Hi We have a PDP 433 HDE screen which appears to be working ok but the Media receiver box(PDP RO3E) keeps turning its self onto stand by and therefore turns the screen off An E01 screen message sometimes is displayed (cable Connection error) but Ive checked the cables and the are connected as per the manual Hope someone can help Thanks John
  • aldo_davi
    aldo_davi Sep 05, 2012
    i have the same problem
    Guru:
  • 1,894 Answers
HELLO SUR
Posted on Mar 09, 2008
  • dewan nafees ahmed Mar 09, 2008
    USE A DIFFERENT CABLE SIR
    ELSE DO A HARD RESET OF THE SET TO CLEAR THE ERROR AND THEN USE DIFFERENT CABLE AND THEN USE THE SYSTEM
    THE PROBLEM WILL GET FIXED
    THANK YOU SIR
    GOOD LUCK
    DONT FORGET TO RATE THE SOLUTION
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
Problem with audio and vidio
Is this a problem only with the cable box or also with oother sources as well?
Feb 03, 2008 | Pioneer PDP-6100HD 61 in. Plasma...
I have a Pioneer pdp-433 plasma with a media receiver pdp-ro3e. When switching it on it gave a loud pop and blew up a fuse in the meter cupboard. Now when switching it on it gives green light on receiver...
Alas, the powerblock has gone.
Common problem on this model.
Only solution is replacement powerblock.
Pioneer used to repair this for nothing even out of warranty (they did for me), but they may not be so willing now, as your tele must be at least 6 years old. Unfortunately, it will be cheaper to buy a new TV than to pay for a contractor to fix it.
Brian
Jul 13, 2009 | Pioneer PureVision PDP-4330HD 43 in....
PDP-436PG
maybe its not worth the effort. the media or turner box must corsponed with the model of the pioneer tv, in order to work.
Apr 09, 2008 | Pioneer PDP-4360HD 43 in. Plasma...
Pioneer media receiver pdp-r04u
try testing dvd player direct to tv dont use uvsal remote go to tv turn it on and change inpput to dvd see it works
Feb 06, 2008 | Pioneer PureVision PDP-4340HD 43 in....
Screen wont turn on - flashing green light
hello mark ,just had the same problem with my pioneer pdp503 hde, fixed myself and very easy to do. its the power supply board ,got mine on ebay for 109 pounds.was very easy to fit.it is the big silver panel in the center just unscrew and disconnect cabels. very commen problem in pdp . mark doran post again if you want more info
Jan 23, 2008 | Pioneer PureVision PDP-503HDE 50 in....
PDP 5030
This may help you Greger, I found this on another site and I assume your model is simular to the 503 HDE... Good Luck - Rob...
I had exactly the same problem with my 503HDE. Screen would randomly shutdown and display E01.
In my case I believe that the cable was not at fault. The power supply in the media box looks like the most likely culprit.
I dismantled the media box and removed the LARGE power supply board and checked for dry solder joints. Sure enough, where the heatsink was soldered onto the board the joints were in a bad way. I reckon this is a symptom of the fact that the media boxes for V3 Pio's get very hot - all that expanding and contracting is likely to create dry solder joints. Taking the box apart shouldn't be a problem for anyone with a reasonable level of IT type skills!
I resoldered the joints and (touch wood) I've not had a problem for over 2 months. Whilst I can't guarantee that this is the definitive fix for this problem it seems to have worked for me. I'd be interested to hear if anyone else finds this cures the E01 problem.
Not being a hardware engineer, my only doubt is why the heatsink is connected electrically to the circuit board. Would this be for earthing purposes or perhaps to do with temperature sensing? Not sure about that - rolleyes.gif
Hope this helps someone - six grand is a lot of dosh to write off!! __________________
Dec 26, 2007 | Pioneer PureVision PDP-5030HD 50 in....
PDP 503 hde will not turn on
You need a new y-drive board and possibly a couple of buffer ic's replaced.The ic's definiately need to be replaced by a tv tech.
Oct 10, 2007 | Pioneer PureVision PDP-503HDE 50 in....
Can I use media receiver PDP-R04U with PDP-436PU display?
You need the pioneer media cables hooked up to the media receiver to the plasma unit itself. each end has 2 different plugs. one has 2 thumb screws and the other is a squeezable end that clicks into place. They MUST be on before you plug in any power what so ever!!!! And yes, other information is being passed through.
C-Dog
Sep 18, 2007 | Pioneer PureVision PDP-4340HD 43 in....
Televison & Video Logo
253 people viewed this question
Top Televison & Video Experts
Electro Med Services...
