Question about Mitsubishi Televison & Video
MY WD-52327 has a small area (approx 1"-1") toward the top right hand corner of the screen that appears to be cloudy. It's gray and really only appears against lighter pictures. Any thoughts?
  • Anonymous Mar 19, 2014
    picture has not much color and appears cloudy
I had the same issue with mine in different areas of the screen. Really got to me one night while trying to watch a movie. I ended up taking the screen off the front and found numerous dust bunnies on the mirrors and a spider web in one of the corners. Cleaned up and blew out with canned air. Was crystal clear again with no spots.
Posted on Sep 11, 2008
Case hook up /power
http://global.aopen.com/products_download.aspx?sDropDownProd=52
i55HMt-HD / Manual / User's Manual / English / 12/15/2010
Click on small icon above 1127.6 KB
(Icon is a Floppy Disk drive with a Red arrow above it)
There is a small window that opens up.
Go to the bottom under the Mirror Sites heading.
To the right of the country nearest yours click on the blue ftp site.
I'm going to choose USA, San Jose, as an example.
I click on - ftp://ftp.aopen.com
After a few seconds the manual downloads. It is still in the small window. Go to the Maximize icon at the top right corner of the window, and click on it.
(Next to the Red X)
Now hover your mouse cursor down at the Bottom/Middle.
The ghosted out Navigation Guide will appear.
Go to the far right, and click on the Adobe Reader icon.
[When your mouse cursor is above it - Show Adobe Reader toolbar -
appears ]
Use the Plus ( + ) icon at the top of the file to increase the view size,
use the Minus ( - ) icon to decrease the view size.
Go to Page 14 - 2.7 Connecting Front Panel Cable
The motherboard is shown clocked 90 degrees to the right, from how it actually sits in the computer case.
Processor socket to the Top, Ram Memory slots to the Right, white long PCI slot to the bottom;
The Front Panel header is to the Top edge, and towards the right.
[The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header ]
Situated in the computer case, the Front Panel header is along the top edge. It is parallel to the top edge, and is two rows of contact pins.
20 pins. 10 across the Top, 10 across the Bottom.
Pins across the Top row are numbered ODD.
Pins across the Bottom row are numbered EVEN.
Starting on the Right side on the Top row, and going towards the Left;
Pins 1, 3, 5, 7, 9, 11, 13, 15, 17, and 19
Starting on the Right side on the Bottom row, and going towards the Left;
Pins 2, 4, 6, 8, 10, 12, 14, 16, 18, and 20.
A) Pins 1 and 3 are N/C. Not Connected (White area)
B) Pins 7 and 9 are for the HarDDrive activity LED.
(Middle two pins in Orange area)
C) Pins 13, 15, 17, and 19 are for a Speaker. Internal speaker for the BIOS Beep Codes.
Pin 13 is for the Positive ( + ) wire
(Gray area)
D) Pins 2 and 4 are for a Reset switch, IF a Reset switch is used.
(Purple area)
E) Pins 12, 14, and 16 are for the Power On LED light.
Pins 12, 14, and 16 are used for a Power On LED light that has 3 wires. The LED has dual colors. (Green/Yellow?)
For a two wire Power On LED it is Pin 12, and Pin 14.
(Green area for all 3 pins)
F) Pins 18 and 20 are for the Power On switch.
(Pink or Red area)
Front USB headers are on Page 15.
Front Audio headers are on Page 16.
For additional questions please post in a Comment.
Regards,
joecoolvette
Sep 23, 2012 | AOpen MX46-533V (91.89U10.061) Motherboard
Tip
How to make a high battery percentage iPod Touch 4.0
<p>By default, the iPod Touch gives you the remaining battery life with an animated image of a battery. When looking at the battery icon, you can estimate your rate is available and decide whether to load it. For a more accurate indication of your battery life, you can assess the use of the battery, which tells you the exact percentage of battery life you have available. IPod touch with 4.0 IOS software you can enable this feature in a matter of seconds. <br /> <p><br /> <p>1. Tap the Settings application on your iTouch 4. From the main menu, locate the application on the first page. By default, it appears near the bottom of the screen, indicated by a gray icon. <br /> <p><br /> <p>2. Tap "General". It has a small version of the same gray icon that you have already entered. <br /> <p><br /> <p>3. Tap the "Use" option, you can find near the top of its "General" options screen. You will see a list of relevant information about the battery life, including the extent of use since the last load and the amount of waiting time since your last payment. <br /> <p><br /> <p>4. Touch the cartoon "Battery Percent" switch on top of the screen. Tap the button to toggle between "On" and "Off" options. By switching to "On", the percentage of your battery available in the upper right corner of the screen. Tap again to "Off" position when you want to remove the percent sign, the battery of your screen. <br />
on Aug 05, 2011 | Computers & Internet
Hi, I have an Hitachi 42PD9700 plasma TV. When the TV is off you can see a mottled/patchy area on the top right hand side of the screen (this is still visible when the TV is on if you look closely). This...
Same problem. Gray clouds INSIDE the external (plexi)glass of the screen.
I guess either:
1 - Screen collection dust or some electrostatic phenomenon.
or
2 - Some coating peeling off.
1 may be solved by dismounting and cleaning.
Any solution you know about ?
Sep 22, 2011 | Hitachi Televison & Video
Have dark smoky cloudy look in top left corner approx. one sixth of screen.
i suppose u broken the top left corner of your screen due to which the liquid crystal inside it is spreading n the screen.
Feb 10, 2011 | Televison & Video
Loaded mozilla and screen did not appear fully.
Right click on the bar along the bottem of the screen, and a menu should pop up, near the top of menu click cascade windows, the mozilla window should go to the top left corner of your screen. with the mouse cursor go to the bottom right hand corner of the window and an arrow should appear keep the right click button held down and drag the window diagnally towards the bottom cornner of the screen and you should then have full screen window.
Jan 22, 2010 | Mozilla Firefox
Shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
Jan 04, 2009 | Sylvania 6626LCT 26 in. LCD Television
Solid Line Across Screen
Suspect the Light Engine part # 939P977010
Feb 21, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Grey icon; top righthand corner
It probably is a mode you are in, try switching your modes, is this the picture you are seeing up in the right, the gray icon?6719dfc.jpg
Nov 17, 2007 | Pentax Optio M10 Digital Camera
Televison & Video Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
