Cmputer hangs whenever I run a vrus scan or downloadin something from net, or do a multi tasking , my computer stops suddenly. I had to restart manualy.
    Novelist:
  • 104 Answers
Just Restart the OS and check coolers and basically the temperature of the system. Either you have problems with that or a piece of hardware has problems, HD or RAM. But first thing first, Reinstall OS. That can happen because of almost thousand reasons... so Good Luck
(if you are clueless on this, take your computer to a technician, is that so expensive?)
Posted on Mar 10, 2008
  • Carpenocte Carpediem
    Carpenocte Carpediem Mar 14, 2008
    Well... I see you did not solve the problem so here is what you sould do: PLEASE EXCUSE ME if I go too far, I dont know your level of experience on this... AND I assume your hardware is highly compatible and it once worked perfectly.
    if you have no knowledge of hardware you should not touch any part of the computer and just try a testing software that could give you a close idea of what is happening. One of them is called DOC memoy, its for RAM, SpinRite and HD recovery for HDs, and find an stress test software, there are some free on the net...
    if that soft tells you that you have a problem you will know where and if it hangs it is almost obvious u have hardware problems.
    if you think you can manage the problem yourself try this simple steps and if its your first time get some manuals about your hardware and read a little before starting:
    KNOW THIS AND I GO AGAIN: ANYTHING COULD CAUSE THAT KIND OF PROBLEM, so please try to understand that nobody can know exactly what is happening without seeing your computer first.
    STEP 1- Isolate the problem:
    FIRST THING IS TO ENSURE YOUR PROBLEM IS NOT THE SOFTWARE YOU ARE USING.
    you gotta find where the problem is, CPU; RAM; HD; OPTICAL DRIVES; MOTHERBOARD; POWER SUPPLY; SOFT...
    so just disassemble your system step by step. All you need to run almost any program is a good installed and configures operative system. First thing to do is install Windows or whatever you use. New clean installation without connecting to Internet at any moment nor upgrading a thing.
    get the latest STABLE drivers for each hardware you have from their respective website.
    look for the latest bios version for *********** on your mothers website and see what that bios version fixes... your problem might be registered there, so get the new bios and a windows over bios flashing software, if you run over ASUS motherboard much better and easyer.
    Once you have this just upgrade bios, install OS and the last stable drivers you just got from the net. DO NOT INSTALL ANY RARE SOFTWARE... DO NOT UPGRADE NOTHING, DO NOT CONNECT TO THE INTERNET at this point.
    ---if you have a good safe copy of you installing OS and you experience problems installing it... you might have hardware problems so, bad news. In this case skip the following and go to the next part---
    Install then a common perfectly working software like a good version of photoshop CS... if you know how to use it... some good working game. If you have Windows XP Pro do not go further than Service Pack 2. Do not install a newer Direct X version.
    photoshop would make a good test if you open a new 600 pixels document insert anything, image, photo in that document and just add a zoom efect or any good filter to the total image at maximung quality. If that does not hangs your system you started ok. You can do the same with 3D software, Videogames, but not with word, excel or playing movies... so try with heavy software first. After that install the software you use ONE BY ONE and use the computer whith that software for awhile so you will know at last if you have software problems. Just at the end install antivirus or any security programs and upgrade ONE BY ONE so you will know if the problem comes from the net.
    ---I have this recommendes configuration for home users:
    Windows XP pro SP2 NEVER UPDATED with the firewall DOWN.
    Drivers
    Acrobat Reader 5
    Office 2003
    Nero
    WinRAR
    kLite Codecs Pack
    X vid codec
    Firefox (try not using internet explorer)
    MSN if necessary...
    Winamp3 (dont go further on this, is not necessary)
    Kaspersky is the best AV I know, any version.
    NOTHING ELSE for a basic System.
    If you can, AVOID ARES or P2P soft, its better Torrents soft, but well... as you know something are not always found in Torrents.--
    IF THE PROBLEM PERSISTS:
    STEP 2. Check Hardware:
    Enter BIOS and check systems temperature and power supply voltage. (3, 5 and 12 volts should be OK if they dont go either much up nor down) CPUs generally work fine to 70 degrees, remember that when you run heavy soft, that temp will go up so BIOS number is just a vague guess)
    Go soft first: take RAM out, take CPU out and any video board, modem, lan adapter and every connected cable to che motherboard.
    Then give a good cleaning to motherboard.
    Then replace the sink material of the processor... that white or gray or silver thing over the microprocessors chip. You can buy it cheaper than 5 dollars y guess, and its very important.
    Then put the CPU and the cleanned Cooler back in place.
    Put the cleanned RAM in slots and connect ONLY the needed cables, those for start the system.
    Connect HD and if you want to install OS just one CD/DVD unit.
    Make sure your power supply is clean.
