Question about Filter Queen Majestic Canister Vacuum
Filter Queen, carpet attachment problem???
Help!!!
My carpet cleaning attachment doesn't seem to be getting suction. The brushes go around but the dirt isn't being picked up. When I use the other attachmentsthe suction is fine. Any ideas? Thanks.
  • wheelsmom Mar 13, 2008
    Thanks for your help, I will check that out.
    President:
  • 1,673 Answers
Open it up and see if the dirt inlet is clogged. It would be by the brush roll. But you must have a clog.
Posted on Mar 13, 2008
My vacuum isn't cleaning/suctioning very well. The hose attachment will work and pick up debris but the main part of the vacuum (where the brush is) doesn't pick up. The brush only spins but there...
Check to see if the brush is turning when you have the vac on and the handel down 'of course keep your hands from that area when doing this ,you might have to lean the vac ,to see the resaults.
Jul 09, 2011 | Panasonic MC-V7582 Bagless Upright Vacuum
The brush attachment always slows when it hits carpet. I've replaced belts and it just doesn't do what its supposed to. I doesn't seem to work very well. If the brush isn't moving how could it move the...
One thing you might want to try is to see if the brush itself is binding up at the ends. When dirt gets in the end pieces and makes the brush difficult to spin, it will slow down, add to that the contact with the carpet and it may slow down even more. Give the brush and axle a good cleaning to see if it works better. Add a bit of WD40 to the ends of the brush axle.
Oct 04, 2010 | Filter Queen Majestic Canister Vacuum
My Dyson 14 Animal seems to not have the suction
Hi its Darran at Dyson.
Firstly check that the brush bar control on the cleaner head is in the correct position. You may have switched the brush bar off the last time you used it or the dial may hav got knocked when you vacuumed under some low furniture.
If this is in the correct position but the brush bar is still not turning, switch the machine off and remove the soleplate by turning the 3 fasteners on the base of the machine and checking for blockages and remove any threads or hairs around the brush bar.
I would recommend washing the filter if it hasnt been done for a while.
You may find it useful to follow the blockage procedure and filter washing instructions in your user guide, however if you no longer have this available you download a replacement for free via the support section on our website at www.dyson.com.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Apr 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
No air pressure to **** up dirt
First test suction on unit without the hose, is there suction? If yes, attach hose and test. If no go to the door to outside, attach hose to the top of unit where it blows (under handle on top), put hose out door and turn on. The stuff clogging the hose should blow out the end.
If it wasn't the hose check the wand, and then the power nozzle and using the above to clear obstruction.
FQ Master
Your Authorized Filter Queen Service & Supplies
888-637-4692 in Iowa
May 31, 2009 | Filter Queen Majestic Canister Vacuum
The brush does not spin when making contact with carpeting
I tried the electrical-tape-around-the-wooden-spindle technique. After a minute or so, it's back to functioning normally.
Mar 14, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Hoover Savvy has limited suction when cleaning the floor and carpet
With the unit standing upright, double check the clear plastic air passages on the sides of the vacumn to see if they are clogged.
Jan 03, 2009 | Hoover U8171-900 / U8172-900 / U8173-900 /...
Suction loss when handle is tipped back to clean carpet
can any one help,
Our Dyson Animal vacuum has plenty of suction when it is upright and the attachments are being used off the hose, but when the handle is tipped back to begin cleaning carpets the beater head is getting no suction. As the handle is being tipped back you can hear what sounds like a flapper valve in the body of the vacuum opening and then all the suction just goes away.
Nov 19, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Losing power on a carpet attachment
Does the motor stop or the brush roll? If it is the brush roll, then replace the belt. If the motor is stopping, then it could be the motor or the cord for the opwer head.
Mar 15, 2008 | Vacuums
How to for Belt replacement and solution to suction loss
You say it lost its suction, then you also say this is plenty of suction power, seems you cant figure out the prob. Try cleaning the fan on the suction blower. The blades can get chocked with dust which will give you a reduced suction.
Jan 05, 2008 | Vacuums
Filter Queen Majestic Canister Vacuum Logo
222 people viewed this question
Top Filter Queen Vacuums Experts
Steve Sweetleaf
Steve Sweetleaf
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
