Question about HP Pavilion dv4000 Notebook
Attach external hard drive
I have a firelite firewire external hard drive. The cable is a 6. It doesn't fit. I can't tell by looking at the pavilion dc4000 what size adapter cable I need. Can you tell me?
    Genius:
  • 3,587 Answers
Firewire adapters only fit into firewire sockets..if you don't have that upgrade, you most likely only have USB ports..
Posted on Mar 09, 2008
I have firelite external and it's not working. There's light but no spinning sound. what can I do?
This a firewire drive and needs to plugged into a firewire port to spin up. If you do not have a firewire port on your computer (most PC's don't) it will not work. I don't believe a firewire to USB connector will pass enough power to the drive to spin it up.
Mar 12, 2012 | SmartDisk FireLite 60 GB Hard Drive
I accidentally spilled water on my USB160 and now my computer doesn't read the drive. HELP! I
what happened when and after you spilled water on it was it connected and working at the time
did you? dry it out completely after you spilled water on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
if this fails to fix the problem you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap if this solution does not work and you might need one
hope this helps
Aug 04, 2011 | Verbatim 160GB USB FireLite: The "drive...
The drive suddenly stopped being detected by my computer. When it is plugged in the orange symbol just flashes repetitively- 6 short flashes and one long.
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
hope this helps
Apr 27, 2011 | SmartDisk FireLite - 80GB - 5400rpm - USB...
What external power does SmartDisk FireLite FWFL120-N take?
Many USB power supplies will have the right plug. I picked one up by buying a cheap USB hub, What you want to look for (most likely on the bottom of the power supply) is VOLTAGE Output: 5.0 VDC, POWER Output: 1.0 amp or (1000ma) and the center hole is the positive side. I have even seen some BluTooth earpiece charges that supply what you need.
Hope that this will help.
AAirwolf
Jul 05, 2010 | SmartDisk FireLite FWFL120 120 GB FireWire...
SmartDisk FireLite XPress 120 GB USB External Hard
Hola!!!
I have this external drive and the truth is that it is very good. But I have a s e doubt that the digital display does not turn me, and I do not know if it is broken or is it because only you connect the USB cable and did not put the current transformer 5Volts. I need someone to help me and tell me what has to be repudiation. Thank you very much!
My Email: @ gmail.com rodolfo.gomez1990
Mar 24, 2010 | SmartDisk FireLite® XPress 120 GB USB 2.0...
It seems the new macbook pro does not support the firewire connector. Is there a different wire available? It looks like the macbook pro has a firewire connection but it is much smaller than the original...
The problem lies in your cable!
The new macbook pro still uses firewire and will be compatable with your drive. It just uses a 4-pin instead of a 6-pin connector. You can get an adapter or new cable that goes from 6 to 4-pins.
They did take away firewire from the new line of plain macbooks though (shakes fist at steve jobs)
Feb 07, 2010 | SmartDisk FireLite USBFLB120 120 GB USB...
External hard drive not recognized
where can i find the software for my smartdisk firelite 160gb
Dec 18, 2009 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
I'm having problems connecting FireLite portable hard drives to my mc.
1. Check operating system version sometimes its just the version not all mac versions like externals.
2. Under disk manager if the drive does not appear 9 times out of 10 its not compatable with the os your using.
Thanks
Sep 17, 2009 | SmartDisk 160GB FIRELITE PORTABLE FIREWIRE...
Miising power supply
It takes a 5V adapter
Here is the part number
C14627 - AC ADAPTER FOR USB BUS-POWERED FIRELITE - ACFLB
Hope this helps!
Feb 27, 2009 | SmartDisk 40GB - 4200rpm - 40MBps - IEEE...
I have aSmartDisk Firelite FWFL80-N, the firewire ports are producing a weak connection connection
Problem may not be the case. If you holding the cord the port that the cord hooks into is going bad. Do the cheap repairs first, check the connection or replace the cable first then the case.
rmatheson@wowway.com
Sep 30, 2008 | SmartDisk FireLite 80GB 400Mbps FireWire...
HP Pavilion dv4000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
