The old XD card corrupted on my camera, so i bought a new 2 G XD card. When I insert the card the window opens to Card Setup. I go to Format the card, get ready to say YES and a message tells me "Caution: erasing all." If I say YES a new window says Card Error. If I say no, then the power is shut off. Is is the camera or both cards? IF it is the camera, can I quickly fix it myself or do I need to send the camera in for repairs? Please help!!
-   I can't read my 1 GB XD card on my Stylus 500. Olympus support says that it's supposed to be compatible with 1 GB & 2 GB cards. The camera was made in 2005 when there wasn't any 1 GB XD cards.
All tech support could say is it could be your card reader. But my reader does fine with the 256MG XD card for the same camera.
-   raylynnwilli
Mar 29, 2009
-   The Olympus Digital cameras that are approx 5mega pixcels or less will only work with less than 1G or less cards. A C-350 will only work with 256 or less cards. The XD cards are the best quality by design on the market. XD cards can be taken to a high end camera shop and for little or no cost the contents can be rescued and be reformated. For that matter they might replace the card for free!! My Fuji S8000 camera that takes XD & SD cards firm ware is designed for 1G or less, it will run 2G. I was advised not to format the card in the camera and not to fill the card with files that are greater than 1G. Advice: If you wish to take panaramic photos, use the soft ware that comes with the FUJIFILM XD or SD cards called Panorama Maker 4, and you can join any photo to any photo. Olyimpus cards lock in the order of the photos taken and cant be changed easley!! -   Tech Guy
Mar 02, 2009
-   I have tried several 1gig cards and still have the same symptions as all others.-   ghadd
Feb 22, 2009
-   help me.....i have the same problem as above, and i have some pics on it that I DO NOT WANT TO LOSE!!!! i try to put the card into my computer, and the auto play thing doesnt pop up for some reason......SOMEONE PLEASE HELP ME?!?!?!?!?!? however my camera isnt the same camera as above, i do believe it different, i just dont know where the book on it is....so i dont know how to tell which model or whatever mine is.........
-   the_brandy
Apr 05, 2008
-   I have the same problem with a 1G memory card. I looked up the specs on this camera. The max memory listed is 256 M.
But, the only reason I bought the 1G card was because the camera started giving the memory card error message on the old 128 M card I bought when I got the camera.
I now have a card reader on my computer and I reformatted the 128M card using my computer and it now seems to work ok in the camera. The 1G card is ok in the computer, but won't work in the camera.
I think that memory cards above 256 M aren't supported by this camera.-   Sandw15
- My card was doing the same thing.
Solution: with the card not being read by your PC automatically.
If you can identify the Drive slot such as Removable disc :F or :J of :G etc. Then right click on the letter and select explore. Then open the file "Oly" for Olympic Or Fuji which is the storage file on the card that your camera writes to.
The you can highlight the photos you want and Right click and use cut to remove photos permanently or copy to copy photos to paste the photos in to the folder you choose, or you can click drag and drop.
My in built card reader was not reading my cards, so I VERY CARFULLY pulled the card reader lead out from the mother board while on, then pushed back in ofter 10 seconds and it then discoverd the card reader and the card as if I had pulled the card out and pushed it in again.
When a card reader is reading a card the LED light will come on do not remove the card while the card is loading. Right click the same as explore and select eject before removing!!!
Mar 30, 2009
- The older Olympus Digital cameras take 256k and no larger.
Long term, get a good used or a new Olympus that suites your needs. The XD cards will fit the Fuji cameras but not all Fuji cameras as the older Fuji cameras use SD cards.
The XD M or H cards are faster loading and as a result you can take possibly double the photos without flash on the same batteries as they more power efficient.
Mar 30, 2009
- When you obtain the maximum size card that suits your camera as the older cameras don't recognize larger cards ( ph call to Olympus will help), you should then format the card to suit the camera. In my case I have an Olympus and a Fuji and I swop cards between them with out formatting without any major problems. If I need a particular photo on that card I right click the card click explore in my card reader and open ether Oly or Fuji file. When cleaning out a card DON"T delet these files, just the photos. If you delete all the files and the files that contain the photos you might have to FORMAT the card!!!! If you need to formot the card, your nearest quality camer shop might do it for free!!!
Mar 30, 2009
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Olympus Camedia C-350 / D-560
I have a Dual-Smart 800 Crystal digital camera and when I plug it in my computer can't upload the...
(More)
I have a Dual-Smart 800 Crystal digital camera and when I plug it in my computer can't upload the pics..
Display is mirrored. Only way to read or see various commands is to actually hold the camera back up...
(More)
Display is mirrored. Only way to read or see various commands is to actually hold the camera back up to a mirror. Can't find anything in set-up that would control this.
I recently got a read error when viewing the pictures from my F470 XD Card (512M), when the images...
(More)
I recently got a read error when viewing the pictures from my F470 XD Card (512M), when the images are "not there," the card still shows a remaining capacity that suggests the images are still there, but they can't be accessed in the camera or the reader. How do I restore the pictures to the card? How do I fix the card so this doesnt happen again
Hi i have an olympus c-500 camera, and it won`t turn on ! It`s not the batteries, i saw the answer...
(More)
Hi i have an olympus c-500 camera, and it won`t turn on ! It`s not the batteries, i saw the answer for batteries, but i can turn it on by pressing the review button. It will show me pictures previously taken, but when i press the camera button , in order to start taking pics, it keeps on beeping .. same if i press the power button .. keeps on beeping and turns itself off. The thing is my camera got stuck like this after my batteries died, with the tube out , while taking pics .. help please
When I take picture, its automatically size is HQ 2048X 1535. I hope to change the setting to SQ1. I...
(More)
When I take picture, its automatically size is HQ 2048X 1535. I hope to change the setting to SQ1. I try to change it but just for that picture.I am tired to change the setting every time before I taking any pictures.
