Question about Sony Playstation 3 (PS3) Console
PS3-can't find IP address
Hello, problem with getting the PS3 to find IP. We have a Linksys WRT330N router. I use MAC addresses and would like to use WPA-SPK security. I've disabled the security on both the PS3 and Linksys, but that didn't help. I've also disabled my AVG firewall, still couldn't find it.
    Genius:
  • 3,587 Answers
You need to assign an IP with PS3. Do you have the users manual for that item? and if not, what's the actual part number serial number of your PS3?
Posted on Mar 09, 2008
How to change admin username & password on cisco 2911 router
agree that turn off your modem first before trying to open the router's setup page. By default, there's no username and the password is admin on Cisco 2911
http://www.3anetwork.com/cisco-cisco2911/k9-price_p238.html
Nov 04, 2011 | Cisco 2911 Router
Need password to my cisco wireless router
For that press RESET button of your router for 10 seconds then it will automatic restart and reset. then connect router to computer lan port with lan cable. then you can access it with default ip addresshttp;//192.168.1.1 or http://192.168.1.2 Type user as 'admin" and password as "admin" or "1234" or "password" or blank then you can see configuration page of router. Then click on wireless->security then note down the password.It's your password to connect wireless.
Let me know if you need further assistance. thanks for using fixYa.
Oct 17, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Hello i need to open some ports in order for my ps3 will function properly..I need the Tcp ports open #'s (80)(443)(5223)(10070)(10080) and also need the UDP ports open #'s (3478)(3479)(3658)(10070) model...
LINKSYS ::::
NAT STRICT
Step 1 : Connect Router - Computer
Step 2 : Open Router Setup by typing http ://192.168.1.1
Step 3 : Click Applications and Gaming
Step 4 : Click DMZ
Step 5 : Select Enable and Give the IP Address of the XBOX/PS3/Wii in it
Step 6 : Click Save settings
Step 7 : Unplug the Power cord from the router and turn Off XBOX /PS3/Wii
Step 8 : Plug the power cord back to the router and wait till the lights are Solid
Step 9 : Turn on the Xbox/PS3/Wii
Step 10 : Test the Connection
Else ...
Under application and gaming you can find port range forward
There you can open the ports one by one
And give the IP Address of the PS3 for all the ports opened
Dec 21, 2010 | Linksys Wireless-G WRT54G Router
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Dear Assistants I have a router linksys compact wirless - g broadband router. model number WRT 54GC ver. 2 and i have a problem with it I cant find anywhere the WAN MAC Adress of the Linksys What to do???...
The Linksys has a device MAC address and the router issues IP addresses to the computers that are connected to it.
There is no WAN MAC address. Your ISP issues to your cable or DSL modem an unique IP address and you connect this modem into the WAN port on the Linksys router.
You enter the routers configuration address -
http://192.168.1.1
and login and configure the router.
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Normal 0 http://www.fixya.com/support/r3559128-wireless_router_security
Oct 23, 2010 | Linksys WRT54GC Compact Wireless-G...
My linksys keeps losing its connection i play on ps3 online and one minute it works then i get signed out because i have no internet connection
Try adjusting te antenna's, make sure that there are no obstacles, that are blocking the signal.
Also make sure that other devices are not interfering with your routers signal.
Read this: http://www.allinthis.com/2010/01/21/9-easy-ways-to-boost-wireless-router-signal/
Aug 19, 2010 | Linksys Wireless-G Broadband Router
How do i renew the ip adress for my linksys router ?
Goto your web browser.
Enter 192.168.1.1 and put admin for both username and password.
The admin screen for your router should have a MAC address clone feature. If you enter the MAC address (which is found on the main page of the admin screen) and change the last two boxes, it will renew the IP address. Don't change the first 4 of the mac. When putting different numbers in the last two, it has to be hex (1-8 for first digit and a-f on the second digit).
Hope this helps,
Mar 05, 2010 | Linksys Wireless-G WRT54G Router
Cannot share my cable modem connection
You need to connect a router to the cable modem.  The router then gets an IP address from Comcast and provides a gateway between the computers connected to the router.
The modem expects to communicate with a single Ethernet device, and provides an IP address to the first device that provides a piece of data called a MAC address.  By placing a router in-between, the router gets the IP address that lets you communicate on the Internet.  It provides local IP addresses to the equipment connected to the local Ethernet and "routes" those to the Internet.  You can either hook your two devices into the router if it has enough ports, or hook you switch to the router and hook your PC and PS3 into the switch.
May 05, 2009 | Linksys EtherFast EZXS16W 16-Port Ethernet...
Ps3 key change timeout using westell 6100 modem on verizon
there might be a problem with the Linksys router, the Westell 6100 should be 1st set to bridge mode in order for your router to be connected to it. or there could also be a proble on the Verizon server.
Apr 10, 2009 | Westell Wirespeed LiteLine 6110 Modem
can you try this without security, until we get the IP address issue resolved?
Mar 11, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
