Question about Compaq Evo N610C Notebook
Adding memory stick to Evo N610c
I purchased a 512 mb RAM "memory stick" from HP/Compaq and they guaranteed it was right for this unit and was easy to install. Their tech support doesn't know about business laptops (only residential) unless I pay a fee to tech support in India to someone I have great difficulty explaining & understanding them. My local computer store did not know by looking at it & said they would research it for me & get back to me...never got back to me.
PLEASE! Does antone know how/if I can install this?
Thank you so much
Stilla9erfan@att.net
    Problem Solver:
  • 11 Answers
I am sending you a link which describes the replacement of the Memory stick in the computer. Please check it out and let me know if this helps. The link is as follows:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01122797/c01122797.pdf
Do get back in case you need more information.
Posted on Mar 09, 2008
I want to upgarde my compaq evo n1000c laptop. i want to increase my processor and graphic card, can it happen ????
Not graphics card, sometimes the processor although HP are usualy keen on intergrating it onto the motherboard...so in short..NO!
Mar 17, 2011 | HP Compaq Evo Notebook N1000c
How do i add more memory to my evo n600c compaq laptop which only has 256 memory
max memory is 512. you need to buy it and take out the 256 and install 512
May 10, 2009 | Compaq Evo N610C Notebook
RAM increment
yes just pur chase 1 128 MB or 512 MB or 256 MB ram but check first *********** bord ram module
check your old 64 Mb ram if it has 1 notch it is ddr1 or ddr2 if it has 2 notch it iks sdram
then pur chase from shop.
then fix it on secodn slot
Apr 24, 2009 | Compaq Presario 5000 PC Desktop
How much more memory can I install
This laptop can support up to a max of 1 GB of RAM , so if you buy 1 stick of 1 GB of RAM you need to take out the 768 MB and just put the 1 stick of 1 GB RAM, or your other option is to buy a 256 MB of RMA so your computer will still have a max of 1 GB of RAM and that would be cheaper and you can still use your old RMA on your laptop , this is the lin for the complete specs of your laptop http://www.dealtime.com/xPF-Compaq-Refurbished-COMPAQ-P4-M-1-8GHZ-256MB-30GB-14-1-TFT-CDRW-W-XP
Hope that helps...........
Sep 28, 2008 | Compaq Evo N610C Notebook
Can I install 1 gb ram into a compaq evo n610c
Yes u can Install 1 GB RAM and u can use any kind of
flathead screwdriver to remove the cover
http://www.edgetechcorp.com/memory/upgrade.asp?cid=25412
In this see the Installation Help it is having a video how to fix the Memory Module
Jul 28, 2008 | Compaq Evo N610C Notebook
Can I install 1gb of ram on a compaq evo n610c
Yes, Memory Upgrade for Compaq Evo N610C, the Compaq Evo N610C takes the PC2100 DDR SDRAM SODIMMs to a max of 1gig - and two 512 would be perfect.
The memory modules in a Compaq Evo N610C are not located where you expect them to be.
Here's how to do it.
Open the notebook, and place your fingers on the keyboard as if you were going to type. There is a panel directly beneath your left palm, just below the Ctrl and Alt keys. The panel is hooked into the front of the frame closest to you. Using a thin flathead screwdriver or knife blade, apply a bit of pressure on the panel so that you're pushing it towards the LCD while prying it up. The panel will come right off and you'll have direct access to the memory modules.
Compaq evo n610C adding ram
Hi, the ram is located under a cover to the left of the mouse pad, you need a flat blade screw driver to pop it open.
Jun 26, 2008 | Compaq Evo N610C Notebook
Blue Screen of death
According to this link, the memory of Compaq Evo N610c can be upgradable to 1024 mb.
http://h18000.www1.hp.com/products/quickspecs/11382_div/11382_div.HTML
Memory Upgrade for Compaq Evo N610C, the Compaq Evo N610C takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with of Memory. You can upgrade your Compaq Evo N610C to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with standard Memory installed. For best system performance use the maximum amount of allowed Memory per slot for your system. (Souce: http://www.memorystock.com/memory/CompaqEvoN610C.html)
So you have to install 512mb memory module on each slot to make up 1024mb of memory.
Did you install 512mb memory module on each slot or did you just install 1GB memory module in one slot?
Try to go back to 256mb RAM and see if you will have the same blue screen error. If you did not receive any blue screen, try to add memory into it or just insert 512mb first and then oserve again if you will have the blue screen error.
You may also want to go to these links for other suggestions.
http://www.pcfixreview.com/blog/2007/07/12/bad-pool-caller/
http://www.registrysimple.com/bad-pool-caller-fix.php
May 08, 2008 | Compaq Evo N610C Notebook
How to upgrade memory for compaq evo n610c?
The maximum amount of memory you can install is 1GB 266 Mhz SDRAM DDR SDRAM (512 -MB in slots 1 and 2)
The motherboard will not handle any amounts larger.
It is suggested that you use Compaq branded memory to ensure compatibility with what you have. Otherwise, pick two chips that are the same.
http://h18000.www1.hp.com/products/quickspecs/11382_div/11382_div.HTML#Overview
This site will show you where to find the location of the memory.
The slots are below the keyboard to the rightr of the track pad. THe "Tabs" that hold the lid down can be seen if you look at the bottom left of the keyboard area. You need a flathead screwdriver size small to remove the lid.
Apr 18, 2008 | Computers & Internet
Compaq Evo N610C Notebook Logo
157 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