    Start the system and try what I told before.
    That should be all...
    STEP 3. Calm Down:
    It all can work with patience. You have to be really unlucky if the problem comes from external things so lets concentrate in the machine in this case.
    If you have a clean OS and clean soft and in this conditions you experience problems, I mean with nothing else than Mother, CPU, RAM and HD, some of them has problems...
    a. disconnect cd/dvd unit if you have it connected, floppy too if you have;
    b. try again;
    still if you have only the basic stuff connected and there are problems, either ***********, ram, cpu or HD is busted.
    You can discard HD by trying a LIVE OS, windos or linux, in any case you dont need nothing else than downloading one and burn it into a cd and just boot up and play awhile, dont need knowledge of anything to do so. If you have come to this poing and a live os works fine... then your HD might be your problem.
    Its very rare that a CPU fails... I wouldnt count on that
    Its very rare RAM fail if its good like kingston or corssair for example and its very common that any motherboard fails... specially if it is a cheap one (under 80$)
    Well I will be here, try some of this and get back to me if you wish... Good Luck
My cmputer is not freezing just the virus scan.
Probably the AV needs a update for the latest virus definitions available in the market. kindly update the AV online and try running the scan. It should solve the issue.
Oct 11, 2016 | AVAST Software Avast Free Antivirus
I have the NEC versa E6200. Whenever i use it, for about 2 min to 3 min, the computer started to hang and not responding. What should I do??
Have you run a Virus scan and a malware scan? when you say" Whenever i use it, for about 2 min to 3 min, the computer started to hang and not responding" whenever I use it means what just moving the cursor or going online, opening a program etc. could you be a bit more specific that would help in the diagnosis.
Oct 31, 2012 | Computers & Internet
Laptop dell inspiron n5010 hanging suddenly
There are many things that might cause your PC to run slowly or restart at time and then. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. Here is a few good virus scanners that you can run to check your PC:
http://c74b6qq6lbo8zlievtv2q810g1.hop.clickbank.net/?tid=DMWDH6W3
Nov 24, 2011 | Dell Computers & Internet
Its benn hang why?
if you mean your computer hangs
you might have to many programs running at the same time you are playing games putting to much strain on the CPU
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start tick in both boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then click start all programs accessories system tools defragment your hard drive
you might have to install more RAM random access memory to check how much ram you have
to check the details on your computer
click start all programs accessories system tools system imformation you will see all of your computers imformation from there another way of doing this
click start right click on my computer select properties you will see all imformation about your computer including installed ram
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer if you see something running that you don
Jul 19, 2011 | Foxconn Computers & Internet
I have Kaspersky antivirus 2010. Whenever i start full scan it get stuck to some random percentage.then it shutdown my PC.When restart it and look for KAV 2010.it says ''Malfunction unknown,the task was...
in my experience kaspersky 2010 has many issues like this. during the scan the system will get stuck and once you restart it will say like files missing something like that. i advice you to use mcfee internet security. its very nice
Apr 14, 2010 | Kaspersky Labs Antivirus 2010 Full Version...
Whenever I start scan, it stops responding after 5
your window can come up again:
1 open taksmanager
2 click on new task button
3 type explorer.exe
your window will come again.
in regards to antivirus:
i think u have to reinstall freshly, the present copy has become corrupted.
Feb 10, 2010 | Symantec AntiVirus Scan Engine
Computer has viruses which might be why it has a the blue screen
Try entering safe mode and doing the virus scan:
  • Switch on your PC
  • Before the Windows Logo screen appears press F8 to get the startup options menu
  • Chose Safe Mode
  • Once your computer boots, run AVG and let it remove all the viruses. Reboot and it should go into Windows as normal.You might have to rerun the scan a few times to get rid of everything but it should do the job.
May 17, 2009 | E-Machines eMachines W2686 PC Desktop
Most of the time my Nikon 5000 works well. Recently I encounter the following problem. After several normal scans the program stops after the physical scan. (can hear from the scanner movment.) Nothing...
Hi, I have the same problem. I am running on the same computer with the same software Nikon Scan without problems. Found out that the problem happens mostly when a crop is selected that just eliminates the scanning frame. Without crop mostly OK. However no reason why and no real solution
Apr 15, 2009 | Nikon COOLSCAN 5000 ED Film Scanner
My computer experience errors, suddenly hangs up, freezes whenever i do video calls..
This may not be with the computer, it could be with your internet provider. If you have a bad or unstable internet connection, then a minor glitch or quick loss of connectivity will cause you to lose the call, even if the glitch is almost unnoticeable. If connected wirelessly, then try a cable and hardwire directly to the net, a wireless glitch could do the same.
Aug 02, 2008 | Dell XPS M1330 Notebook
Computers & Internet Logo
125 people viewed this question
David Payne
David Payne
