Question about Maytag Washing Machines
My maytag washer ha606 shakes when spin dry. What is it? How can i fix it?
Make sure your unit is level in both directions.
Posted on Jul 22, 2008
Maytag Performa Washer PAV1000AWW. Shakes when spinning out
My washer doesnt drain in the rinse cycle?? dont kno what to do
Feb 15, 2010 | Maytag Performa PAV2200
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
Maytag Nepture washer shakes across floor
iff you remove the door assy 2 screws holding it on) andthe n the 2 screws opposite the hinge, youll be able to remove the front cover and look at the inner workings of unit, perhaps a shock absorber has broken causeing the vibration
Feb 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
Replacing the pump? on my Maytag HA606
On the front of the unit, about 2inches above the floor you will find 2 screws towards the outer edges. Remove the two screws and lift the bottom of the front up and it should snap out at the top. The motor and pump should be visible once the front is removed.
It sounds like you may have a problem with your timer not advancing.
Jul 13, 2008 | Washing Machines
Spin Cycle
Yes its true the main support bearing is part of the outer tub and is factory set .Dry bearing will roar until it develops a leak and eventually starts a main pulley shake that will cut through the back of the outer tubs shell.The outer tub costs about $175.00(varies)the labor (please sit down)yes, is high enough for you to go out and find your self a 15 year old Maytag top load, re-build it,scrap the front load,and never see a repairman for the next 15 Years.No joke!                             I/m happy to help you with anything you need a answer to.............Sorry about your Maytag    :(
May 23, 2008 | Maytag Neptune MAH5500B Front Load Washer
Overbearing shaking and vibrating washer even when no load in it and just run empty
is the damper pad at the base dry.they need to be oily other wise the machine can vibrate badly.hope this helps.
Mar 12, 2008 | Washing Machines
Maytag top load washer
This solution applys to many Maytag washing machines. Perhaps not all.
Maytags have three damper pads in the bottom of the machine that must be lubricated from time to time. If they are not, they can be ripped off. They are glued to the bottom of the machine, the drum rests on top of them. When they become dry or lost, the machine shakes violently and no amount
of leveling or load balancing will fix it. Replace and/or lubricate the pads and magically it works again.
This is not a difficult repair for those that have modest mechanical skills and a few basic tools.
replacement pads and lube come in an inexpensive kit.n
I will create a web page with instructions if there is interest.
Jan 28, 2008 | Maytag Neptune Washer
Top load washer
I am having this same issue, has anyone found the solution to this issue?
Oct 14, 2007 | Maytag PAV3240A Top Load Washer
Washing Machines Logo
70 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
