this right? And if so, what type of cable do you have that need to connect? Is it thin and round or flat and wide?
Thank you for your patience. One of use will be able to help you further once you post this information. Sorry, but we actually need to konw this in order to solve your problem.
Please use th comment box below to reply.
Aug 18, 2008 | Computers & Internet
Power Supply Cables
The hard drive and CDROM connect to the large flat four pin cables [there are several.] The floppy[s] connect to the tiny four pin cable that is on the same line as one or more larger four pin cables...
There is no order, just pick them in a way that they all reach without strain.
Aug 15, 2008 | Mad Dog Multimedia SurePower (MD-350WPS)...
Motherboard fails to see Hard Drive...please help
Sounds like you lost an ide channel, swap the ide cables around, primary to secondary and secondary to primary. and see if it recognizes the hard drives and not the cdrom.
I lost an IDE channel and had to install a sata hard drive or run the hard drive and cdrom on the same ribbon. If you run HD and CDROM on same ribbon set both to CS (cable select)
Mar 23, 2008 | Dell Dimension 4600 PC Desktop
Dvd rom drive
is cable on master jumpers or slave ?
Feb 07, 2008 | NexxTech (COB6V5216) Burner
Power buton permanently on but system won't start
cheak cables again take batery out back in reset bios make sure middel of cable is slave end of cable jumpers on cd rom hd setto master ok
Jan 29, 2008 | Dell OptiPlex GX260 PC Desktop
Compaq Presario 5000 PC Desktop Logo
24 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
