Question about Dryers
Amana dryer sqeaks at start up
When I first start the Amjana dryer there is a loud sqeaking noise until it warms up. I think it might be the belt. How do you take off the front panel
Theresa
  • Anonymous Mar 14, 2014
    dryer belt sqeaking
  • 247 Answers
Going in through the front is usually an absolute last resort when working on white goods. Based on experience with other machines (I don't know yours):
If you pull the dryer out then tip it back a bit, you may be able to get to some of the components through the bottom.
There is almost certainly a large access panel on the back (probably your best way in if you have belt problems).
Working from the back of the machine, if you take some of the top edge trim off, you will probably be able to get the top cover off if you need to.
A.
Posted on Mar 09, 2008
Ge gas dryer making loud noise
what kind of loud noise ? is it a sqeaking/squealing noise ?
Jul 22, 2014 | GE DBXR463GB Gas Dryer
I have a 2000 dodge caravan 3.0 engine there a sqeak noise when i first crank the motor up until it warms up i replaced the idler pully 6 months ago but it still sqeaks i can move the tensioner pully a...
I can't say for sure but it could be the tensioner pully. I don't think you should be able to move it side to side. That would indicate that the bearing is worn.
Nov 03, 2017 | 2000 Dodge Caravan
1995 GMC SONOMA makes a loud sqeaking noise when i take off in the first to third gear, after third gear it stops, but when i get to a stop sighn it starts all back over, loud noise.
This type of noise is likely to be a universal joint that is worn out in the drive line. have a shop put it on a lift and inspect the joints.
Jun 06, 2012 | 1995 GMC Sonoma
When I start car it makes a loud sqeaking noise what is that?
either the belt is worn and causing this or one of the pulleys on the motor may be causing this if the belt is good remove the belt and test the diff pulleys by spining them with your hand wiggling each one and see if they are loose. hope this helps
Jan 25, 2011 | 1990 Chevrolet Cavalier
Loud sqeak when turning. Front of drum seems loose.
The rollers that the drum rides on are worn and need replaced.
May 20, 2010 | Dryers
Dryer making sqeaking noise
greetings,
the most likely answer is the belt pulley..the rollers can also make noise,but they usually will make a thump thump noise..remove belt pulley and lubricate and see if this helps
May 17, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
GE Clothes dryer squeaks
My ge electricryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Jun 19, 2009 | GE DWXR483EBCC Electric Dryer
My dryer is sqeaking loudly when running
Squeaking usually comes from drum roller supports and/or the belt idler pulley needing lubricated. If the drum does not have drum roller supports under the drum, it will be equipped with a plastic drum glide the is located around the perimeter of the front drum facing. If this plastic wears down it will cause the drum to scrape against the metal bulkhead and make noise. If equipped, you need to replace the drum glide
The drum rollers (if equipped) can be lubricated with a light weight turbine oil (like the kind you would lubricate some ceiling fan motors with). Lubricate the roller wheels at the axle ONLY. Do not lubricate the wheels. The same is true for the idler pulley. Make sure you don't get any oil on the belt, or it will slip.
If you need instructions on how to reinstall the drive belt, repairclinic.com has dryer belt diagram illustrations under their "Repair Help" section. Look for the "Dryer Belt Diagram" link on the left hand side of the page. If your dryer is a GE model, you would use diagram M, D, or L (depending on the age of the dryer).
If you have questions, let me know. I hope this helps you.
May 06, 2009 | GE 7.0 Cu. Ft. Super Capacity Gas Dryer
Amana dryer, sqeaks, very loud, makes alot of noise. Someone said it needs a belt. How do you change the belt. We lifted the top and the drum is loose.
Try leveling the dryer The outside cab is the bearing for the drum a little twist and adjusting can fix it. You can also try some belt dressing
Jan 23, 2009 | Dryers
Dryers Logo
60 people viewed this question
Top Dryers Experts
Marvin
Marvin
