Question about Kenwood DVD NAVIGATION SYSTEM Car Video Player
Kenwood navigation system not working after car battery dies
I have the kenwood navigation system in my 2002 honda crv. yesterday, i accidently left the lights on and ran the battery down. i had left them on for about an hour and a half, then jump started the car and ran it again. prior to that the navigation system worked perfectly in every way. since the battery was run down, it now doesn't display properly. audio passes through it ok, but the display is unusably dim and unreadable. i've run the car last night and today, it works fine and the battery seems to be doing fine. however, the kenwood system still has the display problem. is there something i can do to get this working again. i expected to perhaps lose my radio station presets, but don't understand how the display is still effected. did jump starting the car hurt it somehow? any ideas as to what about that situation would have effected the display?
mixmaster
  • 626 Answers
SOURCE: kenwood mpe system flashing protect
"PROTECT" means that the unit's thermal protection units were activated, which in turn cut off output power to the speakers. The causes for this vary. Usually, it's a problem with the impedance load that the speakers present to the power amplifier inside the receiver. Occasionally, the circuit acts up and activates itself, or playing the unit too loudly has blown a fuse. First, check all the user servicable fuses. You'll find their location and amperage rating in the user's manual. If they're broken, replace them. Make sure that none of the bare wire from any speaker is touching any bare wire from any other speaker. If the unit still won't power up, then I'm afraid you'll have to take it into the shop for evaluation by a qualified repair technician. Best of Luck.
Posted on Sep 14, 2007
hawkwatcher
  • 67 Answers
SOURCE: kenwood kvt 715dvd
I have seen problems in the hideaway (brain) where 8v reg circuit fails causing higher voltage(12v to 14v) to be on that 8v line. First component to fail is the Tuner followed by electronic volume ic. I have probably seen 6-8 failures where tuner fails. Fix is to replace tuner and replace open chip resistor in Hideaway box to restore 8v regulator to proper voltage. kstahl65@att.net
Posted on Feb 29, 2008
SOURCE: Display on a Kenwood KDC-MP532U radio
not grounded well at all ground it man form main bolt on back to car chisis bet wont happen again
Posted on Mar 14, 2008
hawkwatcher
  • 67 Answers
SOURCE: Kenwood KVT-715 Radio not working
I would be willing to bet you have a 8v regulator circuit failure in hideaway Box. I have seen many of these units where a resistor opens and causes 12v instead of 8v to appear at tuner and a few other IC's. Usually But not always destroys tuner.
kstahl65@att.net if there are questions
Posted on Apr 21, 2008
SOURCE: Kenwood DDX7017 Screen has no color and it won't eject
Had the same thing happen to me. All you have to do is use a pen or a paper clip and push the reset button located on the front of the unit. It cleared right up.
Posted on Dec 14, 2008
Where is the fuse for the air conditioning compressor in a 2002 Honda CRV. I know where the fuses are located, but don't know which one is for the a/c compressor since no fuse is labeled as such.
There is a fuse panel under the hood,,on the right side.. behind the battery.. under the black lid.. be careful ..Honda CRV is NOTORIOUS for bad A/C SYSTEMS!!!
If you need work,, get SEVERAL OPINIONS!!
Jun 14, 2017 | 2002 Honda CR-V
Crv wont start
Start by making sure the battery has at least 10.4 volts and that the cable clamps are clean and tight on the battery posts. If these are good, check the wiring to the starter. Make sure the "small" wire is pushed all the way into the connector and the "big" wire is tight against it's post. If all this is good and it still won't start, I would check to see if full battery power is going to the started on the "big" cable. If not, you need to back track the wiring to see where power stops. Possibly the alarm system is activated or the ignition switch has gone bad or the fuse for the ignition system is blown because of the old starter. Of course, start with the fuse check first.
Apr 04, 2014 | 2002 Honda CR-V
2002 Honda crv headlights were left on, they were turned off before battery drained, started fine in morning but on the way to work power drained down until vehicle died, replaced battery and now battery...
Check to see if alternator is charging. Battery light is an indicator that your alternator is not charging. Start engine use multimeter at battery 20 v dc or if autorange meter just dc. engine at idle the battery should read 14 - 14.5 volts. if not replace alternator.
Oct 19, 2012 | 2002 Honda CR-V
My 2002 Honda CRV Vwarning tones for key left in ignition
broken drivers door switch you will find it has come apart can clip back together or new switch
Sep 24, 2009 | 2002 Honda CR-V
From Japanese to English Honda CRV Navigation and Sound System
Hi David, since there's no english language support in honda navi systems, my suggestion is to scrap the head unit and buy an aftermarket one. Kenwood or JVC 2-din units are compatible with honda system. If you have steering control, install SWI interface module (google: pac swi). Ff you have reverse camera, make sure the player have CCD input.
Aug 11, 2009 | OEM Systems Car Audio & Video
2002 honda CRV radio code
look under ashtray, or pull radio and look on it
Aug 07, 2009 | 2002 Honda CR-V
2007 Honda CRV failed emission - Battery died
I know a website that has every info on all vehicles and vehicle problems, with their solution In detail.. it's
www.reliable-store.com
Mar 04, 2018 | 2007 Honda CR-V
2002 Honda CRV 4WD problems (accelleration problems)
check your ball joints, and your alignment those might affect the steering.
Mar 07, 2009 | 2002 Honda CR 125 R
Navigation System Disc in Honda CRV not working
your best possible solution is to take it to the dealer they most like ly will have to download a programing patch to repair the problem.
Aug 29, 2008 | 2005 Honda CR-V
Car Audio & Video Logo
204 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
