Question about Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ...
Lexmark (Invalid cartridges)
Hi
I have a Lexmark X8350, when my colour cartridge ran out I bought ink and refilled it myself. It worked for a while and then the printer said the cartridge was invalid, I cleaned the connections and must have tried about 20 times to got it working. In the end I went out and bought a genuine Lexmark cartridge but the print said that this is invalid. Any help please, bearing in mind I'm not going to spend any more money on cartridges as I can buy a new printer for the price of cartridges.
Many Thanks, Gary.
    Problem Solver:
  • 19 Answers
That printer uses Lexmark 32,33,34,35 cartridges. The branded cartridges should work. Have you contacted Lexmark's technical support center? Contact information is on www.lexmark.com. They should be able to get you going again.
Posted on Aug 28, 2009
Refilled ink printer. still shows empty on the printer,s screen
Lexmark does not recommend the use of refilled/remanufactured cartridges. These tend to degrade print quality and printer/cartridge performance.
Please note that once a cartridge is refilled, it can no longer register its ink level.
Sep 13, 2011 | Lexmark X8350 All-In-One InkJet Printer
I have inserted a new black ink cartridge (34) and get an error message 'left cartridge missing, insert black or colour photo cartridge' have peeled label off and reinserted several times but still...
Make sure you are inserting a genuine Lexmark cartridge. Try to insert a different known working cartridge, maybe your old black cartridge, to determine if your new cartridge is faulty. If inserting your old black cartridge gives you a message saying "very low ink" or something to that effect, then most probably there's something wrong with the new black cartridge. Have it replaced with a new one from the store where you bought it from. You may also contact Lexmark Technical Support Center for assistance.
Aug 12, 2011 | Lexmark X8350 All-In-One InkJet Printer
I refilled my cartridge for x2650, its full, but doesn't print I refilled my cartridge with ink myself that i bought from Argos, now it is full of ink, but still shows the message that i must replace...
Please note that Lexmark does not recommend the use of refilled cartridges. Refilled cartridges tend to degrade in print quality and performance.
You may try to re-seat the cartridge and make sure it's properly seated in the cartridge carrier. Also note that once a cartridge is refilled, it can no longer register its ink level.
Aug 11, 2011 | Lexmark X2650 All-In-One InkJet Printer
How do I reset the ink level on my lexmark x8350?
http://support.lexmark.com/index?locale=en&segment=SUPPORT&startover=y&userlocale=EN_US&question=x8350+ink+level&productCode=LEXMARK_X8350&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X8350&searchid=1280474419390#1
The above is the description page for you Lexmark printer.
Solution
Some menus on the X8310 and X8350 are repeated in the Copy Mode, Scan Mode, Fax Mode and Photo Card menus.
If you press the Menu button while in any of the above menus, two ancillary menus will be listed, Maintenance and Device Defaults.
To select either of these menus, press the check mark pattlnk_442006_155-selects.gif at the center of the navigation keys on the printer.
Maintenance Menu options View Ink Levels Clean Cartridges Align Cartridges Print Test Page Reset Defaults
Device Defaults Menu options Set Date and Time Language Country Copy Paper Photo Paper Photo Size Button Beep Power Save Timeout Caller ID Pattern
The ink levels should reset when the ink jet cartridge is installed.
Jul 30, 2010 | Lexmark X8350 All-In-One InkJet Printer
I have a lexmark x8300 printer (all in one). in the past I have been successfully using refilled black no.32 and colour no.33 cartriges. However it used to say 'low ink replace cartridge' but it had always...
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Jan 21, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
My Lexmark z22 printer will not print corretly
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
May 09, 2009 | Lexmark JetPrinter Z22 Color InkJet
I bought re-inked cartridge for Lexmark It didn't work
Yes, Lexmark has been making their new printers smarter to reject refilled cartridges. Most likely what is happening is your printer is turning off the electronics on the cartridge when it gets empty so you can't reuse that cartridge. I own a Cartridge World printer cartridge refilling store and I've even had customers return original Lexmark cartridges because their printers have rejected them. If you want to be able to refill your cartridges never buy a Lexmark printer. HP printers that use integrated print head cartridges can be refilled nicely.
Apr 13, 2009 | Lexmark JetPrinter 5000 InkJet
Refill ink not printing Lexmark x4550
take the cartridges out and clean them also clean where they go with a lint free cloth then replace them.
Jan 08, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X2530 won't accept re-inking of cartridges
This is a trick that is used on some of the HP printers. Try this, you will need at least 3 maybe 4 cartridges. The printer stores the chip ID in memory for the last 2 or 3 cartridges installed, so, take an old cartridge number 1 and install in the printer, reset power. Next step, take old cartridge 1 out and install old cartridge 2 in, let it come to ready or tell you to replace empty, then install your refilled cartridge. You just have to remove from its memory the chip ID of the refilled cartridge. You can fool it by doing this each time you refill. Can't guarantee this will work with lexmark, but it does work with HP.
Hope this helps,
Printdoctor
Dec 20, 2008 | Lexmark X8350 All-In-One InkJet Printer
Lexmark X8350 jams (and other problems) after ink cartridge refill
You have a paper jammed in the path or there is something blocking the path, try to look inside carefully.
Apr 29, 2008 | Lexmark X8350 All-In-One InkJet Printer
Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ... Logo
453 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
