Overheating and shutting down
My Acer Aspire 5610-2328 notebook has been over-heating and shutting down since I purchased it around 15 mos ago. I sent it in to their repair center once and they turned it on and left it in the back room without any kind of load on it and told me that they couldn't find anything wrong with it.
It has continued shutting down and now it says that my Windows Live OneCare that I purchased some months ago has quit working. It is freezing up and most of my programs are not responding on a regular basis. One of the biggest problems is that the date is stuck at June, 2005 and it won't let me change the date and time.
    Sergeant:
  • 458 Answers
Re-load it. OR Take it apart and clean it. Dust is clogging the heatsink by the processor. AMD OR PENTIUM?
TRY RUNNING SPYBOT S&D and ADAWARE 2007 to remove spyware (Change to the highest that you can. SPYBOT S&D can shut down things in start-up in Advanced mode. Download THE FREE Norton from the Google package and let it run.
Posted on Mar 10, 2008
My acer notebook 1 keep shut down
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Aug 25, 2012 | Acer Aspire One PC Notebook
Acer Notebook 5315 overheats and shuts down unexpectedly
The weak point of ACER is overheating. I always plug in on usb port additional fan and place it right below the ACER to prevent overheating.
Regards, vote please, Jay
Jan 25, 2011 | Acer Aspire 5315 Notebook
My Acer 5315 is overheating helpp
Follow these steps to avoid overheating:
-Don't use your laptop in full sunlight for extended periods
-Don't leave your laptop in a closed car on a sunny day
-Don't place your laptop on or near extreme heat sources, such as radiators, hot air vents
-Turn off your laptop before putting it in your carry bag
-Turn off your laptop when not in use for a long period
-Work on an even surface as much as possible ?€" not your lap!
-Clean the air vents in your laptop regularly by using a can of compressed air
-Get more space under your computer by propping it up on something when it's on a desk
-Consider purchasing a laptop cooling pad
-Consider purchasing an external fan
To clean your laptop's cooling system follow these steps:
-Shut down the laptop ie do not leave it suspended, sleeping or hibernating.
-Unplug all cables from the unit and remove the battery pack
-Get a can of compressed air and blow it into all vents around your computer - this should clear out any dust and hair.
-Do Not use a vacuum cleaner.
Nov 25, 2010 | Acer Aspire 5315 Notebook
Laptop shuts down
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed-air, and give your computer a "blow-job", to remove the dust, because the dust is acting as a layer of insulation, trapping heat inside your computer.
Reload the battery.
Connect the AC power.
Start your laptop, and check that the fans inside the notebook computer are pushing air out of the exhaust-vents. If not, the fan(s) have failed, and you need a professional computer technician to disassemble your computer, and fix the fans.
Jul 16, 2010 | Acer Aspire 5535-5050 Notebook
Acer aspire overheating & rstarting.
you can replace the fan if you know how to do so but take it to a qualified technician and they will be able to sort it out for you and it should be that expensive
May 29, 2010 | Acer Aspire 5100 Notebook
Acer Aspire 5520g continuous restart on off problem
try cleaning the air vents with a hoover. worked for me mine kept overheating and shutting down it was down to dust
Mar 16, 2010 | Acer Aspire 5520-5908 Notebook
Acer Laptop runs but shuts off suddenly
this is an overheating problem, computer have a thermal protection sensor that senses extreme temp.
i suggest return to your service provider and have them check again, it could probably cause by, the fan isnt plug or there is a lot ob obstruction to exhaust that tned to build up heat around your pc
Aug 03, 2009 | Acer Aspire 5720-6661 Notebook PC
Acer aspire 5610-4654 keeps shutting down
Did you noticed overheating (hot laptop areas, fans spinning like in crazy?)
Can you start the laptop again just after it shuts down itself??
Jan 18, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire 3000 notebook constantly overheating and shutting off
purchase what they call a chill pad... it plugs into a usb port on the laptop and has two fans... you set the laptop on top of it....
Robert
Jan 05, 2009 | Acer Aspire 3000 Notebook
Computers & Internet Logo
81 people viewed this question
Alun Cox
David Payne
David Payne
