Question about Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum
Blown motor, or just a fuse?
I have the model 3750-T, and the other day I had a power surge, while vaccuming, which caused the motor in the "brush" section (the bit that makes the most noise) to stop working completely.
Basic suction works, but this thing doesn't do much anymore....it's essentially an oversized hand vac.
Wondering if anyone has had any problems like this before, i'm hoping it's a blown fuse and not a totally blown motor.
I'll see if i can pull it apart later today and find out for sure.
Any help is most appreciated,
Pat.
  • pdm08 Mar 10, 2008
    Unfortunately, it's not just the belt.
    I've taken the whole thing apart, and yeah, there are 2 motors.
    There's a motor in the canister section (removable canister on this model, handy!) and another motor in the floor brush section.
    The motor in the floor brush is the one that is dead.
    I can't actually open up the motor though, as there are some strange screws. I spoke to a vacuum repair company and they reckon the motor is dead. I am considering going to home depot and buying the appropriate screwdriver to open this little ****** and maybe trying to fix it myself.
    If there's a fuse in there, I can definitely fix it (swapping a fuse = not hard!), otherwise, I will at least be able to say I tried :)
  • Anonymous May 02, 2009
    The brushes turn, but the vacuum motor doesn't work and won't power on.
  • 247 Answers
Suggest you double check that this machine really does have a separate motor to drive the brush roller - most just have a single motor that drives the vacuum impeller directly, and the roller through a belt.
If yours is the same, then the most likely problem is a worn-out belt. Hope so, as this makes for a cheap and easy repair.
A.
Posted on Mar 09, 2008
  • Alastair Macleod
    Alastair Macleod Mar 11, 2008
    Suppose it's worth a try.
    Be careful when opening it up - there are likely to be a couple of lightly spring-loaded components in there. and while I doubt they'll p'doing out fast enough, it would be good to know which way they went in.
    While it's open, have a quick look to see what state the brushes are in.
    A.
  • Alastair Macleod
    Alastair Macleod Mar 12, 2008
    Edit:
    In last comment, for "fast enough", read "fast enough to damage your eyes".
    Oh, and when I was talking about "brushes", I meant the carbon ones in the motor, not the fibre ones for sweeping the floor.
    Not the most clear and unambiguous prose that's ever left my keyboard!
    A.
Kirby G4 was surging, then a flash of light and a pop from outlet!
the surge is caused by a faultering armture, might be caused by low carbons or sticking carbons, strip the motor down for inspection. Or take it to your local kirby service centre shop for clean and service and polish. price range from 39 to 59
Jul 07, 2017 | Kirby Vacuums
No power to Bissell 3750-E
I'd test the new fuse with a meter. I'd then plug it in and retest for power and ground to and through the switch and motor. It could be as simple as a loose or pinched wire which grounded out.
Dec 07, 2013 | Bissell 3750 Lift Off Bagless Upright...
Air driven turbo brush
Is this the Lightning model? How old is it? You may have to just replace the belt.
Also, the front brush motor will not engage until the power is turned on and the handle is in the down position. In the upright position the brush motor wont engage. Typical faults will be the belt is broken and needs replacing or the fornt brush motor needs replacing.
Nov 27, 2011 | Fantom Vacums Vacuums
Turn on the power and nothing happened. I checked the power plug. It was ok. what caused the Vaccum didn't work? Thanks, Peter
Same, I have the same issue with this model. Brush motor is working but not the vaccum motor. Any ideas?
Jul 26, 2010 | Bissell Lift-Off(R) Revolution(R) Turbo...
Bottom brush will not turn.
Did you check the drive belt? There are (Ithink) 4 screws underneath that you must remove to access that belt. It's likely the cause of your problem. Iether that or a build up of other gunk there.
Jun 03, 2010 | Bissell 3750 Lift Off Bagless Upright...
Bissell 3750-T Bagless Upright Vacuum motor is hot, noisy, and smells like it is burned out, but still working. Can I replace the motor?
There are threee filters inside this unit. Be sure all three are clean. You can't clean the Hepa filter. You can only replace it. You may even try pluging it in and running it (not while vacuuming the carpet) without the filters to see if it is clogged up anywhere. It's not uncommon to **** up an object that doesn't fit though the vaccum hose very well and for that item to cause hair etc to catch on it and plug that hose. Before you know it you have a big plug in that hose. The hose detaches easily. Look through it.
Feb 24, 2010 | Bissell 3750 Lift Off Bagless Upright...
Power nozzle for rainbow vaccum is getting power but the motor does not work nozzle model r-2800c
Hi there it's SmartAlec from NelsonVacuums.com.au here. It will either be the fuse or the motor itself. If you disconnect the wires from the fuse and join them together and it works you will know it is the fuse that needs replacing. If it does not work then it is the motor itself. Depending how competant you are you can dismantle the motor itself and check the brushes. Other than that it needs a complete new motor. If you are in australia you can contact me on 0269215200 and i can supply anything you need as i am a rainbow agent. Hope this helps - happy vacuuming :)
Sep 15, 2009 | Vacuums
Problem with D17 Animal
Probably requires a new set of motor brushes or a motor.
Aug 07, 2017 | Dyson DC17 Animal Bagless Upright Cyclonic...
Bissell Lift-Off(R) Revolution(R) Turbo Upright Vacuum Logo
301 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
