Targus power supply TIP for HP dv2630ea
What Targus Tip can I use for HP - Pavilion - DV2630EA Notebook. I have a Targus APM10 adapter, mpdel 800-0084-001A.
Many thanks
    Sergeant:
  • 458 Answers
Did you contact HP?
Posted on Mar 10, 2008
Dear Team, Overheating causes Video failure. BIOS updated to F13 for Fan to run constantly. Still causing problems related to overheating. Is there a recall on this product? or any other service to help...
When the CPU overheats then it will shutdown (i.e. thermal overload) and won't boot up again until it has cooled down.If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes this problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged withdust the remove the dust and make sure the vents are clear and dust free. Use acan of compressed air to do this.
Apr 14, 2011 | Pavilion dv2630ea dv2630ef dv2630en...
Universal power supply targus tip for Dell Latitude D620, won't charge battery, pop up says slow and no (charge), use only Dell. Is there a Targus tip that will go on Model APA10 Targus Universal power...
the problem is the BIOS of the Dell system is looking for an ID signal from the AC adapter so it knows what adapter is connected. If the BIOS cannot ID the power supply, then battery charger is disabled.
You will need to get a Dell AC adapter.
http://www.discountelectronics.com/index.php?l=product_detail&p=1459
Feb 15, 2010 | Dell Latitude D620 Notebook
Can this HP Pavilion DV9000 adapter fit Presario V3000 laptop
just see it from http://www.udtek.com/hp-pavilion-dv9000-ac-adapter-90w-185v-49a-p-2970.html.may this is good for you.
Jan 15, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
I have the targus universal power adapter and can't figure which
If you cannot find the right tip, plug each tip in the Targus and measure the voltage of each tip with a multi-meter.
On the bottom fo the Acer the operating voltage of the laptop will be printed on the label.
Select the tip that matches the voltage that is printed on the Acer label.
Sep 19, 2009 | Targus (PA179U) Car Adapter
The 6T04 adapter and adaptec AIC wont start
Make sure u using proper adapter. If u need to use compatible adapter. If ur company adapter is with yellow tip means its 65w adapter or if its black tip than its 90w. Now u decide which u need to use.
Jul 15, 2009 | HP Pavilion dv6000z Notebook
Need polarity of adapter plug for HP Pavilion DV6500
The cables for these are fairly specific, but if you have a cbale that has the same plugs and fits both the transformer side and the computer side, you cna use that as a replacement. The cord itself has no polarity.
Are you looking to do something else here?
Jan 01, 2009 | HP Pavilion DV6500T Notebook
No power
Try purchasing an original adapter. I've had several machine of different make through my shop that the Targus adapter just simply won't run. For example, a Dell Inspiron 1100 and HP dv4000 won't run at all, and a Dell Latitude 1501 and Gateway crv503 will run but won't charge the battery. Targus adapters are junk, if you can, get your money back.
Jun 28, 2008 | HP Pavilion dv1000 Notebook
Need to know which tip to use for power supply on my think pad model#r51
You can enter your model number and brand in the following link and compare the results to the tips and adapter you have.
http://targus.com/us/tipconfigurator/default.aspx?region=1&cat=Notebook
Apr 12, 2008 | Computers & Internet
Computers & Internet Logo
163 people viewed this question
Alun Cox
David Payne
David Payne
